    2 hours ago, Rover said:
    What do you mean by immediately? The alarm arm/disarm actions takes over one second in HC3. I think this is the most slowest action in HC3.
    The idea to create verify solution in AOQ came because of that.
    If you remember, before using verify option you've struggled with delays to verify alarm state...
    Edited by cag014
    4 hours ago, gggizmo said:
    Again a little help
    {0,"$24clock",{state="value=05:00",lineState={"{&heating:value=true}"},timeSlot="~07:00",trueAct={"`caldaia`","turnOn",""},falseAct={"`caldaia`","turnOff",""}}},
    {0,"$24clock",{state="value=07:30",lineState={"{&vmc:value=true}"},timeSlot="~14:00",trueAct={"`vmcs`","turnOn",""},falseAct={"`vmcs`","turnOff",""}}},
    these lines are supposed to turnon at time and turnoff at the end of timeslot...but they don't work. What am i doing worng?
    Not exactly... let's see the first line:
    At 05:00 it will turn On the caldaia, but on minute later it will be turned OFF. The state of value=05:00 becomes false and falseAct{} executed.
    Try that:
    {0,"$24clock",{lineState={"{&heating:value=true}"},timeSlot="05:00~,~07:00",trueAct={"`caldaia`","turnOn",""},falseAct={"`caldaia`","turnOff",""}}},
    Now there is no false/true state. trueAct{} executed at 05:00 and falseAct{} at 07:00.
    Same for the second line
    I mean: does this line with verification sign (!), but without okAct or errAct, also retry if disarming was not succeeded?
    Yes arm/disarm actions takes many seconds. Therefor I like a construction that the arming/disarming is repeated until success.
    Question was whether this repeat happens with "!" also without okAct or errAct.
    Yes, it works w/o okAct{} or errAct{}.
    You can see that on debug window.
    In case verification failed, an error message printed on debug window and error popups on HC3 UI and  hcWebEye as well. (The error sent to TTS also, so If you have updated TTS in AOQ you should hear warning message)
    I considered to send notification to user, but it can be very annoying.
     Now testing again an alarm zone with 1 device (your new emulated sensor, indeed to be included in alarm zone).
    Yes indeed, and with errAct I can send f.i. an email.
    Edited by Rover
    The verification runs in back ground and I don't see a problem that meanwhile another action executed.
    Looks like verification shows fail even when  the conditions are OK.
    So it continues to run in loop and crashes?
    Please post your jM table
    Edited by cag014
    Hi @cag014,
    Another curious thing:
    Test your rptAction:
        - If arming the house at a certain moment when arming has succeeded (in HC2 by a while loop) then buzzer and push message let me know that arming was successful. I do not want a message later on that the arming was not successful. The same for disarming: I do not want to open the entrance door before knowing that the disarming is successfully ready.
       - No, first verification shows fail, because the disarming was not ready yet, the repeated verification after 3 seconds shows that disarming is ready. (How many repeats can be done if disarming takes longer? I think disarming for all sensors take minimal 15 seconds.)
       - Yes indeed, when okAct is part of the active code.
    Edited by Rover
    Try that:
    $24clock or $Blank is the same for those lines?
    and i suppose that in this line false act never be esecuted
    {0,"`tlaura`|`tjacopo`",{state="value<18",lineState={"{&heating:value=true}"},timeSlot="16:30~21:55,~22:00",trueAct={"`caldaia`","turnOn",""},falseAct={"`caldaia`","turnOff",""}}},
    171 and 169 are Schilderijspot and SpotsTrapOverloop.
    Bad file descriptor?
    It's normal in last beta?
    /monthly_2020_09/image.png.4c4bcfdb0049fc536ba0b91387b0f120.png" />
    What beta version?
    8 minutes ago, cag014 said:
    What beta version?
    5.041
    another question:
    {0,"$24clock",{lineState={"{&vmc:value=true}"},timeSlot="07:30~",timeSlot="~14:00",trueAct={"`vmcs`","turnOn",""},falseAct={"`vmcs`","turnOff",""}}},
    {0,"$blank",{timeSlot="?$sunriseHour+1800?~,~?$sunsetHour-1800?",trueAct={"&luci_attive","setGlobal","false"},falseAct={"&luci_attive","setGlobal","true"}}},
    about 15 mins ago i installed the new beta.
    and devices vmcs was turned on after reboot
    and global var set to false.
    Why? what i missed? Do i need to set something in oninit?
    10 minutes ago, gggizmo said:
    5.041
    another question:
    Yes, on Startup AOQ initialize every line.
