    1 hour ago, gggizmo said:
    It' s exactly what i did today,. First tried 4 jm lines then 3,two, one..minimum delay 1,5 sec. And the single jm line was to drive a light and a motion sensor located at less tha 3 mt from hc3 appliance
    Let's do something interesting.
    Please change line
        self.http = net.HTTPClient({timeout=900}) -- bigger timeout is needed
    to
        self.http = net.HTTPClient({timeout=40000}) -- bigger timeout is needed
    Now entire code uses HC3 refresh-state only. Please don't use slave devices... it will dramatically increase delay time on slaves.
    1 hour ago, cag014 said:
    Unfortunately I have only 5 devices...
    AOQ uses same refresh-state triggering engine as block scenes.
    Interesting, could you try it with one jM line only?
    Anyone else has same delays ?
    Yes, I have. 1~6 sec. I noticed that if the AOQ repeats the same action, it is fast, but if some time passes it is slower.
    Please change line
    to
    i'll try tomorrow early morning...it's saturday, i have a wife, and i have not enough money to divorce...please be patient:-)
    Why???
    Edited by Rover
    30 minutes ago, Rover said:
    Oops... added once... bug.. fixed.
    Meanwhile please make it in two lines.
    @gggizmo
    This is a long shot, but please try attached version...
    @Rover
    this version includes bug fix (+Send_Pushover)
    In addition this version supports start/kill/enable/disable scenes on slaves as well.
    attached new version of AOQ_REMOTE (minor bug fix).
    Edited by cag014
    4 hours ago, cag014 said:
    @gggizmo
    @Rover
     [20 Sep 09:26:30] /opt/fibaro/AOQ1341.jM hash table:4:~: {0, "`mportoncino`|`mscala`|`pingresso`"...}
    {0,"1269|1286|1211",{"timeSlot"="?$sunriseHour+1800?~?$sunsetHour-1800?","state"="value=true","trueAct"={"481","turnOn","","{1288:value<15}"},"falseAct"={"481","turnOff","64","={1286:value=false|1269:value=false|1211:value=false|481:value=true}"}}}
    (8) Action 'turnOn' not found for ID(481) Supported actions:
    `lscala`Luce scale:481:scala Device's actions are:
    - reconfigure reset toggle turnOff turnOff
    AOQ Supported Actions: (16% in use)
    May be a bug? it's a fibaro double switch
    For me too.
    /monthly_2020_09/image.png.a804ac738c78312a14440d69d13f44e5.png" />
    Edited by SmartLifeSystems
    5 hours ago, cag014 said:
    @gggizmo
    And just another request that i know may sounds stupid.
    Please add in aoq qa a button to pause the execution of itself, i think may be very useful during test and compare sessions, a very time saver.
    Gggizmo,
    My HC3 is parcked wiats for better fw.
    I spent a lot of time but nothing was functioning right.
    Happenly my wife is patience (patient).
    Succes,
    Sjakie
    Looks like bug...
    Attached bug fix
    @cag014
    What is the translation of HC2 LUA
    to AOQ? It concerns a RGBW-Controller.
    1 hour ago, Rover said:
    @cag014
    As far as I know HC3 doesn't support startProgram, has been notified by few users.
    Edited by cag014
    Usual command
    {"86","startProgram,155",""}
    But please pay attention if HC3 supports this functionality.
    I have RGBW controller (TKB Home) and it doesn't have startProgram...
    here is the properties and as you can see in actions: startProgram not supported.
    It is a Fibaro RGBW-Controller.
    21 minutes ago, Rover said:
    No protest of AOQ for
    7 minutes ago, cag014 said:
    If AOQ sends the command, means Fibaro RGBW has the command.
    @gggizmo
    Attached AOQ has an anticipated button to stop and restart AOQ.
    tnx cag, i really appreciate
    Hi @cag014
    If
    Edited by Rover
    2 hours ago, Rover said:
    Hi @cag014
    If
    3 hours ago, Rover said:
    Hi @cag014
    If
    It could happened if your range is too tight...
    Range= ?
    Another question:
    I want to create a flash light for alarm status, so the repeat cycle should be short, like 1 second. But Time Span has as minimum 1 minute and it should be an integer number. So how to repeat fast?
    Edited by Rover
