9 minutes ago, cag014 said:
For the switches that's OK, because you need different condition value=false and not value=0
For the dimmer, that's strange! For 11 seconds the status not updated??? So the dimmer was always on?
To me it sounds like the condition for the dimmer is wrong also? Is it the same `DimmerHall` that you tested before?
Now 15 seconds with HC2 switch 212'hc2.
       Yes, the dimmer was always on.
   HalDimmer  is the QA Slave device I tested before, DimmerHal is the <device>'hc2  device, both tested before.
15 minutes ago, cag014 said:
Please change the line of $blank back to ON/OFF, it makes the line generic for all dimmers/switches (no specific conditions)
{0,"$blank",{trueAct={{"`HalDimmer`","turnOn"},{"`HalDimmer`","turnOff","1"}}}},
and set {"$blank>2","rptAction,3,1","trueAct")
11 seconds, we are making progress!
Just the question why 1 second delay turns out to be 2 seconds.
    I see one of them turns to 4 seconds delay!
    I'm running in the loop same scenario for last 5 hours and no unexpected delays over 1 second.
    My guess something slows down the execution in HC3...
    Could you please reboot HC3?
    After reboot:
    2x AOQ on Edge and 2x AOQ on Firefox
    Edited by Rover
    24 minutes ago, Rover said:
    After reboot:
    What do you mean by 2x on Edge and 2x AOQ on Firefox? do you mean you run 4 x AOQ?
    Sorry for my fake news.
    No , that is not the case: 1x Edge for editing, 1x Edge for debug screen, 1x Firefox for HC-WebEye.
    On 9/30/2020 at 7:18 PM, SmartLifeSystems said:
    Is it rue the sendPush and sendiPush too.
    Here is an example. My phone got the notoifications 2 times. If i don't set the ID413, got the notifications the 2 phones normally.
    {0, "$DayArmed",{state="value=armed",trueAct={"Satel Integra:","sendPush,3370,413","A riasztó nappali élesítése aktív."}}},
    I still trying to find the reason for that, but w/o success
    Could you please post snapshot of debug window where this command shown?
    May be another solution can help you, when you need to send push to both numbers use just "sendPush" w/o IDs. AOQ by default sends push to all users in the system. Only when you need to send to specific user, then use ID in sendPush
    BTW - did you mange to set temperature in zones?
    Edited by cag014
    OK, finally this is the latest version which I'll post today in forum's download
    What has been changed in v3.5?
    Yes, I use the Climate panel.
    I saw the link, what you sent me, but my phone settings is correctly.
    If I set only the ID413 phone in the line, the messages arrive correctly, but the ID3370 phone gets then as well.
    Only the ID3370 phone gets the messages doubled.
    If I use the following settings, the messages are sent to both off the phones.
    pushNote    = {false,"3370"}  -- if true, alerts interactive push notification will send
    If I use the following settings, the messages are also sent to both phones but the ID3370 gets then doubled.
    pushNote    = {false,"3370,413"}  -- if true, alerts interactive push notification will send
    So I can not achieve that only one phone receives acertain messages.
    Thanks!
    Example the line:
    {0, "`garageDS`",{state="value=true",trueAct={"Garázsajtó:","sendPush,413","A garázsajtó nyitva."}}},
    The debug window:
    [2020-10-04] [11:24:17] [TRACE] [AOQ3694]: 3.5jM{122} TGarage:421:Garage door sensor[true] => sendPush,413(Noémi iPhone-ja,) 'Garázsajtó:','A garázsajtó nyitva.')
    But the message is received by the ID3370 phone too.
    Edited by SmartLifeSystems
    Hi @cag014
    Could you please change this or-relation to work?
    Edited by Rover
    1 hour ago, Rover said:
    Hi @cag014
    Will see what can be done.
