Here you see HC3,
start at 15.13 and higher CPU 15.14 just running
See also your memory when start its higher when running normal it will be lower
3 minutes ago, cag014 said:
Version 5.050.13 ?
Yes.
3 hours ago, cag014 said:
I believe there is an error in Pushover, after print("status =",status.status) there are a lot of printouts that not appear on debug window?
for example
                print("Nachricht gesendet :"..message)  -- this is an error. There is no such parameter message in the code!?  There is settings.message... please go through code and change it at all places.
That's the reason that 7 seconds not good enough... the QA is resets himself and it takes much more than 7 seconds.
By the way in the future to avoid concatenating null values, just use
print ("Nachricht gesendet :",message) in this way you'll see null printed (or blank) and you can identify the error.
(and yes, this is Fibaro bug that error doesn't shown)
You are right again cag ?
With the corrections even 2 seconds in between works!
Rover good behaviour  off your CPU
In my case
130 devices (80 hue)
7 devices for doorbell
5 Sensor
QA
Scenes
//Sjakie
58 minutes ago, SmartLifeSystems said:
1. Inmediately
2. Yes I have. In AOQ and In Lua too
3. Any QA only the AOQ and my SONY TV.
4. attachement screenshot
5. I have a Nice gate.
Where can I see this number of devices?
Settings, 16. Z-Wave.
    Great...
    5.050.13 verzió ?
    So i deleted the all lines, and the CPU's load was normaly.
    If i started loaded back the lines, the CPU's load was higher, but the AOQ's answere time was fast.
    For the AOQ don't like somethings, but i don't understand what is it.
    If the lines number upped, the CPU load and the AOQ's answere time proportionately upped too.
    Edited by SmartLifeSystems
    So i started again the lines back load.
    The timeslot upping my CPU load. $sunsetHour~$sunriseHour. If i delete this code, my CPU load normaly.
    See my attachement. When i used the timeslot, the CPU higher, than before, and then after lower, when i delete this code.
    How many lines you have?
    You can see that when AOQ started
    Not the lines number is my problem.
    2 minutes ago, SmartLifeSystems said:
    165. But read my prev message.
    5 minutes ago, cag014 said:
    Yes, but i start again the lines back loading. Line to line. And the first line with timslot code, upping the CPU' load. I use the time slot many time. I think something similar is my problem.
    Did some tests and don't see any impact from timeSlot.
    In addition have tested attached version with 175 lines!
    To all - as I suggested before please keep your jM lines optimized (each and every line must be checked for conditions, states and time)
    This version has built in optimization....
    Let me know how it works
    Thank you! What i need see in this version ("This version has built in optimization....")?
    The AOQ write something in the debug window?
    Yes, if main loop will take over 4 seconds...
    Quickly back to version 5.0!
    Edited by Rover
    5 minutes ago, Rover said:
    Why?
    1 minute ago, SmartLifeSystems said:
    Why?
    See attached picture. Endless: Variable test not found!
    52 minutes ago, Rover said:
    Sorry... one of leftovers of problem debugging.... removed
    Edited by cag014
