    Hope that is the last one
    All bug fixed
    @Rover
    For sonos player use below (since  parameter has calculation sign "/" it should be in square brackets)
    {"115", "playFromCIFS,[Mediacenter/d/SonosGeluiden/Deurbel.mp3]"}
    Edited by cag014
    another stupid question:
    Do you know any way to avoid increase of device or scene or qa id after every reconfiguration or after an update  for example of aoq?
    My system was migrated from hc2, i reconfigured every single devices 3 times to identify high cpu load , and now i have devices with id starting from 1500...and aoq also,with a new release almost every day id increases.
    I don't know if all of this may have an impact on system...
    Wierd interface label looks related to chrome...everything it's ok in firefox and edge
    7 hours ago, SmartLifeSystems said:
    Hi cag! I have got a problem, what i don't understand. We have got 2 iPhone, and the Push notes my phone got double. My  wife's phone no.
    The 3370 is my phone, the 413 is my wife's phone.
    Will take a look on that... all my family with iPhone (6), except me... as my wife said is too expensive for me....
    Edited by cag014
    The ID numbers are not important at all, just annoying...
    Next time I'll post QA and text file with Lua mainCode that could be copy-paste into exist AOQ. I think it's even better, since you always need to update user data.
    Perfetc.tnx
    All bug fixed
    @Rover
    Edited 3 hours ago by cag014
    Yeah, that is better!
    Now I install the last AOQ QA and copy the mainCode in the old one. Then I delete the last one. Again a device ID richer...
    1 minute ago, Rover said:
    As I mentioned if the QA hasn't include this command use +
    {"115", "+playFromCIFS,[Mediacenter/d/SonosGeluiden/Deurbel.mp3]"}
    @cag014,
    You are working on AOQ day and night ?.
    What time is it now at your place?
    Edited by Rover
    I want to finish that once for all....
    Yes, that works! I had forgotten that ?
    11:45
    But keep healthy ?
    Great... I believe this is your TTS system...right?
    Edited by cag014
    No, it is just our Sonos system, what except for music also is used for doorbell and alarm mp3 messages.
    I did not thought about using it for TTS. How can you do this?
    Not exactly the right sequence...
    42 minutes ago, Rover said:
    It's not exactly TTS, but as you did with the alarm, some specific announcement could be played.
    Some user (don't remember the name) has recorded words and by playing right sequence created a sentence....
    I prefer the android TTS solution
    31 minutes ago, cag014 said:
    As I said, the timing is the problem...  3 seconds should work.... (turnON and OFF on the same time)
    And the iOS TTS solution = ?
    iOS not so simple.
    But I'm using 2 cheap android tablets (living room and bedroom) for TTS and Fibaro app on them.
    How to use a local variable as parameter?
    Arming, disarming, verify, okAct: WORKS ?
    Still not as it should be:
    Edited by Rover
    1 hour ago, Rover said:
    Try that one - tested and works
    Attached txt file of mainCode.
    Opened an copy-paste to mainCode in AOQ
