1 hour ago, Rover said:
@cag14
any particular reason aoq remote is limited to 10 buttons?
May i for example modify the line
jBtn={"btn1","btn2","btn3","btn4","btn5","btn6","btn7","btn8","btn9","btn10"}, add 2 more buttons and so on?
    1 hour ago, gggizmo said:
    @cag14
    No.. you can increase the number of buttons by adding more
    jBtn={"btn1","btn2","btn3","btn4","btn5","btn6","btn7","btn8","btn9","btn10","btn11","btn12"}
    Now add graphical buttons (same number) and set button ID to new names
    In onReleased section of the button enter btnPressed
    Means AOQ has been unable to get value from slave..
    You should receive an error that describes the path which has no access
    Printed on debug window and popup menu at hcWebEye
    Edited by cag014
    tnx i'm a newbie but not so newbie.Already done and working i was asking for a tecnical reason to limit buttons number.
    No reason at all. set as many as you need
    And i suppose i can upload more instances of remote just to have an orderd view of devices paired with different gateways
    Edited by gggizmo
    Yes you can.. as many as needed. New instance will have new device IDs..
    1 hour ago, cag014 said:
    Edited by Rover
    my bad the nil and false means the same to Lua.
    Download attached
    To all, attached slave switch emulation QA. Emulation includes power and energy readings, if exist on slave switch.
    This QA suitable for all kind of switches (WallPlug, Fibaro double/single switch and etc.)
    By the way, you can change the AOQ remote to have more buttons in one row... I have decided to use two buttons in row because of length of the label, that's all.
    If you can use short labels you can have tens of buttons on one remote and divide the buttons by labels
    14 hours ago, Rover said:
    Now timing with a Fibaro Dimmer2:
    It might be better approach to use state checker.
    trueAct={"'`DimmerHall`","turnOn;else;turnOff"," if {`DimmerHall`:value=false}"}
    now set the rptAction to 6,1 (repeat 6 times with 1 second delay)
    BTW if it is actually dimmer, you should consider that dimmers don't turn off the lights immediately, but dimming to off. Depends on dimmer setup.
    Edited by cag014
    Download attached
    Did you forget to update release number inside the main code?
    or did i copy and paste wrong version?
    /monthly_2020_10/image.png.f9f9be23bf6318fdf8aa21f9d8e745db.png" />
    Oops... too many releases, yes you right forgot to update.
    don't worry it's just cosmetic...and i think soon you 'll release 3.3 so...
    Download attached
    Repaired ?
    Nice, but what is the extra value above <device>'hc2?
    Is sceneActivation usable for Fibaro double/single switch?
    No turnOn in cycle...
    7 minutes ago, Rover said:
    OK... this is because the dimmer.
    try to replace value=0
    Dimmer doesn't use true/false, but value 0-99
    Edited by cag014
    So 6 actions, starting by turnOff, ending by turnOn...
    Time between actions is 4 seconds, too long.
