Zone $KamerGlo has 2 D/W sensors (SlaveSensor).
Is it normal that when one window is open the armAlarm results in okAct?
It is getting worse, worser, ...
Doubleclick button ZwaveMe wallswitch ('hc2) until switching HC3 Wallplug (so no HC2 slave or 'hc2) in seconds: 22, 21, 14, 62, 33, 145
    2 hours ago, Rover said:
    Wow... it means you send too many commands to the slave!
    You probably control entire HC2 from HC3.
    How fast you see the action executed on HC3 after pressing ZwaveMe in HC2?
    145 seconds to react? are you sure? may be some condition prevent to execute the command ?
    Edited by cag014
    @Rover
    I have an idea that could speed up the execution... will post the version.
    No, these are the reaction times. You see this simple AOQ line, no other conditions!
    Also other remotes like the SceneMaster have extreme delay's: setting a dimmer on: 40 seconds!
    Edited by Rover
    @Rover
    Let's see if this faster...
    2 hours ago, cag014 said:
    @Rover
    15,10,23,9,11 seconds.
    Edited by Rover
    7 minutes ago, Rover said:
    Is it the only line in jM?
    Now in AOQ is api.get() in use (instead of api.post). This is the same way that fibaro.call executed.
    Could be something wrong with you network connection?
    Did the same line in mine system, takes less than 0.5 seconds....
    Edited by cag014
    Joking?
    Do you want to see the rest?
    12 minutes ago, Rover said:
    Joking?
    No, could you make it the only line in jM.
    It's easy, at the end of the jM start new jM with one line (don't need to delete or remark all lines)
    Another question: is most of your lines monitors HC2 devices... I mean the main device i the line?
    Edited by cag014
    Same line: no delay...
    Now the best idea is to add few lines at a time , to find where the problem starts...
    OK
    By the way overall it looks faster than previous version (although it's not fast enough)
    I saw you are using many devices for the same command, will try to use group command over network.
    Edited by cag014
    43 minutes ago, Rover said:
    OK
    Added a part of the lines: delay.
    Stripping until the one line: delay differs from 0 to a few seconds and often no response at all.
    Triggered wallswitch several times again (so 1 line):
    Edited by Rover
    Could you post these lines (that creates delays), will try to emulate it on my system.
    Including jS2n if you're using aliases
    Edited by cag014
    It was only the jM with 1 line toggling a HC3 wallplug.
    When I see this, then it looks impossible to operate a system...
