1 hour ago, Rover said:
Why does not trigger the showed line at all?
Not if pushed the button 1x, not if pushed the button for longer time (Hold/Release).
Edited by Rover
I receive message of high response time on HCL (and that expected), have set
slaveApiTime=1200
now it works and no warning displayed, but I would like to keep lower limit for HC2 in case of problems.
Any option to define slaveApiTime for each slave?
Edited by AR27690
    slaveApiTime=1200
    I have noticed about that yesterday... work in progress...
    25 minutes ago, cag014 said:
    So maximum 2 seconds to activate... unless HC2 has some delay inside...or HC3
    Few tests:
    When icons changes on HC3, how fast turnOn action appears on HC3 debug window?
    What happens when you turn the light from GUI of HC2?
    Could you post jM line of that action
    What happens when you turn the light from GUI of HC2? : No delay
    When icons changes on HC3, how fast turnOn action appears on HC3 debug window?: About 2 seconds.
    Based  on your line it actually should take over 5 seconds... as you have one second to execute REST API
    first action to turn Schilderijspot (1 sec.)... then TestLicht (+1sec), then to evaluate value of &Huisstatus (+1sec) now to turn on SpotsTrapOverLoop (+1 sec)  and again TestLicht?  (Why again?)
    Overall I don't understand why API execution takes almost 1 second?
    Another interesting test that you can do to verify this response time
    Set SlaveSwitch emulator for one of the lights on HC2. Now turn it on/off, how long it takes? (the API in SlaveSwitch is exactly the same as in AOQ)
    Edited by cag014
    slaveApiTime=1200
    Here how you can define different response time limits
    in jSlave {} table define slaveApiTime specific for that slave
    Slave={
            hcl={user="xxx",passwd="xxx",ip="xxxx",slaveApiTime=1200},
            hc2={user="xxx",passwd="xxx,ip="xxxx"}
    When no time defined in jSlave the slaveApiTime  in AOQ parameters will be used.  In this case hc2 will be set to that.
    If no slaveApiTime defined at all (not in jSlave table and not in AOQ parameters ) 600 milliseconds  as default will set for all.
    Indeed second turnOnn TestLicht is not needed, deleted.
    Schilderijspot changed to SlaveSwitch.
    The SlaveSensor lost its icon again and it is not possible to get an icon in this QA again, so I have to count from the moment when I move in front of the sensor.
    Measurements: TestLicht-Schilderijspot-SpotsTrapOverLoop
    17-17-23, 9-9-17, 6-6-17, 16-16-20, 6-6-17.
    So HC3 light and SlaveSwitch light have the same delay, while <device>'hc2 light has a lot more delay.
    And the delays are quite unstable.
    PostTime=0.489
    When I have a look in webEye, it do not looks well...
    Edited by Rover
    New measurements after installing new SlaveSensor to be able to see an icon, counting from seeing icon On:
    TestLicht-Schilderijspot-SpotsTrapOverLoop :
    On 1-2-15 Off 1-2-?
    On 1-2-22 Off 1-10-10
    On 1-2-14 Off 1-2-42
    Cag, you have written that it is dangerous to reboot the HC3 with this AOQ version, or did I misunderstood this?
    Dangerous to reboot ? What do you mean?
    AOQ just a QuickApp in HC3 like any others.. nor risk to reboot
    On 1-2-15 Off 1-2-?
    What about activate the lights from SlaveSwitch?
    I think the best option to see what is wrong, is to have just on line in jM. If slavesensor breached turn on the light - that's all
    Edited by cag014
    I thought, maybe rebooting HC3 might help, or is that a wrong idea?
    Yes, it's a good idea... let's see.
    By the way this morning HC3 sopped to send email from QA devices (works fine from Lua/block scenes), did reboot and now it works fine.
    HC3 is not stable yet...
    Hi cag, please assist in the solution.
    Edited by Rover
    Why double brackets?
    {0,"`OverloopSwitch`",{lineState={" if { {`OverloopSwitch`:sceneActivation=`But2Single`} or {`OverloopSwitch`:sceneActivation=`But2Release` and `OverloopSwitch`:sceneActivation<>`But2Hold`}}"},
    should be
    {0,"`OverloopSwitch`",{lineState={" if {`OverloopSwitch`:sceneActivation=`But2Single`} or {`OverloopSwitch`:sceneActivation=`But2Release` and `OverloopSwitch`:sceneActivation<>`But2Hold`}"},
    should be
    does not looking good in hcWebEye.
    46 minutes ago, Rover said:
    This is not the same line, right?
    What are definitions for all these parameters, I mean line with But1Single, But1Release, But1Hold looke good,
    but line with But3Single, But3Release, But3Hold does not?
    No, it is another line, but with the same like content.
    The message is that the AND and OR construction fail and the other one is OK, if you have a look at hcWebEye.
    Edited by Rover
    As usual... your code is the best debugger...
    Have set an option for and/or in actions, totally forgot about lineState.
    Thanks for reminding me... meanwhile please use previous format in lineState  (use "|" as "and"), "or" works fine.
    Will fix it...
    Will fix it...
    OK, already did it ?
    Edited by Rover
    Using webEye it is uneasy that Toggle do not refresh, so that de details cannot be seen. Just editing AOQ code will refresh the webEye.
