    3 hours ago, gggizmo said:
    I forgot to mention that after every single step or modification i rebooted hc3 to assure same starting condition
    Thank you for such detail test.
    By looking on your CPU graph, I can certainly say that new version has better CPU performances.
    As I have suspected, more Z-wave device will cause longer delay and this makes sense as HC3 works.
    HC3 trigger engine executes in parallel Lua/block scenes.
    In AOQ, I don't have a choice but to react by trigger->device in serial way.
    I did an interesting experience by using few AOQs with different jM lines (I mean every AOQ has different z-wave devices) and the delay stays very low.
    By the way AOQ has a small advantage over standard scenes. HC3 allows only one single scene instance (HC2 allows up to 10) and if triggered too fast the previous instance killed and an ERROR displayed. Don't think that's so important, but in follow example it does.
    by pressing on Fibaro key-fob button one, I turn on or off the lights according opposite to the light state (if lights off-> turnOn, if lights on -> turn off).
    By pressing very fast on key-fob no changes on the light according to the number of presses.
    Again, , I want to thank you for your time and such a comprehensive testing...
    A si previuos siad delay start to be noticeable with 10 devices or more. And from previuos post i reconfigure aoq to drives wall remotes. Block scenes are now used only for motion triggered lights.
    At home my family can wait a little if a light is switched on or off manually, but no way, they enter in nothing is working mode if lights don't turn on immediatly when they walk trough the rooms.
    So i can bear to have a mixed configuration to accomplish family request. I hope in better perfomance with new firmware but if i correctly understand may be delay is not related to cpu load, but let me say that it's really a pain to control multiple conditions with block scenes so everytime a small dely it's not a problem i'll continue to use aoq to save time and mental sanity.
    Just a question: any idea to make a slave device visible in hc3 interface: ex. in garden i have 3 or 4 lights and i can't create a motion triggered scene. I did in the past but with  6 cats lights stay on every time. So i need to switch on and off manually.
    So may be a qa toggle global var checked by aoq  a solution? And i know that with this approch delay  on off it's in the range of 3-4 secs. Any hint?
    5 hours ago, Rover said:
    Wat is wrong in the verification?
    Do you mean to have QA device that simulates slave's light device?
    10 minutes ago, cag014 said:
    I just think aloud, do we need confirmation? I think if no error executed it confirms that the action is completed.
    I can create another table in case verification succeed, is it necessary?
    yes, and the only idea i have to use global var....
    I missed this part...are you suggesting to split devices declarations and related jm lines to multiple instances of aoq?  Now i know what to do on sunday!!!!!!
    and when you say aoq has different z-wave devices you meant in js line? Or it's enough that a specif device is not present in any action in jm lines?
    jS2n line could be the same (it's just name mapping)
    In each AOQ in jM line work with different devices as a line main device in jM (marked bold below) All devices could present in actions of all AOQs.
    for example
    AOQ-1
    jM={
    {0,"400",{state="value=true",trueAct={"300","turnOn",""}, falseAct={"300","turnOff",""}}},
    AOQ-2
    Never define 400 as line main device, but you can use it in actions
    {0,"500",{state="value=true",trueAct={"300","turnOn","","{400:value=true}"}, falseAct={"300","turnOff",""}}},
    Edited by cag014
    for example
    AOQ-1
    jM={
    AOQ-2
    clear: avoid check of same zwave device in different instances of aoq.
    Tnx
    pss. my english is far from good, but i can assure that on monday i'll buy new aaa bateries for my keyboard...i'm loosing keystroke and my post are less than readble...sorry
    To all, I hope this is the last update (few users have asked for an official release)
    Major changes are:
    1. Any command must have only two first fields (mandatory), all other fields could be written in any order or not at all if not required for your convenience.
    For example
    trueAct={"400","turnOff"} -  no delay/conditions/initState required
    trueAct={"400","turnOff",false} -no delay/conditions required, only initOnStartup is false
    trueAct={"400","turnOff","{300:value=true}"} - only conditions required
    trueAct={"400","turnOff","{300:value=true}","10"} - conditions and delay required.
    trueAct={"400","turnOff","{300:value=true}",true,"10"} - all parameters in use.
    Although any order accepted, please try to keep same order when parameters required for better view later, but do skip unused parameters.
    2. Conditional parameters could be written in human readable format also
    Two formats are supported (any combination in between supported as well)
    [when]{cond1 and cond2 and ….} or {cond1 and cond1 and ….} or..  - human readable
    [=]{cond1|cond2|…}{cond4|cond5|….}{..} - short format
    @Rover
    Have added okAct{} table for successful verification.
    {"all","disarmAlarm!{$Beneden:value=disarmed|$Boven:value=disarmed}",""},errAct={"Arming error","sendEmail,2","Niet alles armed"},okAct={"Arming state","sendEmail,2","Alarm armed"}}},
    31 minutes ago, cag014 said:
    @Rover
    Thank you cag, for this very useful additions ?
    Also the two major changes are very useful for me (and for sure other AOQ users) ?
    Edited by Rover
    Sorry to bother you with a simple question...i was so focused on performance and i don't pay attention to syntax changes and function, or simply i forgot how to create jm lines.
    so, i need to create a simple jm line that changes a global var value 30 min after sunrise and 30 minutes before sunset...i'm stuck..i can believe it
    {0,"$blank",{timeSlot="?$sunriseHour+1800?~,~?$sunsetHour-1800?", --execute trueAct 30 min after sunrise and falseAct 30 min  before sunset
    trueAct={"$variable","setGlobal","sunrise"},    -- set global variable to value "sunrise"
    falseAct={"$variable","setGlobal","sunset"}}},  -- -- set global variable to value "sunset"
    Assuming you need to set same global to different values at sunrise and sunset.
    Please change $variable to your global and "sunrise"/"sunset" values to what you need
    Edited by cag014
    first time i see $blank... I need to read again documentation and every single post in this topic.
    Tnx again
    Guys ... sorry... there is a bug when line includes ;else; statement. Please keep that lines in standard order, will fix it.
    Other lines works fine
    14 hours ago, Rover said:
    I am trying to do it also, so till now all could be implemented in AOQ.
    But how to implement in AOQ a repeated action where the number of repetitions can be declared and the line can be "called" from several other lines?
    What is the difference between $blank and $24clock?
    Edited by Rover
    7 hours ago, cag014 said:
    12 hours ago, Rover said:
    O.K. errAct is clear, but which line can be activated if all disarming has succeeded?
    Yes I need confirmation of no error, because if no error then I can go further with the expansion of arming or disarming operation, while if error occurs the operation should be stopped.
    TNX for adding the okAct feature ?
    No difference at all... but probably you correct and it's better to use $24clock in this way you can easily to identify time-based lines in jM.
    Is this HC2 command to be translated to AOQ? It concerns a Fibaro RGBW controller.
    It sets just the W output off and let the other colors unchanged. I need this because the White color is steering the siren and outdoor flashlight.
    Ok,
    Used as standard command
    {"`AlarmstatusRGB'hc2`", "setW,0")
    Edited by cag014
