20 minutes ago, cag014 said:
Sorry... one of leftovers of problem debugging.... removed
It looks like a much faster initiation ?
    Thanks for confirmation... especially faster when using devices on slave controllers.
    But I think @SmartLifeSystems has a point, somehow timeSlot calculations indeed create more CPU load...
    Working on that...
    Working on that...
    Just now, Rover said:
    Do you have a lot of timeSlot definitions? I mean a lot of them !
    I have 4 timeSlot definitions.
    That's nothing.... it starts somewhere over 70 definitions...
    Working on that...
    Yes. Some timeSlot codes i added to the if conditions.
    The CPU load a little bit lower, and the AOQ's answere time more better.
    in conditions not an issue because it calculated only when and if the action executed...
    Looks like the os.date() Lua function is the heavy one...
    In the past, we talk about the first day of week. So in Hungary the monday is the first day, but the AOQ using the sunday for me.
    AOQ using system timezone... what timezone you have on HC3
    /monthly_2020_10/image.png.a5550da5c6d8cc7410a46749161fbfa6.png" />
    1 minute ago, SmartLifeSystems said:
    The time, the sunset and sunrise hours is corrct. Only the days not.
    But is not problem for me.
    My bad... I'm using GMT days setup ..
    Please try attached version... it should reduce CPU load to normal average..
    Now better like was, but not looks like @Rover 's CPU. :)
    Edited by SmartLifeSystems
    @SmartLifeSystems Some needs to work harder for the same result?
    @cag014 I want to try to slave  HC2 instead of using switch/ sensor slave sometimes I see the action is not done.
    Note HC2 is on Event Runner HC3 AOS
    I hope you have some time to support
    Getting error  user_data.lua:26: unexpected symbol near '<\226>'
    {0,”120’hc2”,{state=”value=true”,trueAct={“240’hc3”,”turnOn”},{“&variable’hc2”,”setGlobal”,”HC2”}}}},
    120 doorsensor, not in js HC3
    240 HUE lamp is in Js
    Do I need to set a variable in HC2?
    Please advice,
    //Sjakie
    14 hours ago, cag014 said:
    Yes, if main loop will take over 4 seconds...
    @cag014, where can i look the main loop time?
    I can't press downer the CPU's load.
    Please advice,
    //Sjakie
    I have asked you if you're using salve switch/sensor emulation...
    May be now we we can finally fix the delay issue.
    Please replace your slave QA by attached
    This new version has fixed the delay issues in @Rover system
    First of all why you're using 240'hc3 ? You're running AOQ on HC3, so use as usual {“240”,”turnOn”}
    You're missing brackets - should be
    {0,”120’hc2”,{state=”value=true”,trueAct={{240’hc3”,”turnOn”},{“&variable’hc2”,”setGlobal”,”HC2”}}}},
    I have no slave devices. Only Fibaro switches, dimmers, RGBW modules, wallPlugs. One Qubino Z-Wave wall plug and a Hank Z-Wave wallPlug, Nice gate, SONY TV with Plugin and a SATEL alarm with plugin.
    The answere time has improved with one or two seconds with the 5.2 version.
    OK... misunderstanding.
    Now you have two choices to use HC2 devices directly or to use SlaveSwitch/Sensor/Dimmer emualtions.
    To my opinion is better to use emulation of devices, I think it's slightly faster and you can see on HC3 UI  HC2 devices (their status and control)
    Again... @Rover has the best experience what is better?
    @Rover what is your recommendations?
    Sorry I overlooked your question at this moment NO  slave devices
    I want to use the whole HC2 as slave.
    Do I need to use SlaveSwitch also if I use
    jSlave={
           hc2={user=xxxxxxxxx?
    First of all why you're using 240'hc3 ? >>>> your documentation the line with example.
    .//Sjakie
    ok see your point. For me I dont mind the speed (at this moment)
    But to see in HC3 the status of the  devices is easy it will take a long time to do the all.
    Advantage I dont need to adapt my rules later?
    If I now add all with name and in Js
    //Sjakie
