    OK, now everything is clear, thanks.
    One question - when you're using SlaveSensor how fast it reacts on changes? I mean when you open door, how fast you see the slavesensor icon changes ?
    Looks like when too many SlaveSensor emulated, HC2 response slows down.
    Edited by cag014
    Let's try to optimize SlaveSensor
    Please download attached and copy/paste to Lua code of SlaveSensor...
    First try just see if it works correctly and then replace all of them
    It might be the easiest way first to concentrate at the SlaveSensor motionsensor, because it is a rather closed environment without arming/disarming issues.
    Only the LUA code of this SlaveSensor has been changed.
    Now I count about 10 seconds between moving myself before the sensor and light is getting on.
    This is after Lua code change?
    On my system it reacts less than 1 second.
    What about icon change on HC3 when you move before the sensor?
    Hi cag!
    Can you send me a code for the terminal? I use MacBook and the code is in your PDF, don't working the HC WebEye. :(
    Thanks!
    Edited by SmartLifeSystems
    Code of hcWebEye?
    It is java script code and not pdf
    3 minutes ago, cag014 said:
    Code of hcWebEye?
    No. I think what is in your HcWebEye user manual PDF. That's code should copy-paste to the terminal. Isn't it?
    Yes, after LUA code change.
    The icon on HC3 changes very fast when I move before the sensor, but then it takes about 10 seconds before lights on.
    Hope that's what you need
    For achieving the same on mac system, for chrome browser use the following command on terminal:
    open -n -a /Applications/Google\ Chrome.app --args --user-data-dir="/tmp/someFolderName" --disable-web-security
    So the command on HC3 executed fast, but HTTP to turn on light on HC2 takes time...?
    Can you turn ON other device which is on HC3, just to verify that the issue is communication to HC2
    Complicated:
    In the last version of SlaveSensor the icon has been vanished, so I cannot give that information.
    But besides of the 2 HC2 steered lights my only HC3 device (wallplug) is turned on and off with the other two.
    Result:
    • When I move before the sensor, after about 5 seconds the HC3 device is getting on and about 5 seconds later the HC2 steered lights are getting on.
    • When sensor is getting false, (maybe, I cannot verify with looking at icon) after about 5 seconds the HC3 device is getting off and about 5 seconds later (that is sure) the HC2 steered lights are getting off.
    Edited by Rover
    Guys, just for in formation:
    Cag the slaveSensor/switch is great!!
    20-25 slave devices import from HC2 into HC3
    HC2 is slowing down a fraction
    HC3 arming 7 zones( I dont have sensor in 2 zones there for I created a kind of common zone)
    HC3 respond fast on arming and breaching almost directly
    On HC3 AOS and toiletlight with HUE
    Unfortuannaly HC3 crashed so its now only HUE and two sensors.
    Awaiting Fibaro answer,
    //Sjakie
    Riddle:
    After days of good behavior Pushover do no function from AOQ, it does work from HC2 and from HC3 scene.
    1 hour ago, Rover said:
    Riddle:
    What? Did you updated the pushover QA. Looks like missing function Send_Pushover !???
    Can you see in QA QuickApp:Send_Pushover?
    How it works from HC2?
    Edited by cag014
    It has worked very good.
    Yeap, as I though it's now Send_pushOver
    2 hours ago, Rover said:
    Complicated:
    Result:
    I must say that HC2 is not really relaxed...
    What i did wrong?
    It's very confused, from one hand @Sjakie reports fast response with 20-25 slaves and in your case it takes 5 seconds just to identify state change...
    7 minutes ago, SmartLifeSystems said:
    What i did wrong?
    OK, i was the idiot. Working fine. :)
    Thanks your help!
    2 minutes ago, SmartLifeSystems said:
    What i did wrong?
    What i did wrong?
    Looks OK... this is Chrome, right?
    Could you try following solution...
    Thanks your help!
    Ok, I'll not ask...?