    Please insert initOnStartup=false
    {0,"$24clock",{lineState={"{&vmc:value=true}"},initOnStartup=false, timeSlot="07:30~",timeSlot="~14:00",trueAct={"`vmcs`","turnOn",""},falseAct={"`vmcs`","turnOff",""}}},
    {0,"$24clock",{initOnStartup=false,timeSlot="?$sunriseHour+1800?~,~?$sunsetHour-1800?",trueAct={"&luci_attive","setGlobal","false"},falseAct={"&luci_attive","setGlobal","true"}}},
    why global var is set on false on every reboot or reinit of aoq?
    even if you reboot after sunsetHour?
    yes.
    Do you have same weird interface in last beta?
    yes.
    Looks like scenes.sceneDashboard.sceneTile.log.never
    is shown ultil scene is triggered
    22 minutes ago, gggizmo said:
    yes.
    No... I'm on 5.041.50 (beta)
    yes.
    Could you post your debug window of AOQ startup... I mean from "Gathering system... " and before the table shown
    it's same version.5.041.50...notified to me today at 6pm.
    [28.09.2020] [22:10:04] [DEBUG] [QUICKAPP1257]: Irrigazione Inattiva[28.09.2020] [22:10:04] [DEBUG] [QUICKAPP1256]: Vmc Attiva[28.09.2020] [22:10:04] [DEBUG] [QUICKAPP1259]: riscaldamento inattivo[28.09.2020] [22:10:04] [DEBUG] [QUICKAPP1258]: Condizionatore Inattivo[28.09.2020] [22:10:06] [DEBUG] [AOQ1354]: 2.96Gathering information...5264[28.09.2020] [22:10:07] [DEBUG] [AOQ1354]: hcl: Hcl_garden HCL-027231...[28.09.2020] [22:10:07] [DEBUG] [AOQ1354]: local: HC3-00003585 HC3-00004002...[28.09.2020] [22:10:09] [DEBUG] [AOQ1354]: 2.96Initializing jS2n{}, jP2n{}, global and userKeyWord{} tables...[28.09.2020] [22:10:10] [DEBUG] [AOQ1354]: Global not defined. Local variables ("onState" "my_Var") won't be saved for next run...[28.09.2020] [22:10:10] [DEBUG] [AOQ1354]: Global not defined. Reminders won't be saved for next run...[28.09.2020] [22:10:10] [DEBUG] [AOQ1354]: 2.96Parsing jM[31] hash table data... <6 sec.[28.09.2020] [22:10:13] [DEBUG] [AOQ1354]: 2.96Initializing devices state...[28.09.2020] [22:10:17] [TRACE] [AOQ1354]: 2.96jM{27} Itbagno:444:porta bagno[true] => turnOff{stufabagno)[28.09.2020] [22:10:19] [DEBUG] [AOQ1354]: 2.96Data validation in progress...[28.09.2020] [22:10:19] [DEBUG] [AOQ1354]: 2.96Arranging data table... <10 sec.[28.09.2020] [22:10:25] [DEBUG] [AOQ1354]: 28-Sep 22:10 AOQ2.96 All-in-One    ? O O ? O ? ? ?    sunHours 07:12~19:03
    Type Item Description Value Criteria in State TimeSpan Time Slot trueAct falseAct trigAct timeoutAct timeLoopAct initAct Active Rules jM{#} jM { hash table line }
    Z.Dev
    Bedroom:931:remote camera
    TBR centralSceneSupport=dummy 00:00:08 Activity       turnOffsetValue         >5 {0, "`rcamera`"...}
    Giardino:59'hcl:linea destra false value=true 00:00:08 Activity   turnOn turnOff       turnOff lineState >19 {0, "`lineadx`|`lineasxt`|`lineasxb`|`lineacx`"...}
    Giardino:60'hcl:linea centrale false value=true 00:00:08 Activity   turnOn turnOff       turnOff lineState >19 {0, "`lineadx`|`lineasxt`|`lineasxb`|`lineacx`"...}
    Giardino:64'hcl:linea sx turbina false value=true 00:00:09 Activity   turnOn turnOff       turnOff lineState >19 {0, "`lineadx`|`lineasxt`|`lineasxb`|`lineacx`"...}
    Giardino:65'hcl:linea sx battente false value=true 00:00:09 Activity   turnOn turnOff       turnOff lineState >19 {0, "`lineadx`|`lineasxt`|`lineasxb`|`lineacx`"...}
    Jacopo:1302:Temp Jacopo
    21.2 value<18 00:00:09 Activity 16:30~21:55, ~22:00 turnOn turnOff         lineState >23 {0, "`tlaura`|`tjacopo`"...}
    Sala Pranzo:358:Interruttore cucina
    TBR centralSceneSupport=1.Pressed 00:00:10 Activity   turnOffturnOn             >10 {0, "`icucina`"...}
    TBR centralSceneSupport=3.Pressed 00:00:10 Activity   turnOffturnOn             >11 {0, "`icucina`"...}
