9 hours ago, Rover said:
I made the mistake of rebooting HC2 tonight. The alarm was initiated and the siren could not be stopped ?. The WAF is below sea level (not only because we are living below sea level) ?
But the HC2 is somewhat more relaxed, but still with periods of 100% CPU load, because of what??? Besides of being slave of HC3 the HC2 has nothing to do...
The response times of HC2 motionsensor into light did not improve.
Thats a pitty.
Sometimes HC2 is doing something. I see that also nothing going on in my opinion and CPU goes up but here not 100%. Only within 3-5 min after reboot/backup.
Reboot HC2 and than it will go 20% with peak 40-70% if some stuff need to be done
/monthly_2020_10/image.png.9617a9865e52e0442ea61cbeee2e6657.png" />
//Sjakie
6 hours ago, cag014 said:
Let's try to measure the response time for API GET, PUT and POST
Attached version has these results... at the end of the table.
@AR27690
Please use this version also. Stable while slave controller has network problems, but notice if you have connection problem do not restart AOQ till problem solved. AOQ will continue to perform all actions (except where no connection), but if you will restarted, AOQ unable to load device data and will stop.
v4.6 crashes, going back to v4.5.
I see now that I have missed v4.5. Before I had run v4.4.
But in v4.5 the SlaveSensor motionsensor reacts not at all (but the <device>'hc2 motionsensor works), so going back to v4.4. Still no reacting SlaveSensor motionsensor ?!?
I added missing icon to SlaveSensor motionsensor: there is light again.
Again to v4.5: "working" SlaveSensor motionsensor, with the same delays.
Edited by Rover
On 10/15/2020 at 1:04 AM, cag014 said:
In addition at end of the table slave controllers status is shown, including response time (last response time and max. response time) and if slow response identified (checked every 5 min) warning displayed.
works ?
Edited by Rover
    You have probably most complicated configuration.... which finds every "tiny" bug.
    Here an update
    Here an update
    IP 10.0.0.69 ???
    22 minutes ago, Rover said:
    Ooops, did it to debug your previous bug...
    Worked well on first 4.6 release.
    Any how downloaded that one also.
    Have disconnected the internet and it's stable.... and when connect internet back, actions executed per updated states and system backs online.
    The AND relation is not developed well, it behaves like an OR relation.
    41 minutes ago, Rover said:
    IP of HC2 is correct now, with getTime 0.02.
    Does this information help?
    I'm interesting to see postTime and putTime.... these the actions sent to slave.
    9 minutes ago, Rover said:
    That's not the format...
    {condition and condition...} or (condition and condition....}
    Not
    {condition...} and {condition....}
    Edited by cag014
    After moving in front of the SlaveSensor motionsensor.
    Edited by Rover
    Not
    Then how to code ((A or B) and C)?
    (A and C) or (B and C)
    This format easier to view and understand ( per correct programming guide)
    Don't know exactly what the line does, but you can do it also
    lineState="{ if C....}"
    then in actions
    {A} or {B}
    Edited by cag014
    then in actions
    {A} or {B}
    The issue is that using the Button Hold button on a switch the Hold (3) as well as the Release (5) trigger is initiated. I have a lot of actions, so filtering in actions is too cumbersome. That is why I want to put the filter in the lineState.
    Twice higher than in my system
    Edited by Rover
    19 minutes ago, Rover said:
    Reporting of the moment:
    Icon SlaveSensor motionsensor on: HC3 wall switch on at once, HC2 lights 12 seconds delay.
    Icon SlaveSensor motionsensor off: HC3 wall switch off at once, HC2 lights 7 seconds delay.
    How many lights you're turning on /off - is it a list of lights?
    Base on your postTime it takes one second to turn one light, so if you have a list of them the last light will be activated seconds after....
    Two HC2 lights: Schilderijspot and SpotsTrapOverloop.
    So maximum 2 seconds to activate... unless HC2 has some delay inside...or HC3
    Few tests:
    When icons changes on HC3, how fast turnOn action appears on HC3 debug window?
    What happens when you turn the light from GUI of HC2?
    Could you post jM line of that action
