    OK.. I think all bus are fixed.... okAct{}, rptAction, Bad file descriptor  and initonStartup
    Attached version has additional cosmetic improvements:
    In time slot you'll see now true/false superscript instead of tilde ~ (on time based actions)
    Accordingly you can define true/false instead of tilde (at any combination)
    timeslot="true 05:00, false 07:00"
    timeslot="05:00 true, 07:00 false"
    Edited by cag014
    Hi @cag014,
    In a HC3 scene this SonosPlayer QA (from Tinman) can be called as
    How to call it in AOQ?
    1 minute ago, Rover said:
    Hi @cag014,
    exactly the same
    {"115", "playFromCIFS","Mediacenter/d/SonosGeluiden/Deurbel.mp3"}
    in case playFromCIFS not recognized use +
    {"115", "+playFromCIFS","Mediacenter/d/SonosGeluiden/Deurbel.mp3"}
    @Rover
    Please pay attention to correct timing when you use rptAction
    you have delay of 1 second between turnOn and turnOff, so I think using one second delay in rptAction is wrong. It will immediately turnOn after turnOff.
    To create delay of 1 second between turnOff to turnOn set rptAction,3,2 (at least)
    2 minutes ago, cag014 said:
    @Rover
    OK, so "delay between in seconds" is total time of actions to repeat. This can be made clear in the new guide.?
    Yes, this is the delay between repetitions...
    14 minutes ago, cag014 said:
    exactly the same
    3 minutes ago, Rover said:
    Ooops, my bad
    {"115", "playFromCIFS,Mediacenter/d/SonosGeluiden/Deurbel.mp3"}
    what you see on debug window ?
    What I showed to you...
    I mean how looks the command sent by AOQ on debug window
    On second thought it should fail on checker ...
    Which command? I have commented all lines related to "Deurbel" out.
    I mean the sonos player
    It should fail on checker
    All this commented out.
    Made active again.
    As I thought... will fix it..
    This is a new issue in this code with the last AOQ version. It worked alright in the last weeks.
    Hi cag! I have got a problem, what i don't understand. We have got 2 iPhone, and the Push notes my phone got double. My  wife's phone no.
    The 3370 is my phone, the 413 is my wife's phone.
    My settings is here:
    pushNote    = {true,"3370,413"}  -- if true, alerts interactive push notification will send
    If i use the next settings, working correctly, and on the 2 phones arrive the messages normaly. But I can't set that only one phone got the message. What did i do wrong? This problem i experinced on the HC2 AOS too.
    pushNote    = {false,"3370"}  -- if true, alerts interactive push notification will send
    Edited by SmartLifeSystems
