2 hours ago, cag014 said:
Is anyone have tried new HC3 version - 5.050.10
I install now. :)
Alarm not defined in Fibaro D/W sensor  (SlaveSensor.fqa)?
Edited by Rover
    12 hours ago, minsad79 said:
    Good news...
    I'm looking forward
    Attached SlaveDimmer QA
    Please notice the dimmer emulation does not support scene activation.
    Edited by cag014
    It work in state only... bug.. fixed
    Try attached
    Edited by cag014
    Hello cag014
    Applied slave dimmer qa
    Works exactly without errors
    Thank you for your hard work and contribution
    It would be nice if RGBW slaves were added later.
    1 hour ago, minsad79 said:
    Hello cag014
    RGBW a little bit tricky to show the color bar...
    Meanwhile SlaveDimmer can work on RGBW, but w/o color changes. (on, off and level are the same)
    Edited by cag014
    Thanks for Slave devices... it just works great for mobile application... I can run only one Home Center app. on my phone and control HC3, HC2 and HCL. No need for Fibaro old app.
    By the way following your suggestion to control HCL over internet, it does the work... at least my mother has some kind of smart home during these dark days (COVID-19). For last ~3 months she closed at home.
    Thanks...
    Will rate your application in download center later... it helps to others to find it quickly.
    Edited by AR27690
    Tricky task
    But I think you canI live in koreaI support you in a far country
    cag14, just another newbie question:
    what's the syntax to call a qa function with argument?
    same as any Zwave call, except you need + before command because it not listed in QA properties.
    ("QAID","+<cmd>,arg,arg,arg,..."}
    where the command is actually the name of QuickApp function inside QA.
    Edited by cag014
    ok, so i can use same hue lamp syntax
    ex.
    {"`fstufa`","+changeBrightness,255",""}
    ex.
    Yep...
    It looks like a not functioning of timeSlot in HC3 version 5.050.10:
    Indeed... this version back again to treat true/false as normal...
    Made change to cover all versions so far...
    If I install v4.3, is timeSlot then working again?
    Yes...
    Cag what kind of issue are you talking about?
    I reading back previuos post in forum but i can't find it
    Interesting:
    I got an email "HC3 off line". So internet works otherwise I could not get an email, but internet light on HC3 box was red, while internet light on HC2 box was green. This took 5 minutes.
    What is going on here (HC3 version 5.050.10) ???
    New update? It was quickly. 5.050.13
    Edited by SmartLifeSystems
    The issue was when using in timeSlot true instead of tilde.  "true 14:00" instead "14:00~". Interesting that false works.