    Meanwhile if you can "replace" 35 by 34, you can use range definition
    state="sceneActivation=32~35" means 33and 34 are in range and will be executed.
    or
    sceneActivation=32~36 and use lineState to exclude 34
    Edited by cag014
    @Rover
    On second thought, that option already exists
    {0,"`VoordeurSwitch`",{lineState={" if {`VoordeurSwitch`:sceneActivation=33} or {`VoordeurSwitch`:sceneActivation=35},
    initOnStartup=false,state="sceneActivation=30~40",trueAct={....
    Hi cag!
    How can you setting this?
    If I push a button before I leave the house and somewhere the window or door is open, then the AOQ send to me a messages.
    Now I use the next line, but don't work correctly for me.
    {0.5, "{`kisszobaAblak`}{`bedroomWindow`}{`storeroomDoor`}{`storeroomWindow`}{`livingroomDoor`}{`livingroomWindow3`}{`balconyDoor`}{`livingroomWindow2`}{`livingroomWindow`}{`hallWindow`}",{state="value=true",timeLoopAct={"Satel Integra:","sendPush","$name in the $room is open. Please close it, before you leave the house!"}}},
    This is the way to send push if any sensor is breached:
    {0,"`pushButton`,{state="sceneActivation=1",trueAct={"Satel Integra","sendPush","Sensor breached - please close it, before you leave the house!",
    "{`kisszobaAblak`:value=true}{`bedroomWindow`:value=true}{`storeroomDoor`:value=true}{`storeroomWindow`:value=true}{`livingroomDoor`:value=true}{`livingroomWindow3`:value=true}{`balconyDoor`:value=true}{`livingroomWindow2`:value=true}{`livingroomWindow`:value=true}{`hallWindow`:value=true}"}}},
    To send what is breached, not an easy option. If these sensors already in AOQ, then you can update variable.
    If not then to send the list of all of them like that
    trueAct={"Satel Integra","sendPush","Sensor breached: kisszobaAblak= @`kisszobaAblak`>value, bedroomWindow=@`bedroomWindow`>value,  storeroomDoor=@`storeroomDoor`>value, storeroomWindow=@`storeroomWindow`>value, livingroomDoor=@`livingroomDoor`>value, livingroomWindow3=@`livingroomWindow3`>value, livingroomWindow=@`livingroomWindow`>value, hallWindow=@`livingroohallWindow`>value, close before you leave the house!", "{`kisszobaAblak`:value=true}{`bedroomWindow`:value=true}{`storeroomDoor`:value=true}{`storeroomWindow`:value=true} {`livingroomDoor`:value=true} {`livingroomWindow3`:value=true} {`balconyDoor`:value=true}{`livingroomWindow2`:value=true}{`livingroomWindow`:value=true}{`hallWindow`:value=true}"}}},
    You should rceive for each sensor value 0 or 1. If value=1 means breached.
    Of course you can make a line for each sensor and send only the sensors that breached.
    {0,"`pushButton`,{state="sceneActivation=1",trueAct={"Satel Integra","sendPush","kisszobaAblak is open, please close before you leave the house!","{`kisszobaAblak`:value=true}"}}},
    {0,"`pushButton`,{state="sceneActivation=1",trueAct={"Satel Integra","sendPush","bedroomWindowis open, please close before you leave the house!",
    "{`bedroomWindow`:value=true}"}}},
    Edited by cag014
    May I ask you to test that with HC3 block scene?
    Just create a block scene with push notification (you can choose any combination there) and run it. When you run it manually  It should be executed regardless the trigger.
    Let's see how many notification you receive....
    Edited by cag014
    To all,
    I don't know if you're aware about emitEvent option in HC3.
    It could be used instead of some variables and to trigger Lua/block scenes.
    Thanks your help. I will try tomorrow and i will tell you how working.
    1 hour ago, SmartLifeSystems said:
    OK, I tried this in block scene and working correctly.
    At any combination?
    8 hours ago, cag014 said:
    At any combination?
    Yes, every combination.
