2 minutes ago, cag014 said:
Strange, in centralSceneSupport no changes from previous versions.
Yes, it is. I don't understand. But don't working. :(
Edited by SmartLifeSystems
    I think fibaro button supports scene activation and not central scene? is it correct?
    Regarding fibaro key-fob - this the key with the shapes? circle, minus, plus ....?
    Edited by cag014
    2020-09-23] [20:25:31] [DEBUG] [AOQ3688]:   [23 Sep 20:25:31] /opt/fibaro/AOQ3688.jM hash table:1:~: {0, "`keyfob`"...}
    {0,"160",{"state"="supportSceneActivation=1.Pressed","trueAct"={"158","turnOn",""}}}
    (28) State property "supportSceneActivation" is not available for Z.Device |KeyFob:160:Living room|
    Available properties:
    - protectionState
    - protectionExclusiveControl
    - idleTimeout
    - pendingActions
    - sequences
    - RFProtectionSupport
    - RFProtectionState
    - batteryLevel
    - useTemplate
    - lockKey
    - markAsDead
    - userDescription
    - protectionTimeoutSupport
    - unlockSequence
    - stepInterval
    - defInterval
    - localProtectionSupport
    - keyOptions
    - localProtectionState
    - protectionExclusiveControlSupport
    - centralSceneSupport
    - minInterval
    - maxInterval
    - protectionTimeout
    [2020-09-23] [20:25:31] [ERROR] [QUICKAPP3688]: QuickApp crashed
    I try with the devices ID and nothing.
    {0, "160",{state="centralSceneSupport=1.Pressed",trueAct={"`cinemaSystem`","turnOn",""}}},
    Fibaro key-fob defiantly uses central scene. I have one and it works.
    You said you have Fibaro buttons- that I think support sceneActivation mode.
    Anyone else have problem with key-fob?
    @SmartLifeSystems
    Do you see any value in the table. like that
    Edited by cag014
    Stupid question, when you go back to 2.5 is it works?
    Yes, working fine in the 2.5.
    @SmartLifeSystems
    In the debug window i don't see nothing, if i press some button.
    Are you using hcWebEye?
    If so, can you post the table?
    Yes. The previous picture from the hcWebEye.
    I'm confused... are you talking about error in the picture?
    If so, you have defined wrong state
    it should be centralSceneSupport and not supportSceneActivation
    No. I use the centralSceneSupport. With the supportSceneActivation I have got error message. But with the centralSceneSuppport in the new release not working.
    In the 2.5 working fine all buttons and keyfobs.
    For example this line what I use in the 2.5. Working fine, but in the new verision no work.
    {0, "`keyfob`",{state="centralSceneSupport=1.Pressed",trueAct={"`cinemaSystem`","turnOn",""}}},
    Don't know what to say ....
    Did same as you (have copied same line  to make long list)and works fine
    If you go back to 2.5 now is it working...? I mean might be the keyfob lost communication or the battery is too low!?
    Do you see green light blinks on keyfob?
    Edited by cag014
    By the way I see same button on few lines, you do know that you can combine them. all actions tables could have many commands and same command can support list of devices...
    Attached version includes proper Nice devices support (color, columns in table and etc..)
    In addition I have added debug lines for centralSceneSupport.
    When real trigger received AOQ prints out the event like that:
    Please let me know if you see these lines
    Hi cag, I tried it out. See my attachment.
    But when I press example the keyfob, not doing anything. Only the AOQ restarts by it self.
    Restarts ???!
    May I ask go to HC3 -> monitor screen and press "Reload" (make sure Debug box unchecked)
    Now press any button on key-fob and press "Reload" again.. (may be you will need to press "Reload" several times)
    Please post the part where CentralSCeneEvent shown.. see below
    1 hour ago, cag014 said:
    Restarts ???!
    This is what you think?
    As far as i can see it doesn't do anithing.
    OK. I think this is.
    I don't believe it -- Fibaro has changed the structure on new version !!!???
    To all, please download attached version to make centralSceneSupport working. (please pay attention in main color code for nice_Device  has been added)
    @SmartLifeSystems let me know if it works..
    Edited by cag014
    Everything's works well.
    Thank you for your help again. If you are near Hungary, you are our guest for a real Hungarian goulash. :) :) :)
