    2 minutes ago, Rover said:
    Post this QA and I'll check
    Edited by Rover
    Wow... Fibaro has changed the site look ...
    Anyhow , have find the problem.. new concept works faster, but needs to encode the url.
    In this case one parameter in json has a space... "Alarm Uit"
    Fixed ...
    Fixed ...
    Still an issue about "secure"
    In the new site look choose files and drag to spoiler does not work anymore, just paste image works.
    What is the new concept?
    Edit has been gone !!! No it is in the right upper corner under the ...
    Edited by Rover
    Is it worked before?
    What is this device ?
    Yes it has worked before.
    Device is Danalock lock.
    Edited by cag014
    5 minutes ago, cag014 said:
    Oops... my bad copy/paste miss function
    Pushover works again ?, TNX for the repair.
    api.get instead of api.post to executed commands. works faster.
    Hi cag!
    Can you help me? Why is the delay in the lines. If i push a button, or a MS/DS is breached, the actions will do after ~3sec or sometimes more than 3sec.
    Anybody have got this problem?
    Edited by SmartLifeSystems
    Test for consecutive Pushover notifications:
    Very interesting is that the programmed line delays have not been effected...
    Edited by Rover
    Edited by cag014
    3 hours ago, SmartLifeSystems said:
    Hi cag!
    That's indeed strange...
    Do you have any Slave device emulated on HC3?
    @Rover
    I'm wondering if you see that your debug window is slow? (I believe you're using full size debug window)
    I had same issue when debug window has slow response and suddenly sent all printouts in one batch.
    Please close debug window and open new..
    let me know if you see the same
    Edited by cag014
    @Rover
    Did the same line as yours, but without sending the push message in Pushover. Just print the parameters and then end .
    Looks and works fine.
    You somehow need to make sure that Pushover QA has finished to send the message before send another.
    21 hours ago, SmartLifeSystems said:
    Hi cag!
    I am wondering if you have been thinking about the google calendar solution? Do you think it can be created?
    Right now AOQ doesn't support dates  (like 20/oct/2020), so it couldn't be done by default.
    But you can create userKeyword with function that synchronizes the calendar
    for example
    userKeyWord={{"$myTime","$dayTime"},
        {function () ....... use calender and return timeSlot value end},
    function() return  os.date("*t",os_time()).hour<6 and "Good night," or os.date("*t",os_time()).hour<12 and "Good morning," or os.date("*t",os_time()).hour<18 and "Good afternoon," or os.date("*t",os_time()).hour<=23 and "Good evening," end }}
    in jM use $myTime keyword.
    {0,"..............{.....,timeSlot="$myTime",.......}}},
    BTW - could you post a specific example of calendar dates usage (I believe you refer to holidays) in actions?
    Edited by cag014
    6 hours ago, cag014 said:
    That's pushover issue... you cannot send message till the first message is sent..
    QuickApp won't response till it's running.
    Interesting based on remark in Pushover it can take a while!??
     --Send a high priority code every 30 seconds for approx 3600 seconds until the message is acknowledged by the app on the smartphone.
            --The alien-message is being used.
    That is my own remark for realizing repeating high priority messages, fixed coded in the Pushover QA (the rest is German language).
    How waiting until Pushover QA is ready? PushoverID:value= true means that message has been sent, but using verify is difficult if you have a list of possible Pushover notifications.
    No. Only the master HC3.
    In pushover QA there is a timeout of 5 seconds for HTTP command, it means HTTP will be finished in any case (fail or success), so you need at least delay of 5 seconds between sending messages (I recommend 6 sec. to be on safe side)
    Edited by cag014
    So you don't have SlaveSensor, SlaveSwitch or SlaveDimmer emulated on HC3?
    Try to close debug window and to open new
    Did the same scenario, no delays
    Edited by cag014
    @SmartLifeSystems
    Had same issue for 1 hour and then it's gone... no delays any more.
    Something sows down HC3, (connection to Fibaro remote server, CPU, Internet..)
    Please check again.
    Will continue to monitor that.. maybe you can see some abnormal behavior when it happens
    Edited by cag014
