This email is not sent at all when pressing a button at VoordeurSwitch:
{0,"`VoordeurSwitch`",{trigAll=true,trigAct={{"VoordeurSwitchHC3","sendEmail,2","@`VoordeurSwitch`>sceneActivation"},{"VoordeurSwitchHC3","sendEmail,2","Pipo"}}}},
    2 minutes ago, Rover said:
    In Advanced User's Guide 4.0:  1. In case property is sceneActivation or CentralSceneSupport, trigAll set to true by default.
    But trigAll is not functioning with CentralSceneSupport at all, even if trigAll has been added explicitly:
    {0,"`PortSwitch`",{initOnStartup=false,trigAll=true,state="centralSceneSupport=6.Pressed",trueAct={
    Only pressing button once is working, until another button has been pressed.
    Is PortSwitch HC2 device and is it used in more that one jM line?
    @Rover centralSceneSupport, sceneActivation have been fixed.
    By the way initOnStartup is set by default to false also for centralSceneSupport and sceneActivation.
    @SmartLifeSystems @[deviceID]>lastBreached has been fixed
    Edited by cag014
    18 hours ago, Rover said:
    I can see this on the end of the day.
    The  High REST API response time is still quiet.
    The iClock function has worked tonight ?
    On 10/23/2020 at 2:00 AM, cag014 said:
    When using AOQ internal GV, on every restart it's start from default value as defined in varArray.
    By using system's GV all values are stored and retrieved on every AOQ restart.
    For example: you have defined variable for alarm
    global4local= {false,gVarName="",varArray={Alarm="disarmed",
    now in some point you have armed the alarm and Alarm="armed".
    If you restart AOQ, the Alarm will be set again to disarmed, but if you're using system GV the last value is stored and retrieved on restart. So in this case even after restart Alarm value is armed.
    By the way to use system GV you need to set not ony gVarName, but to set the first value true as well.
    global4local= {true,gVarName="AOQtank",varArray={Alarm="disarmed",
    Please define GV in system before usage (AOQ doesn't create the GV)
    In Advanced User's Guide 4.0: global4local = {false, gVarName="aosVar", -- system’s global variable definition to store script’s local variables.
    What means here false or true? Why in Advanced User's Guide 4.0 a different advice?
    [24.10.2020] [08:56:00] [DEBUG] [AOQ66]: 5.6Initializing jS2n, jP2n, global and userKeyWord arrays...
    [24.10.2020] [08:56:04] [ERROR] [QUICKAPP66]: QuickApp crashed
    [24.10.2020] [08:56:04] [ERROR] [QUICKAPP66]: /usr/share/lua/5.3/json/util.lua:55: bad argument #1 to 'for iterator' (table expected, got number)
    when global4local= {true,gVarName="aoqVar",varArray={Tuinpomp2uur="Uit",Achterkant
    {0,"`VoordeurSwitch`",{lineState={" if {`VoordeurSwitch`:sceneActivation=`But3Release`}"},
    initOnStartup=false,state="sceneActivation=11~45",trueAct={
        {"VoordeurSwitch-%HC3","sendEmail,2","Disarm"}}}},
    Why do I get 2 emails (1 for 33-But3Hold and 1 for 35-But3Release)?
    Cag,
    I have slave switch 319 listed in Js
    In Device
    lampBoven:358:overLoop
    Emulation in process
    If I use in line overLooplampBoven it  generates error its not found
    Please advice,
    //Sjakie
    Icon doest change either on/off
    Why different advice? Just different name for GV... it could be any name.
    The false or true is used to store or not the AOQ GVs.  You can define GV name, but by setting false it wouldn't be saved. That's all
    I believe after 33-But3Hold keyfob always sends But3Release, isn't?
    It is not about the name of the system GV of course, its about:
    1. In guide is adviced to use a GV + false, while you statet now to use true.
    2. If you use true, then: system crash:
    Yes you get always a Hold + Release. That is why I try to filter one of the two in the lineState, but this do not work! Why not?
    (Before you say that this an unnecessairy complex way to filter 1 button: I am using more buttons in the lineState, but there is only one showed here in order to define the issue).
    @cag014 i have a question. Does the slave switch fqa that you uploaded work with wall plugs?
    Does the slave switch fqa show the energy consumption?
    Yes, it does
    Never tested on HC3, looks like json.decode() more robust...
    Fixed
    Fixed
    Works ?
    Just a little bit crowded on debug page:
    Works ?
    I must to delete SmartLifieSystems' debug line..
    @cag014 why is the But3Hold not filtered?
    The [24.10.2020] [23:09:25] [DEBUG] [AOQ66]: onTime end loop 93 4 is still there...
    Edited by Rover
    I thought I answered... sorry
    As I understood you're sending email on But3Hold and But3Release events, but afte But3Hold pressed again But3Release is activated, right?
    Why you're sending email on But3Hold ? it will be sent on But3Release anyhow.
    Since But3Hold activates two events (But3Hold and But3Release) send email just on one of them.
    I mean remove sending email from But3Hold
    Edited by cag014
    I am not sending emails from But3Hold, but I want to send email only if lineState condition is true, that means only if But3Release and not if But3Hold.
    Please free me from this loop ?
    Edited by Rover
