1 minute ago, cag014 said:
Are you sure? Have tested that and it triggered only when state is changed. Not every value above 25
not tested in the last days but i'm pretty sure that with hc2 and first version of aoq in hc3 line worked that way.
And just a clarification, how the state is saved? Isn't cheched at every report?
    trueAct and falseAct triggered only on status change.
    trigAct triggered on value changes. Means every different value report, it's triggered regardless status
    when trigAll set to true then trigAct triggered on every value report, even if the value is the same as previous.
    No other options....
    Edited by cag014
    Better you remove me from mentions in forum download:-(
    shame on me...
    Hi cag014
    First of all thank you for AOQ, does better job than block scenes. (I'm not so familiar with Lua programming)
    I have a question - I want to set my old HCL at my mother home, can I control it for HC3 using slave option?
    shame on me...
    No at all... you did help to debug the code and some of yours remarks are implemented in AOQ.
    7 minutes ago, AR27690 said:
    Hi cag014
    Hi
    Yes, you can control remote HCL (make sure you have an access over internet and to make it stable a fixed IP required)
    Two observation:
    1. In case internet is down, HCL won't work from HC3. I suggest some critical actions should be implemented directly in HCL block scenes (like alarms)
    2. I suggest to run second AOQ on HC3 which is dedicated to HCL, otherwise it can slow down your AOQ due to internet connection and in case your mother's internet is down your AOQ will be almost dead (unless you'll remove HCL from slaves list)
    Hope this is understandable and makes any sense to you.
    12 minutes ago, cag014 said:
    Hi
    Two observation:
    Thanks.. will follow your suggestions.
    7 hours ago, cag014 said:
    Do you need to trigger the line on every LUX  change ?
    No, I want to trigger one time between 15:00 and 22:00, but next day (and every day) I want again to trigger one time between 15:00 and 22:00.
    Does
    will do this job (every day)?
    The scenario is:
    • If it is getting darker (>20 lux) from 15:00 (till 22:00) then put all lights on.
    • If lights not on yet at 1 hour before sunset, then put all lights on.
    • By button on scenemaster or keyfobs: put all lights on.
    So not only lux measurement is the trigger but more types of triggering.
    That is why my idea is to set a global variable at a number of ways in order to trigger the lights on by these global.
    Better idea?
    Edited by Rover
    8 hours ago, gggizmo said:
    Please can you share infos about pir device and post debug screen?
    I use a similar line and it' works as expected. My line it's temp triggered but i think it's same concept
    The PIR is a Fibaro motion sensor.
    For temperature settings see parameters 60, 62, 64
    22 hours ago, cag014 said:
    I think you can try  a new idea by using old smartphone (with unique email account) connected to local wifi  and in case no internet, to send email to this smartphone and to forward the message to your email account.
    How can I send email to a smartphone only connected to local wifi (without using the email server of the email provider by internet)?
    Does
    That's what I thought
     So why need global variable for? You can do it in two lines only
    {0,"`lux`",{state="value<20",timeSlot="15:00~22:00, true?$sunsetHour-3600?",trueAct={"`lights`","turnOn"," if {`lights`:value=false}"}}},
    As an example using sceneActivation
    {0,"`keyFob`",{state="sceneActivation=1" ,trueAct={"`lights`","turnOn"," if {`lights`:value=false}"}}},
    Please keep in your mind that actions by timestamp are always triggered at time, regardless the state status
    Edited by cag014
    Yes, the implementation is the tricky part, you need to receive email on WiFi and send it on cellular... phone setup doesn't have that by default
    That's exactly what I have answered, the tricky part
    @Rover
    I don't if you are using another button on keyFob to turn OFF,  but you can use same button to turn lights On / Off.
    {0,"`keyFob`",{state="sceneActivation=1" ,trueAct={"`lights`","turnOn;else;turnOff"," if {`lights`:value=false}"}}},
    {0,"$24clock",{lineState={"{&vmc:value=true}"},initOnStartup=false,timeSlot="07:30~",timeSlot="~14:00",trueAct={"`vmcs`","turnOn",""},falseAct={"`vmcs`","turnOff",""}}},
    What am i doing wrong?
    Goal is to start ventilation at 7:30 and stop at 14, but nothing happens at 7:30. Already checked: devices id. and global var. Except for initonstarup stamement it's the same line perfectly working on aos in hc2
    [08.10.2020] [07:24:36] [TRACE] [AOQ1385]: 4.1jM{5} GBedroom:931:remote camera[4.Pressed] => turnOff{lcamera)[08.10.2020] [07:25:57] [TRACE] [AOQ1385]: 4.1jM{27} Fbagno:444:porta bagno[false] => turnOn{stufabagno)[08.10.2020] [07:31:42] [TRACE] [AOQ1385]: 4.1jM{27} Tbagno:444:porta bagno[true] => turnOff{stufabagno)[08.10.2020] [07:54:01] [TRACE] [AOQ1385]: 4.1jM{26} Tt$24clock[07:54] => setGlobal,false{&luci_attive)
    This true<time> is new for me, also not to be found in the recent Advanced User's Guide v4.0...
    The only issue is that it is not a simple turnOn but a longer conditional line:
    But of course I could use the new feature Shortcuts to use this line at several places in the trueAct.
    This line does not trigger anymore the next day (timeSlot not yet present for testing purposes):
    Why should your AOQ line will do it each day?
    It's not new...
    ccordingly you can define true/false instead of tilde (at any combination)
    timeslot="true 05:00, false 07:00"
    timeslot="05:00 true, 07:00 false"
    It should work according to the state, there is no reference to day time at all.
    Like any simple line when value<80 trueAct executed, now when LUX will be > 80 next time when it goes again <80 trueAct executed. That's all.
    Are you sure that sometime LUX is actually > 80?
    Makes sense ... when it's turned Off, I think &vmc = false, so the line is not executed due to lineState.
    I the goal is to start at 7:30 and to stop at 14:00, why you need lineState?
    Are you sure it works in AOS?
