8 minutes ago, cag014 said:
OK, I think may be this is the problem:
Is your sensor included in other alarm zones as well?
If so till all of them are not disarmed it stays breached as it should be. You want to know in every zone wich sensor has breached.
As I said when you disarm alarm zoe it's beeter to verify the alarm zone state and not one of sensors.
Let me know if this is the situation
Yes, the two sensors are included in one other alarm zone, just as HC2Proxy sensors (changed now to sensorSlave devices).
Is a sensor just allowed to be member of one alarm zone?
As you see I verify the zone and not one sensor.
It is still peculiar that in the armed and breaching state HC3 Alarm page and HC3 lights no alarm status has been shown.
    No, every sensor could be included in every alarm zone.
    Finally have figured out the change in new HC3 version... it executes AlarmPartitionBreachedEvent along with AlarmPartitionArmedEvent  if alarm has breached...
    Any how, here fixed AOQ
    Edited by cag014
    22 hours ago, cag014 said:
    Wow you're great
    Your quick app
    what fibaro couldn't try
    You did it
    thanks
    Edited by minsad79
    TNX for the repair, cag,
    Arming and disarming an alarm zone works also when breached. HC3 Alarm page and HC3 lights show arming status also. ?
    Hi cag!
    Do you think the google calendar can we integrated into the AOQ? For example because of holidays and other events.
    35 minutes ago, SmartLifeSystems said:
    Hi cag!
    Any specific example ?
    For example at christmas the christmas lights turn on automatically, or a national holiday we don't work so the workday scenes should not start.
    Or if there is an event in the calendar, a scene should start.
    Edited by SmartLifeSystems
    what is wrong in:
    9 hours ago, Rover said:
    what is wrong in:
    In condition the devices list must be separated by comma ","  and not by "|". The "|" sign used as "and" statement in condition.
    { 220'hc2,237'hc2,216'hc2,102'hc2,241'hc2,186'hc2,313'hc2,227'hc2,229'hc2,283'hc2,206'hc2,329'hc2:value=false}
    May I suggest after jS2n table to create a new alias like:
    jS2n={........................}
    LichtenAanState = LichtenAan:gsub("|", ",")
    jM={...}
    Now you have a new allias LichtenAanState  which includes same devices for condition statement.
    The advantage is that any change in LichtenAan will reflected on line in LichtenAanState.
    But in this case if each sensor already has a line in jM, I do suggest to use variable by adding in trueAct and falseAct tables global counter. More efficient and faster instead of reading values of so many sensor.
    Define global in (on init must be 0)
    global4local= {......,varArray={msCnt="init:0",.....}}
    {0,"220'hc2",{state="value=true", trueAct={"&msCnt","setGlobal","?&msCnt+1?"}, falseAct={"&msCnt","setGlobal","?max((&msCnt-1),0)?"}}}},
    same for every sensor...
    Now in condition
    " if {&msCnt:value>0}"
    If you don't have all sensors as a main device in jM line, ignore that suggestion.
    Edited by cag014
    jM={...}
    Now in condition
    Good trick, but:
    in the USER SHORTCUTS delivers:
    I do not have all sensors as a main device in jM line if you mean as main device: {0,"<maindevice>",...
    BTW: the devices in LichtenAan are no sensors, but actuators (lights).
    Edited by Rover
    On 10/9/2020 at 6:53 PM, Rover said:
    Interesting:
    3 hours ago, Rover said:
    Good trick, but:
    oops... my bad... they're part of jS2n table.
    Use
    jS2n.LichtenAanState = jS2n.LichtenAan:gsub("|", ",")
    Edited by cag014
    Use
    Why does not work:
    15 hours ago, Rover said:
    Why does not work:
    What is it?
    This is the format
    {"`Schilderijspot`|`SpotsTrapOverloop`","turnOn"},
    and supported in conditions only...
    Edited by cag014
    18 hours ago, Rover said:
    I saw the error: `LichtenAan` is a nested set and the jS2n.LichtenAanState = jS2n.LichtenAan:gsub("|", ",") works only at the highest level of the nest.
    Works now.
    OK, no it's understandable...
    This email has not been received by Outlook. The last email received from AOQ was on 13-10-2020 on 10:20. All AOQ emails after this time have not been received. Email and Outlook is working fine for other senders.
    Hi cag014
    I did as you said and tracing remote device for "networkError" it does work, but AOQ crashes and restarted all the time (till connection is good again).
    Any chance to make it work without need to change jM lines?
    3 minutes ago, Rover said:
    Same for HC2 and HCL, no emails, probably Fibaro's server issue.
    7 minutes ago, Rover said:
    Yes, looks like fibaro issue.
    I have 4.600 on HC2 and it was fine till few hours ago....
