3 minutes ago, cag014 said:
Finally it looks the same as for others....
Yesss. You are great! Thank you very much!
It inmediately reacts to everything.
Edited by SmartLifeSystems
    3 minutes ago, Rover said:
    But you have added quite a lot in the last period: if/and human reading, rpt, etc., etc.....
    Yes, and it's already there in download...
    All latest improvements already updated in AOS and will be released with AOQ next week. (I hope, if no new issues will popup)
    V5.3 still not working
    [22.10.2020] [19:43:28] [ERROR] [QUICKAPP66]: QuickApp crashed[22.10.2020] [19:43:28] [ERROR] [QUICKAPP66]: mainCode.lua:2: attempt to perform arithmetic on a nil value[22.10.2020] [19:44:00] [ERROR] [QUICKAPP66]: QuickApp crashed[22.10.2020] [19:44:00] [ERROR] [QUICKAPP66]: mainCode.lua:2: attempt to perform arithmetic on a nil value[22.10.2020] [19:45:00] [ERROR] [QUICKAPP66]: QuickApp crashed[22.10.2020] [19:45:00] [ERROR] [QUICKAPP66]: mainCode.lua:2: attempt to perform arithmetic on a nil value[22.10.2020] [19:46:00] [ERROR] [QUICKAPP66]: QuickApp crashed[22.10.2020] [19:46:00] [ERROR] [QUICKAPP66]: mainCode.lua:2: attempt to perform arithmetic on a nil value[22.10.2020] [19:46:39] [ERROR] [QUICKAPP66]: QuickApp crashed[22.10.2020] [19:46:39] [ERROR] [QUICKAPP66]: mainCode.lua:2: attempt to perform arithmetic on a nil value[22.10.2020] [19:46:39] [ERROR] [QUICKAPP66]: QuickApp crashed[22.10.2020] [19:46:39] [ERROR] [QUICKAPP66]: mainCode.lua:2: attempt to perform arithmetic on a nil value[22.10.2020] [19:47:00] [ERROR] [QUICKAPP66]: QuickApp crashed[22.10.2020] [19:47:00] [ERROR] [QUICKAPP66]: mainCode.lua:2: attempt to perform arithmetic on a nil value
    37 minutes ago, cag014 said:
    I think the best idea is develop on AOQ on your HC3 and then transfer the jM lines to him.
    It's pretty same that what I'm doing right now on my HC3. I have one motion sensor, one switch, one RGBW and one keyFob. Using these devices I can simulate almost every basic scenario...
    Regarding  using slave devices for HC2, you do realize while you develop some solution, it will active "crazy" at his home?
    I do believe you have enough devices on your HC3 to simulate whatever needed on HC2
    Use attached
    @Rover try this.
    2 minutes ago, SmartLifeSystems said:
    @Rover try this.
    [22.10.2020] [20:05:08] [ERROR] [QUICKAPP66]: QuickApp crashed[22.10.2020] [20:05:08] [ERROR] [QUICKAPP66]: mainCode.lua:2: attempt to perform arithmetic on a nil value
    Hmmm. For me working fine.
    Hi How to set a GV and how to retrieve?
    {0,"`hoofdSlaapKamerlader`",
      {state="value=true",
      trueAct={{"`&mydagRitme`",{value="bedTijd"},falseAct={{"`&mydagRitme`",{value="opStaan"}}}},
    The best option is to use AOQ GV...
    global4local= {false,gVarName="",varArray={onState="init:0",myVar="isOff"}}
    If you must to keep last value when AOQ restarted (due to changes and updates) you can use system's global value to save the states . Create global variable in HC3 (let's say AOQtank) and then define as follow
    global4local= {true,gVarName="AOQtank",varArray={onState="init:0",myVar="isOff"}}
    Now you can use (following this example)
    &onState
    &myVar
    By the way the main difference between keyWord and GV, that GV could be set in jM lines, while keyWord needs a function.
    If you don't mine, please post AOQ QA... and I'll take a look.
    Edited by cag014
    17 minutes ago, cag014 said:
    I'll take a look.
    out of curiosity, did you ever checked logs from HC3 running AOS / AOQ?
    V5.2
    Edited by Rover
    Cag,
    I do it wrong;
    how to tell that hoofdSlaapKamerlader triggers the global4local?
    global4local= {true,gVarName="DagRitme",varArray={BedTijd="init:0",OpStaan="isOff"}},
      {0,"`DagRitme`",
      {state="value=&BedTijd",
      trueAct={{"`stekkers`","turnOff","","`stekkersUit`","turnOff","","`stekkersVertraagd`","turnOff","8100"},
      falseAct={{"`stekkers`","turnOn","","`stekkersVertraagd`","turnOn",""}}}}},
    Error in DagRitme
    Please advice,
    //Sjakie
    Cag,
    I do it wrong;
      {0,"`DagRitme`",
    Error in DagRitme
    Please advice,
    //Sjakie
    No no no... the DagRitme is the global variable to store AOQ GVs. It's never can be used in AOQ as a parameter.
    As I understand if BedTijd=0 then trueAct()
    {0,"&BedTijd",
      {state="value=0",
    2 hours ago, Rover said:
    V5.2
    Works... no error!?
    4 minutes ago, cag014 said:
    Works... no error!?
    Yes, works in 5.2, but not in 5.3.
    As always your AOQ has all options...
    Fixed
    Fixed
    [23.10.2020] [00:12:22] [ERROR] [QUICKAPP66]: QuickApp crashed
    [23.10.2020] [00:12:22] [ERROR] [QUICKAPP66]: mainCode.lua:2: attempt to perform arithmetic on a nil value
    That's incredible... from some reason by defining function in mainCode QA behaves differently.
    So now it's about the time to replace the order of main and mainCode.
    Please add new file user_data
    Copy/paste data from main to user_data
    Copy/paste data from mainCode to main
    Delete mainCode
    Save user_data, main and you are set.
    to copy quickly entire text use ctrl+A then ctrl+C . To paste ctrl+A then ctrl+V
    Delete mainCode
    v5.4 works ?
    Does loop
    [23.10.2020] [01:06:32] [DEBUG] [AOQ66]: onTime end loop 82 3
    [23.10.2020] [01:07:54] [DEBUG] [AOQ66]: onTime end loop 82 3
    [23.10.2020] [01:08:24] [DEBUG] [AOQ66]: onTime end loop 82 3
    [23.10.2020] [01:08:30] [DEBUG] [AOQ66]: onTime end loop 82 3
    going on forever?
    v5.4 works ?
    Does loop
    going on forever?
    Oops... it was a debug line for @SmartLifeSystems
    And now I got his present ?
