alarm=breached still not working:
Voordeur is a SlaveSensor.fqa
    Edited by cag014
    17 minutes ago, cag014 said:
    Tested and it works..
    Is Voordeur included in any alarm zone
    No, there was still the HC2Proxy device present in the alarm zone, but the SlaveSensor.fqa does the job ?
    It turns out that using HC2Proxy is not useful anymore when using AOQ.
    19 hours ago, minsad79 said:
    Tricky task
    But I think you canI live in koreaI support you in a far country
    As wanted...
    This slave QA has a button to stop/restart emulation as requested by few users to stop emulation for debugging purpose.
    In future will add same button to other slave QAs...
    Edited by cag014
    Hi cag,
    The first day on the week is the sunday?
    In the timeslot w=2~6 is monday to friday?
    I have got a line in this timeslot, and the AOQ did the line, but today is saturday.
    Edited by SmartLifeSystems
    Hi @cag014,
    Disarming an arming zone is not quite successful:
    Very special that Alarm page and HC3 lights show no alarm state ???
    BTW I have HC3 version 5.050.13
    Edited by Rover
    4 hours ago, SmartLifeSystems said:
    Hi cag,
    The first week day is different from country to country.
    In Hungary the first day is Monday. So your time slot should be w=1~5.
    See first week day by countries.
    I probably need to mention that in documents.
    Since the first day could be Saturday or Sunday or Monday, in documents I took the middle day (Sunday). Will change it.
    Edited by cag014
    Thanks! I thought I had to use sunday at the first day.
    14 hours ago, cag014 said:
    As wanted...
    Works fine and I see it supports favorite colors also, but I'm trying to set color and used in AOQ.
    There is any chance to display the RGBW value (132,123,11,0) that could be used in command?
    Thanks.
    Edited by AR27690
    Thanks.
    due to lack of  white color support on Fibaro color bar, have added white bar slider and RGBW is displayed.
    BTW never saw any user actually using White values!!??? May be now...
    Edited by cag014
    BTW never saw any user actually using White values!!??? May be know..
    Thanks.. Wow, White color creates interesting colors.
    In addition have followed your advice about HCL and did basic activities in HCL all others on AOQ.
    Have found a big advantage - all emergency activities are on AOQ (Fibaro button, alarm, presence monitoring) and now I'm actually monitoring the status of my mother and her home on-line.
    Just one question - how can I get notification if internet connection to HCL has lost? I need that very much
    4 hours ago, Rover said:
    You mean the color?
    It means that  you're sending same command as executed last time. Just cosmetics to see that you don't send same command too many times. Might be some optimization could be done...
    The actions are executed the same regardless the color
    Edited by cag014
    7 hours ago, Rover said:
    Hi @cag014,
    First of all regarding two time execution:
    During verification AOQ sends again the command - to be on safe side
    Regarding other issues - Let me test with the new HC3 version  and I'll back to you.
    Meanwhile could you replace the sensor to alarm zone. I mean in condition, instead of relying on sensor state it's better to check the alarm itself. $KamerGlo
    Just try it
    Edited by cag014
    Nice idea to keep emergency actions close to you.
    You do have an option to identify immediately if connection lost..
    Any HCL device in AOQ will have value of "networkError" when connection lost. For example
    {0,"700'hcl",{state="value=networkError", trueAct={{"","tts","Warning, unable to reach Home center lite controller"},{"Networ Error","sendPush","Lost connection to HCL"}}}},
    You can do it on any HCL device and send PUSH notification and TTS announcement. (If you have TTS)
    Another suggestion to have more reliable remote connection outside of your LAN , use fixed IP from your provider.
    Edited by cag014
    BTW never saw any user actually using White values!!??? May be know...
    I use the white color for steering indoor siren and outdoor alarm lights.
    You're the first person that I know in this forum that uses white value.
    50 minutes ago, cag014 said:
    You mean the color?
    No, I mean that in the timeSlot more than once has been triggered.
    Quite an honor ?
    8 hours ago, Rover said:
    Hi @cag014,
    OK, I think may be this is the problem:
    Is your sensor included in other alarm zones as well?
    If so till all of them are not disarmed it stays breached as it should be. You want to know in every zone which sensor has breached.
    As I said when you disarm alarm zone it's better to verify the alarm zone state and not one of then sensors in the zone
    Let me know if this is the situation
    To remind you when using alarm zone instaed fof property use value.
    "{$KamerGlo:value=disarmed}"
    Edited by cag014