    TBR centralSceneSupport=2.Pressed 00:00:10 Activity   changeBrightness turnOffturnOn             >12 {0, "`icucina`"...}
    TBR centralSceneSupport=4.Pressed 00:00:10 Activity   changeBrightness turnOffturnOn             >13 {0, "`icucina`"...}
    Sala Pranzo:862:interruttore sala
    TBR centralSceneSupport=3.Pressed 00:00:10 Activity   turnOffturnOn             >14 {0, "`isala`"...}
    TBR centralSceneSupport=4.Pressed 00:00:10 Activity   changeBrightness turnOffturnOn             >15 {0, "`isala`"...}
    TBR centralSceneSupport=2.Pressed 00:00:10 Activity   changeBrightness turnOffturnOn             >16 {0, "`isala`"...}
    TBR centralSceneSupport=1.Pressed 00:00:10 Activity   changeBrightness turnOffturnOn             >17 {0, "`isala`"...}
    bagnetto:1307:Remote Bagnetto
    TBR centralSceneSupport=1.Pressed 00:00:11 Activity   turnOffturnOn             >1 {0, "`ibagnetto`"...}
    TBR centralSceneSupport=3.Pressed 00:00:10 Activity   turnOffturnOn             >2 {0, "`ibagnetto`"...}
    TBR centralSceneSupport=2.Pressed 00:00:10 Activity   turnOffturnOn             >3 {0, "`ibagnetto`"...}
    TBR centralSceneSupport=4.Pressed 00:00:10 Activity   turnOffturnOn             >4 {0, "`ibagnetto`"...}
    true value=true 00:00:09 Activity   turnOff turnOn       turnOff   >27 {0, "`pbagno`"...}
    lab:1063:Temp lab
    20.0 value>25 00:00:09 Activity 08:00~20:00 setThermostatMode setThermostatFanMode setCoolingThermostatSetpoint           lineState >20 {0, "`tlab`"...}
    20.0 value<16 00:00:09 Activity 08:00~20:00 setThermostatMode setThermostatFanMode setHeatingThermostatSetpoint           lineState >21 {0, "`tlab`"...}
    lab:1134:Rack Temp 27.7 value>38 00:00:09 Activity   turnOn turnOff             >28 {0, "`track`"...}
    laura:1305:Temp Laura
    21.4 value<18 00:00:09 Activity 16:30~21:55, ~22:00 turnOn turnOff         lineState >23 {0, "`tlaura`|`tjacopo`"...}
    soggiorno:946:r soggiorno
    TBR centralSceneSupport=1.Pressed 00:00:10 Activity   turnOffsetValue             >6 {0, "`isoggiorno`"...}
    TBR centralSceneSupport=2.Pressed 00:00:10 Activity   changeBrightness turnOffturnOn             >7 {0, "`isoggiorno`"...}
    TBR centralSceneSupport=3.Pressed 00:00:10 Activity   changeBrightness turnOffturnOn             >8 {0, "`isoggiorno`"...}
    TBR centralSceneSupport=4.Pressed 00:00:10 Activity   changeBrightness turnOffturnOn             >9 {0, "`isoggiorno`"...}
    K.Word $24clock 22:10 value=04:00 00:00:10 Activity   turnOn turnOff turnOn turnOff turnOn turnOff turnOn turnOff           lineState >18 {0, "$24clock"...}
    $24clock 22:10 value=20:05 00:00:09 Activity   setThermostatMode             >22 {0, "$24clock"...}
    $24clock 22:10 (value) 00:00:08 Activity ~07:00 turnOn turnOff       turnOn lineState >24 {0, "$24clock"...}
    $24clock 22:10 (value) 00:00:08 Activity ~14:00 turnOn turnOff         initOnStartup lineState >25 {0, "$24clock"...}
    $24clock 22:10 (value) 00:00:08 Activity 07:42~, ~18:33 setGlobal setGlobal         initOnStartup >26 {0, "$24clock"...}
    $HC3onLine false value=true 00:00:09 Activity   tts tts           >30 {0, "$HC3onLine"...}
    $RAM 41 value>85 00:00:10 Activity   sendNote setStateValue setStateValue sendNote       setStateValue   >29 {0, "$RAM"...}
    $internet online value=online 00:00:09 Activity       tts         >31 {0, "$internet"...}
    It444>27turnOff{stufabagno)
    QuickApp/Global/Local variables
    Type Name Value Modified
    Global luci_attive true 0d, 00:01:18
    Global sprinkler false 0d, 00:01:18
    Global cooling false 0d, 00:01:18
    Global heating false 0d, 00:01:18
    Global vmc true 0d, 00:01:18
    now after reboot the global var has correct value. But on previous three reboots it always was false...
