    54 minutes ago, Rover said:
    In webEye I want to see the details in Do Manual refresh for details when you hover to a line showing a yellow rectangle.
    After editing jM you are able to see these details for a short time in webEye. When they are not visible I should like to refresh the content of the yellow rectangle by Reload or Toggle or whatever what, but both has no effect on this.
    Please press Toggle and then press Reload (don't wait for automatic reload), do you see next message?
    Please wait while generating table view..
    Toggle followed by reload (table view at once without waiting) followed by the nice email from Fibaro that "Device All-in-One has been turned off".
    And no details in the yellow rectangles!
    Edited by Rover
    I think I know what happens...
    You have passed the limit for global variable storage...
    You have one trueAct with over 50 commands (with conditions) (That's create a huge HTML data to display)
    As I see you have two options
    1. To run few AOQs
    2. To optimize your AOQ
    This is HC3 limit.
    Edited by cag014
    3 hours ago, cag014 said:
    @Rover  in order to speed up keyfob actions please try to use key-fob emulation for sceneACtivation. (does not support centralSceneSupport).
    Looks like even But[x]Release works much better
    To all
    As I recommended to avoid using slave device as a main item in jM line or using their values directly in conditions, because that slows down the AOQ. (Average API:GET takes ~90mSec. If you have for example 30 items it creates delay of 3 seconds (due to value scanning and retrieve).
    The best option is to use emulation for main items. The "slave" idea is to control devices (like turn ON/OFF, set value and etc..)
    So in {0,"`LichtHuiskamer`",{state="value<20",initOnStartup=false,lineState={"if {`LichtenAanStatus`:value=false}"}, where `LichtenAanStatus` checks 13 devices and takes 1.2 seconds?
    For example I think all those commands could be optimized in one
    {"`Pushover`", '+Send_Pushover,json[["&PushoverTitle","&Prio","&PushoverSound","Keukenraam"]]',"if {`Keukenraam`:alarm=breached}"},
        {"`Pushover`", '+Send_Pushover,json[["&PushoverTitle","&Prio","&PushoverSound","Bovenraam Keuken"]]' ,"if {`BovenraamKeuken`:alarm=breached}"},
        {"`Pushover`", '+Send_Pushover,json[["&PushoverTitle","&Prio","&PushoverSound","Bovenraam Bijkeuken"]]',"if {`BovenraamBijkeuken`:alarm=breached}"},
        {"`Pushover`", '+Send_Pushover,json[["&PushoverTitle","&Prio","&PushoverSound","Veluxraam Kamer Hans"]]',"if {`VeluxKamerHans`:alarm=breached}"},
        {"`Pushover`", '+Send_Pushover,json[["&PushoverTitle","&Prio","&PushoverSound","Veluxraam Kamer Gloria"]]',"if {`VeluxKamerGloria`:alarm=breached}"},
        {"`Pushover`", '+Send_Pushover,json[["&PushoverTitle","&Prio","&PushoverSound","Veluxraam Badkamer"]]',"if {`VeluxBadkamer`:alarm=breached}"},
        {"`Pushover`", '+Send_Pushover,json[["&PushoverTitle","&Prio","&PushoverSound","Veluxraam Garderobekamer"]]',"if {`VeluxGarderobekamer`:alarm=breached}"},
        {"`Pushover`", '+Send_Pushover,json[["&PushoverTitle","&Prio","&PushoverSound","Schuurdeur Achter"]]',"if {`SchuurdeurAchter`:alarm=breached}"},
        {"`Pushover`", '+Send_Pushover,json[["&PushoverTitle","&Prio","&PushoverSound","Beweging Overloop"]]',"if {`BewegingOverloop`:alarm=breached}"},
        {"`Pushover`", '+Send_Pushover,json[["&PushoverTitle","&Prio","&PushoverSound","Beweging Hal"]]',"if {`BewegingHal`:alarm=breached}"},
        {"`Pushover`", '+Send_Pushover,json[["&PushoverTitle","&Prio","&PushoverSound","Beweging Huiskamer"]]',"if {`BewegingHuiskamer`:alarm=breached}"},
        {"`Pushover`", '+Send_Pushover,json[["&PushoverTitle","&Prio","&PushoverSound","Rook Huiskamer"]]',"if {`RookHuiskamer`:alarm=breached}"},
    by setting GV which sensor has breached
    if the devices are slaves, yes it is?
    1. To run few AOQs
    This is HC3 limit.
    But I am not ready yet developping with AOQ ?
    What is your advice?
    What is possible in optimizing AOQ?
    Most of them are not slaves.
    If these commands are binded by setting a GV, what is then the optimization? Each breaching has to be checked anyhow.
    And I want a Pushover notification for each breaching, not only one, although the chance of breaching more than one at the same time is indeed little.
    Edited by Rover
    And I want a Pushover notification for each breaching, not only one, although the chance of breaching more than one at the same time is indeed small.
    Indeed, but it's better to have jM line for each sensor rather then running conditions... as I said it creates more HTML data... and this is a huge long line in table (50 commands).
    As I see few sensors already has a jM line!?
    By the way these sensors are direct devices on HC2... not emulated... and should not have alarm property...
    Edited by cag014
    @cag014 working for you the sunset and sunrise hours code? Today was the winter time set up and not working for me.
    Looks like no change? HC3 has been updated for correct time, but sunset and sunrise still the same?
    Go to Swagger -> settings/info see if it's updated for you?
    Edited by cag014
    Yes, the HC3 has benn updated for correct time, but absolutely not working the sunset and sunrise hour. In the AOQ i see the sunset and sunrise hours.
    OK, I needed reboot the HC3.
    Please let's know if it helps...
    After the reboot working fine.
    In my head there is the fact that soon these not slave sensors, as well as the slave sensors, will all be HC3 sensors.
    Does this  make another view on the way of optimizing?
    On 10/23/2020 at 1:18 AM, cag014 said:
    Yea ?
    I want to give this present back!
    Error notifications still overflowed!!!
    What errors?
    1 hour ago, cag014 said:
    What errors?
    This errors!
    OK, debug notifications ?
    Edited by Rover
    8 hours ago, Rover said:
    All,
    This is the version that I'll release tomorrow in forum
    No debug information anymore
    In addition attached Slave Remote Controller for centralScene
    Edited by cag014
    All,
    Sorry cag014, but in my hc3 v5.8 has a huge impact on cpu load.It looks like 20% higher cpu load in idle.
    v 5.8
    v 5.7
