    1 minute ago, SmartLifeSystems said:
    Is it rue the sendPush and sendiPush too.
    Here is an example. My phone got the notoifications 2 times. If i don't set the ID413, got the notifications the 2 phones normally.
    {0, "$DayArmed",{state="value=armed",trueAct={"Satel Integra:","sendPush,3370,413","A riasztó nappali élesítése aktív."}}},
    May I ask you to check in account settings in HC3 what phones listed under your name (and yours wife).
    In addition what do you see on debug window (how many phones listed)?
    18 minutes ago, gggizmo said:
    what do you consider unpleasant delay?
    That is a delay which could be longer then with devices included in HC3, but not noticeable.
    The AOQ send the massages normally, what I see the debug window. The Account setting correctly too. I don't understand what is the problem.
    Edited by SmartLifeSystems
    So, only one phone listed for each account?
    just to be clear i have to fight with my wife for just 1 sec delay in turnig lights on....
    Yes, because I set the 2 phones, my phone got double messages.
    pushNote    = {false,"3370"}  -- if true, alerts interactive push notification will send
    How fast she reacts on your requests? within one second also? Joking.....?
    By the to turn switch manually takes longer than one second...
    So you have two phones under your account in HC3?
    By the way, only you receive double message? Your wife receives one message?
    One under my account, and one under my wife's account.
    Here is the debug window, and my phone's screenshot.
    [2020-09-30] [18:43:53] [TRACE] [AOQ3694]: 3.0jM{122} TGarage:421:Garage door sensor[true] => sendPush,3370,413(Attila iPhone-ja,Noémi iPhone-ja,) 'Garázsajtó:','A garázsajtó nyitva.')
    I'm clearly a nerd. My house is not big and when we walk from bedroom to bathroom during night 1 sec makes difference. But it's my fault...i don't really need home automation, but i like it and now if something goes wrong i have to pay the fee of my wrong choice.
    In the past with alexa not available in italy, i bought uk version. So to turn on and turn off light we have to speak in english...
    And she reacts very fast...and i did not mention how fast react my sons...
    Edited by gggizmo
    Add sensor to bathroom door... or try  Google Home instead alexa.
    @Smartsystem
    It might be a problem with your iPhone... there are some issues with double notification, see
    Edited by cag014
    Already there...and i have google home too.
    Those light are triggered by motion sensors, and there's non delay with block scene. Less delay if i use old fashion, classic manual switch
    18 hours ago, cag014 said:
    Strange indeed... how Lua compares strings..
    Attached version in txt format.
    download the text file and copy-paste into mainCode of AOQ.
    Let me know if it works...
    Yes, know it seems to work. Only "Power On" on all lights now ?
    What do you mean all lights?
    Life is one of the heaviest things ?
    The lights I want to control turn on now. Not as before when they turned on and off instant twice before staying on.
    Problem solved ?
    Indeed, see COVID-19 issue
    @Rover
    I gave another thought on rptAction and came to conclusion that it is not acceptable approach to make timing calculations between delays of command and rptAction,
    so the attached version makes it simple. The rptAction delay will be between the repetitions regardless how long takes to execute commands.
    To make it clear ( I intentionally use 10 seconds delay below)
    trueAct={{"400","turnOn",},{"400","turnOff","10"}}    and     .."rptAction,3,2"...
    Now when trueAct executed, AOQ waits till it is done then waits for 2 seconds and executes another repetition... and so on
    trueAct(10s) --> 2s --> trueAct(10s) --> 2s --> trueAct(10s) -> done
     After upgrade just change in your jM to "rptAction,3,1" for flashlight
    Edited by cag014
    10 hours ago, cag014 said:
    @Rover
    Yes, this is a better concept.
    But the timing is not so stable. Look at
    networkerror ???
    Edited by Rover
    40 minutes ago, Rover said:
    Now timing with a Fibaro Dimmer2:
    Yes, the one second delay is too fast for HC3 and devices.
    Have tested with my Aeon Lab siren directly with Lua and block scene. It's not a stable action, but 2 seconds works better.
