    4 minutes ago, gggizmo said:
    please clarify where and which values i have to add please
    and remote.fqa, slaveswitch, slavesensor need to be updated?
    no changes on remote, slaveswitch and slavesensors QAs
    Add according to the picture in user data
    8 hours ago, SmartLifeSystems said:
    I tried the code, but don't do nothing.
    As I thought... thanks for confirmation, I was afraid that something wrong in my HC3.
    Finally I think I have figure out what's wrong, in scenes Fibaro uses user IDs and not mobile IDs, although both configurations work in QA??? Have reported to fibaro about that.
    Just for you did some changes to see if it helps.
     After upgrade to attached version please use users IDs instead of mobile in the commands.
    Let me know if it works
    All others please don't download this version.
    Hi @cag014,
    10der has adapted the fine SonosPlayer QA of Tinman to a still finer SonosHub QA, that interrupts music for a sound with dedicated volume and restore volume of music and playing music further after playing the sound. These were for many years the omissions in the Sonos VD and QA of Krikroff.
    The number of parameters of 10der is different from those of Tinman.
    Tinman: "SonosPlayerQA-ID", "playFromCIFS" , "SoundIP.mp3"  It works in scene.
    Plays the sound, but of course after 80 seconds delay and no sound setting.
    Edited by Rover
    sorry but in ver 4 i see again double comand and...remote act turn on and off lights..due to double command
    /monthly_2020_10/image.png.99b17e779260fed26e84cb6a86c7208e.png" />
    After a reboot everithing works as expected. I can't believe that this beta is so unstable...
    Sorry, but no. I have got an error message.
    [2020-10-06] [18:15:26] [DEBUG] [AOQ3694]:  [06 Oct 18:15:26] /opt/fibaro/AOQ3694.jM hash table:78:~: {30, "`hairStraightener`"...}
    {30,"388",{"timeLoopAct"={"Hajvasaló:","sendPush","A hajvasalót bekapcsolva felejthetted. Nézd meg kérlek!"},"state"="value>0"}}
    (16) ID (3368) has not been found in the system.
    Available mobiles (in Green - authorized):
    413:Noémi iPhone-ja
    3370:Attila iPhone-ja
    Available users:
    3368:Attila:[email protected]
    385:Noncsi:[email protected]
    [2020-10-06] [18:15:26] [ERROR] [QUICKAPP3694]: QuickApp crashed[2020-10-06] [18:15:26] [ERROR] [QUICKAPP3694]: mainCode.lua:319: attempt to call a nil value (method 'stop')
    Wow... reboot
    Hard to believe...
    5 minutes ago, cag014 said:
    Wow... reboot
    Hard to believe...
    are you kidding me?
    reboot is the solution for every IT problem....
    WHY, WHY I MOVED FROM HC2 TO HC3?
    Oops, have posted wrong file... sorry
    Just now, gggizmo said:
    are you kidding me?
    Hopefully next release will be stable.
    I'm stuck with few QA device crashing without any reason and when I try to make changes it shows
    So here is the debug window.
    [2020-10-06] [19:23:49] [TRACE] [AOQ3694]: 4.1jM{123} TGarden:420:Nagykapu sensor[false] => sendPush(Attila:[email protected],Noncsi:[email protected],) 'Nagykapu:','A nagykapu csukva.')
    The problem is true. My phone got the messages double. :(
    Bu using block scenes with the same combination works fine?
    Plaease try again Lua scene, but this time use users ID.
    fibaro.alert("push",{id,id}, "test")
    AOQ version 3.5 was O.K.
    After loading AOQ-mainCode-v4.0.txt:
    2. Shortcuts
    Compared to copy and paste same action table to different lines and when change required, going through the lines and make the change, a single shortcut shaves a moment off your task. Any table in the line could be defined as a shortcut.
    In user_data file of the QA at USER SHORTCUTS sections define as following:
    Where is user_data file of the QA at USER SHORTCUTS sections to be found? (Nothing about Shortcuts in AOQ Advanced User’s Guide v4.0)
    Edited by Rover
    6 hours ago, cag014 said:
    BTW the new version 4.0 is available at download center (including main code as a text file)
    Please note, two new parameters have been added
    maxScanTime = 555 -- max. time rate to scan devices in milliseconds when system is idle, range (100-900)
    slaveApiTime= 600 -- max. slave response time (milliseconds), warning shown if greater detected.
    Download Tips and Trick pdf. for more information
    It is not easily change mainCode by AOQ-mainCode-v4.0.txt. A lot has been changed in 4.0: Main and mainCode has been changed in user_data and Main (in reversed order). And in user_data (the old Main) is also a lot changed. Because changing mainCode by AOQ-mainCode-v4.0.txt delivers crahing system, I go back to v3.5.
    I have try it and it works... just copy the 4.0 into mainCode in your version.
    In your main you can  add line below, but it works without the those lines also.
    V4.0 crashes!
    Gone back to v3.5: OK
    Edited by Rover
    6 hours ago, Rover said:
    Hi @cag014,
    You just need to keep correct order between ' and " signs
    Your original command has 4 parameters. The number 80 is part of the command... you made it as a parameter of the table (in this case  makes it as a command delay)
    {"`SonosHub`", "+playFromCIFS,`SonosPlaybar`,[Mediacenter/d/SonosGeluiden/Deurbel.mp3]", 80"{&Huisstatus:value=Thuis}"}
    Now 3 parameters as you intended
    {"`SonosHub`", "+playFromCIFS,`SonosPlaybar`,[Mediacenter/d/SonosGeluiden/Deurbel.mp3], 80""{&Huisstatus:value=Thuis}"}
    Always keep in your mind that command and his parameters must  be one string.
    Edited by cag014
    25 minutes ago, Rover said:
    V4.0 crashes!
    Weird... works fine.. have tried again... even tried the same with 2.9...
    Did you copy the code into mainCode?
    As i understand you already have installed 4.0 QA ,so  just copy your jSlave, jS2n, jP2n and jM tables.
    Yes I copied the .txt code of v4.0 into maincode of v3.5. Result has been shown...
    Could you please do me a favor and try attached
    Edited by cag014
    Differences v3.5 vs v4.0:
    main titles changed content.
    v4.0 (not in v3.5):
    Works ?
    Edited by Rover
