54 minutes ago, cag014 said:
Makes sense ... when it's turned Off, I think &vmc = false, so the line is not executed due to lineState.
I the goal is to start at 7:30 and to stop at 14:00, why you need lineState?
Are you sure it works in AOS?
&vmc is a global var. I use it to make line active or inactive and is set manually via profiles or a qa.
so global var vmc is always active ( during fall and winter ventilation is active)
Hello cag014
Do you have any plans for slave dimmer switch?
    16 minutes ago, minsad79 said:
    Hello cag014
    You mean for emulation on HC3?
    Yes, work in progress...
    Have tested the line with same conditions and it works...
    2 hours ago, cag014 said:
    It's not new...
    ccordingly you can define true/false instead of tilde (at any combination)
    timeslot="true 05:00, false 07:00"
    timeslot="05:00 true, 07:00 false"
    Ah, true instead of tilde ?
    Why attaching an old All-in-One?
    4 hours ago, gggizmo said:
    {0,"$24clock",{lineState={"{&vmc:value=true}"},initOnStartup=false,timeSlot="07:30~",timeSlot="~14:00",trueAct={"`vmcs`","turnOn",""},falseAct={"`vmcs`","turnOff",""}}},
    What am i doing wrong?
    Goal is to start ventilation at 7:30 and stop at 14, but nothing happens at 7:30. Already checked: devices id. and global var. Except for initonstarup stamement it's the same line perfectly working on aos in hc2
    [08.10.2020] [07:24:36] [TRACE] [AOQ1385]: 4.1jM{5} GBedroom:931:remote camera[4.Pressed] => turnOff{lcamera)[08.10.2020] [07:25:57] [TRACE] [AOQ1385]: 4.1jM{27} Fbagno:444:porta bagno[false] => turnOn{stufabagno)[08.10.2020] [07:31:42] [TRACE] [AOQ1385]: 4.1jM{27} Tbagno:444:porta bagno[true] => turnOff{stufabagno)[08.10.2020] [07:54:01] [TRACE] [AOQ1385]: 4.1jM{26} Tt$24clock[07:54] => setGlobal,false{&luci_attive)
    oops, you have an error - double timeSlot.
    it should be
    timeSlot="07:30~,~14:00"
    You can see that on preview table in AOQ - only ~14:00 shown....
    I just press quote... it's automatically attached... ignore it
    It should work according to the state, there is no reference to day time at all.
    Like any simple line when value<80 trueAct executed, now when LUX will be > 80 next time when it goes again <80 trueAct executed. That's all.
    Are you sure that sometime LUX is actually > 80?
    Lux 80 was just for testing to be sure is was more than the actual lux. Normally I want to fire lights if lux<20.
    Yes the state had to be changed before new triggering and with lux value 20 it will. Nice to be remembered ?
    Good news...
    I'm looking forward
    Hi @cag014,
    You see that triggering lights on by lux works ?
    BTW: all these in post debug messages...
    If I select only Trace, then I miss real error debug notifications.
    1 minute ago, Rover said:
    Hi @cag014,
    Great
    You can select trace and error  only - or any other combination
    What about the HC3 Alarm Scenes: making a complete alarm scene or handle all alarms by AOQ?
    it should be
    yep..
    Another little help:
    how to turnoff vmc if windows is open for more than 15 mins..
    {0,"`finestraj`",{state="value=true",trueAct={"`vmcj`","turnOff","1800"}}},
    this line turn off vmc if windows is open after 15 min, but i need to check the time window stay opened
    {0,"`finestraj`",{state="value=true",trueAct={"`vmcj`","turnOff","1800","{finestraj:@lastsafe>1700 }"}}, something like this?
    Use timeSpan and timeoutAct, like that:
    {15,"`finestraj`",{state="value=true",timeoutAct={"`vmcj`","turnOff"}}},
    The idea when value=true, AOQ starts counting 15 (timeSpan) minutes. after 15 minutes timeoutAct executed.
    If in the middle of counting windows closed, the time counting stops and will restarted from 0 again when value=true.
    Please think what happens when window is closed after the  vmcj turned OFF, should be restarted?
    By the way you should see on hcWebEye red progress bar of time count (something like that)
    That's depends what you need to do... how complex your arm/disarm
    Post an example
    Edited by cag014
    Post an example
    Edited 13 minutes ago by cag014
    I mean the "scene" that should be activated when an alarm occurred by breaching.
    In HC3 you see under Alarm: Alarm Zones and Alarm Scenes. Do I have to put a scene in Alarm Scenes or can AOQ do the whole job of actions when alarm occurred without having a scene in Alarm Scenes?
    Post an example
    No, if windows stay opened for more than 20mins vmc must stay off, cause air exchange in the room has been done in the old style way...
    vmc force air exchange with virtually no loss in room temperature, but if someone at home choose to stay with window opened in winter....at last i want to save electricity
    OK... so it should be enough to close the vmc
    I think AOQ could do it, at least that what I do, send SMS , TTS message and and turning some light to show presence.
    By the the TTS message is the most important stuff for me. It sounds like someone at home.
    The message like HI, who is there...I'm coming ...and etc.
    Edited by cag014
    Is anyone have tried new HC3 version - 5.050.10
    Yep.me.
    at the Moment  no differencens with last beta.
    same cpu load, same delay.
    smooth update no problem al all.
    Just now, gggizmo said:
    Yep.me.
    6 hours ago, cag014 said:
    Great
    I should like to have this table not in debug but in trace mode
