32 minutes ago, cag014 said:
Yeap, as I though it's now Send_pushOver
cag has the eyes of an owl ?
    Almost, typo error Send_PushOver
    59 minutes ago, cag014 said:
    It's very confused, from one hand @Sjakie reports fast response with 20-25 slaves and in your case it takes 5 seconds just to identify state change...
    Yes but I am talking only HC3 I didt check what happend on HC2.
    I was focussed on HC3 to get the job done there.
    Goal is to replace HC2 with HC3 or shall I say a dream?
    Sorry I cant go back I did a factory restore.
    //Sjakie
    //Sjakie
    Exactly, slavesensors on your HC3 react fast, while on @Rover HC3 it takes 5 seconds!
    Guys, with the new slavesensor.LUA
    I imported one door sensor aswell in HC2 and HC3 1 sec (manual counting).
    Let me import also a motion sensor to compare.
    //Sjakie
    Could it be useful to reboot HC2 and/or HC3?
    If you ask me Yes!
    I do it often if I otice they become slower whats the uptime?
    //Sjakie
    motion sensor instant reaction
    wall plug on icon change on HC2
    //Sjakie
    21 minutes ago, Sjakie said:
    If you ask me Yes!
    //Sjakie
    //Sjakie
    HC3 uptime: 6 days
    Where can I find the uptime of HC2?
    general information
    Its not so long.
    I check before changing something what the CPU usage and Mem is
    In my case 20% basic with as general piek 40% if HC2 is working very hard I see 60/70 %  Memory 14%
    If thats okay I make a new backup afterchanging if not I restore or restart HC
    make changes and backup again.
    //Sjakie
    1 minute ago, Sjakie said:
    general information
    I only see the server status of 12d, 22h, but I think it must be since the last backup to version 4.560 at 2019-11-16.
    Server status is uptime
    Reboot will make HC2 faster I think
    //Sjakie
    //Sjakie
    Will update of HC2 to 4.600 have a risk of problems?
    I should do one thing at a time.
    Reboot see if that sloves
    //Sjakie
    May I ask what your table refresh time, did you change it?
    Defined in AOQ parameters table
    tblRefresh  = 180 --(seconds) table view refresh rate min 120 seconds.
    This is the refresh time as specified in one of the early versions of AOQ. I never have changed it.
    //Sjakie
    I made the mistake of rebooting HC2 tonight. The alarm was initiated and the siren could not be stopped ?. The WAF is below sea level (not only because we are living below sea level) ?
    But the HC2 is somewhat more relaxed, but still with periods of 100% CPU load, because of what??? Besides of being slave of HC3 the HC2 has nothing to do...
    The response times of HC2 motionsensor into light did not improve.
    Edited by Rover
    Changing refresh time of 60 to 180 seconds enlarged the response time of motionsensor to lights: HC3 device 5 sec. --> 8 sec. and HC2 devices 10 --> 16 sec.
    No way... it's just table printout... every 180 seconds!
    New measurement: response times had not changed, resp. 5 and 10 seconds.
    Let's try to measure the response time for API GET, PUT and POST
    Attached version has these results... at the end of the table.
    @AR27690
    Please use this version also. Stable while slave controller has network problems, but notice if you have connection problem do not restart AOQ till problem solved. AOQ will continue to perform all actions (except where no connection), but if you will restarted, AOQ unable to load device data and will stop.
    Edited by cag014
