8 minutes ago, cag014 said:
@gggizmo
No problem, do anything you need to prevent divorce ?
@Rover
Attached last version with bug fix (device name always shown).
I have changed 2.8-->2.9
    On 9/21/2020 at 9:27 PM, Rover said:
    The constellation works fine already for many years in HC2.
    The reason I do not use turn On/Off is that I am using the color white in Fibaro RGBW for siren and outdoor flashdevice and not in the steering the indoor LED-array. Thats why the fourth number (White) is always 255 (so color red of indoor LED array = (255,0,0,255)). The white color is made of combining RGB (255,255,255,255). This is also the reason that I cannot use a programmed flash of the RGBW device, but have to make a homemade flash (so works fine in HC2). Now the task of making it workable in AOQ.
    @Rover
    I have an idea for your flash light
    define blank line with flash action disabled by default.
    {-10,"$blank",{state="value=blank",timeLoopAct={"`StatusLEDs`","turnOn;else;trunOff","","{`StatusLEDs`:value=0}"}}},
    Now in your original line set necessary color and active the blank line (assuming the blank line is the first line in jM)
    {0,"&Statuslicht",{state="value=Alarm",trueAct={{"`StatusLEDs`","setColor,255,255,255,255",""},{"$blank>1","setTimeSpan","0.03"}},
    falseAct={{"$blank>1","setTimeSpan","-10"}}},
    The idea is to enable/disable the blank line. On the blank line you can use setColor instead of turnOn/Off as fits your needs.
    I think On/Off is better option, because other lines can set different color and to use same blank line....
    Please use AOQ v2.9 for that... did some changes and don't know if previous versions can support such a short span time.
    Edited by cag014
    25 minutes ago, SmartLifeSystems said:
    Hi cag,
    I downloaded the 2.8 version. I have got a Nice gate, and and this command open/close, but with the new release this don't working.
    What's the problem? Can you help me?
    [2020-09-23] [17:18:06] [DEBUG] [AOQ3681]: Global not defined. Local variables ("my_Var" "onState") won't be saved for next run...[2020-09-23] [17:18:06] [DEBUG] [AOQ3681]: Global not defined. Reminders won't be saved for next run...[2020-09-23] [17:18:07] [DEBUG] [AOQ3681]: Parsing jM[149] hash table data... <25 sec.[2020-09-23] [17:18:10] [DEBUG] [AOQ3681]:   [23 Sep 17:18:09] /opt/fibaro/AOQ3681.jM hash table:25:~: {0, "`bedroomButton`"...}
    {0,"166",{"state"="centralSceneSupport=1.Pressed","trueAct"={"468","close","","{420:value=true}"}}}
    (99) Action close not supported.
    AOQ Supported Actions: (32% in use)
    - addRmd armAlarm delAllRmd delLogRmd delRmd disableScene
    - disarmAlarm emitEvent enableScene killScene logRmd poll
    - powerOutage pressButton reboot runAction sendEmail sendNote
    - sendPush sendSms sendiPush setColor setConfiguration setGlobal
    - setProfile setRmd setSlider setState setStateDelay setStateFormula
    - setStateValue setTimeDrift setTimeSlot setTimeSpan setValue shutdown
    - startScene tts turnOff turnOn vacOff vacOn
    - verify
    [2020-09-23] [17:18:10] [ERROR] [QUICKAPP3681]: QuickApp crashed
    I readd the 2.5 version. This codes working only with this version. :S
    Edited by SmartLifeSystems
    Hi cag,
    - verify
    It worked with previous releases?
    Yes, but the last one, what I can use the 2.5
    My HC3 doesn't support Nice devices...
    Could you please post API of the Nice device?
    How can I see the API? This is a 433MHz device.
    On browser
    http://<HC3-IP>/api/devices/468
    OK, I see.
    I think this is:
    Or this is:
    Interesting how it works in 2.5 !!??
    I see the device hase parentID = 7
    Could you please post API of device 7?
    Of course.
    24 minutes ago, SmartLifeSystems said:
    Of course.
    Now it's understandable...
    Here a quick fix for you, let me know if it works.
    You are so great. Working fine.
    Thank you very much!
    Ooops. The buttons and key fobs doesn't work.?
    Are you sure? I have two key-fobs and they're working fine...
    What error you see?
    Please post jM lines with buttons and key-fobs
    Edited by cag014
    What error you see?
    It does nothing.
    Two Fibaro button, and one key fob. No error message, only doesn't work.
    Example:
    {0, "`keyfob`",{state="centralSceneSupport=1.Pressed",trueAct={"`cinemaSystem`","turnOn",""}}},
    2 hours ago, cag014 said:
    @Rover
    TNX for the creativity cag!
    But this "flash" light is too slow: 2-3 seconds between each flash, but it works.
    I am using now a simpler construct:
    with 1-2 seconds between each color change. This is good enough for the job.
    18 minutes ago, SmartLifeSystems said:
    It does nothing.
    Example:
    With the 2.5 version working the button. :S
    19 minutes ago, SmartLifeSystems said:
    It does nothing.
    Example:
    Strange, in centralSceneSupport no changes from previous versions.
