    1 hour ago, Rover said:
    Range= ?
    Another question:
    I want to create a flash light for alarm status, so the repeat cycle should be short, like 1 second. But Time Span has as minimum 1 minute and it should be an integer number. So how to repeat fast?
    The best option to do it, is just to buy blinking lamp and turn it on/off by Z-wave switch.
    for example
    Edited by cag014
    4 hours ago, cag014 said:
    Range? I mean range of numbers in random for example random(5,9) will repeat same number several times.
    does nothing. Why?
    Edited by Rover
    Is your device has turn On/Off command?
    If so, the workable option (to my opinion) will be something like that:
    {0.02,"&Statuslicht",{state="value=Alarm",timeLoopAct={"`StatusLEDs`","turnOff;else;trunOn","","{`StatusLEDs`:value=true}"}}},
    Homestly I don't think this is a good idea because it will overload your HC3 with endless Zwave commands, till &Statuslicht = Alarm.
    The constellation works fine already for many years in HC2.
    The reason I do not use turn On/Off is that I am using the color white in Fibaro RGBW for siren and outdoor flashdevice and not in the steering the indoor LED-array. Thats why the fourth number (White) is always 255 (so color red of indoor LED array = (255,0,0,255)). The white color is made of combining RGB (255,255,255,255). This is also the reason that I cannot use a programmed flash of the RGBW device, but have to make a homemade flash (so works fine in HC2). Now the task of making it workable in AOQ.
    27 minutes ago, Rover said:
    the timeLoopAct executed after 5 minutes from the moment when "value=Alarm".
    7 hours ago, cag014 said:
    10 hours ago, Rover said:
    Hi @cag014
    If
    This has nothing to do with random range, it is just turnoff lights by $24clock.
    How can one $24clock trigger repeats several times in more seconds than the ~value?
    This is not $24clock, this is the random of the timeSlot.
    While you have same value (status is true) the timeSlot is moving. As you can see it repeats every minute, not a second.
    Since AOQ checks every line very fast you have 100% of opportunity to have right random timeSlot every single minute after 03:00. It will repeat for entire hour
    Please explain what you're trying to do here?
    Edited by cag014
    I think we have a misunderstanding.
    Edited by Rover
    No... that's exactly what I said,
    You have define
    timeSlot="?3:00+(random(`RandomMinTijd`,`RandomMaxTijd`)*60)?~",
    means to execute trueAct at 03:00 +random value, correct?
    AOQ interprets this line several times in one second! so it 100% garanties that within one minute it will be the same time and tru Act executed.
    There is nothing to do to $24clock definition.  $24clock will never be "value=0". The trigger is combination of tilde in timeSlot definition XX:XX~ and the time
    Edited by cag014
    11 minutes ago, cag014 said:
    You have define
    Yes, that is what I want, but just one time.
    Your explanation is still not clear to me, but you can help me with showing how to turnOff the 5 random lights at 03:00 +random value, just 1x.
    There is an very complicated solution, but I have an idea how to make it simple.
    Will post new version to support your request.
    Edited by cag014
    OK, download attached version
    Please change your line as follow...
    {0, "$24clock",{state="value=02:55",  trueAct={
    {"$lineId","setTimeSlot","?3:00+(random(`RandomMinTijd`,`RandomMaxTijd`)*60)?~","{$24clock:value=02:55}"},
    {"`XRandomLichten`","setGlobal","stop","{$24clock:value>02:59}"},
    {"RandomLichten","sendEmail,2","Stop","{$24clock:value>02:59}"},
    {"`RandomLichten`","turnOff","","{$24clock:value>02:59}"}}}},
    The idea that every day at 02:55 the setTimeSlot will be executed and will set the timeSlot to 03:00 + random. While your original actions have condition to be executed after 02:59...
    To all, the attached version is the final version which I intend to post on Wednesday , so any feedback or suggestions will be appreciated. Thanks for your time and efforts so far....
    Edited by cag014
    TNX @cag014!
    This solution is so "simple" that I could not have invented it in 100 years ?
    On 9/19/2020 at 10:10 AM, Rover said:
    It would be nice for the final version as everywhere device names are to be seen.
    Edited by Rover
    What do you mean by device names?
    To see device real name or alias as defined in jS2n?
    Question: is your device 174'hc2 defined in jS2n?
    To see device real name or alias as defined in jS2n? Yes, so "turnOff(DimmerHal)" instead of "turnOff(174'hc2)", just like "turnOff (Schilderijspot,SpotsTrapOverloop)" in the line above.
    jS2n:
    acts as OR relation.
    How to specify an AND relation?
    lineState={"{&Alarmtest:value=Aan|&Statuslicht:value=Alarm}"}
    In general condition format is
    "{...|...|...}" means AND
    "{...}{...} means OR
    You can combine as much as you need.
    It works great ?
    Cag14. Tnx, i'm out for work these days and i'll send you feedback asap. Sorry but for me this week is "homeautomation free".
    @gggizmo
    No problem, do anything you need to prevent divorce ?
    @Rover
    Attached last version with bug fix (device name always shown).
    To all, since HC3 and mobile app have options for different color themes, I have added to main code option to change some colors of the table (like false/true status, items and etc...) and printed lines on debug window.
    Please use it for best view on your theme.
    Edited by cag014
    Hi cag,
    I downloaded the 2.8 version. I have got a Nice gate, and and this command open/close, but with the new release this don't working.
    What's the problem? Can you help me?
    [2020-09-23] [17:18:06] [DEBUG] [AOQ3681]: Global not defined. Local variables ("my_Var" "onState") won't be saved for next run...[2020-09-23] [17:18:06] [DEBUG] [AOQ3681]: Global not defined. Reminders won't be saved for next run...[2020-09-23] [17:18:07] [DEBUG] [AOQ3681]: Parsing jM[149] hash table data... <25 sec.[2020-09-23] [17:18:10] [DEBUG] [AOQ3681]:   [23 Sep 17:18:09] /opt/fibaro/AOQ3681.jM hash table:25:~: {0, "`bedroomButton`"...}
    {0,"166",{"state"="centralSceneSupport=1.Pressed","trueAct"={"468","close","","{420:value=true}"}}}
    (99) Action close not supported.
    AOQ Supported Actions: (32% in use)
    - addRmd armAlarm delAllRmd delLogRmd delRmd disableScene
    - disarmAlarm emitEvent enableScene killScene logRmd poll
    - powerOutage pressButton reboot runAction sendEmail sendNote
    - sendPush sendSms sendiPush setColor setConfiguration setGlobal
    - setProfile setRmd setSlider setState setStateDelay setStateFormula
    - setStateValue setTimeDrift setTimeSlot setTimeSpan setValue shutdown
    - startScene tts turnOff turnOn vacOff vacOn
    - verify
    [2020-09-23] [17:18:10] [ERROR] [QUICKAPP3681]: QuickApp crashed
