2 minutes ago, cag014 said:
Hover the mouse over
    1 minute ago, Rover said:
    These lines appears after Z-wave activity, please Toggle the hcWebEye
    I hover and hover and Toggle and Reload and...
    nothing to be seen.
    nothing to be seen.
    Do you have any Z-wave activity on HC3?
    How to be seen? AOQ 6.2 is running.
    Edited by Rover
    Just activate any device on HC3,
    I have only 2 wallplug switches on HC3. On/off manually does nothing on webEye.
    Edited by Rover
    Activate devices and toggle hcwebeye
    Edited by Rover
    I installed a second AOQ 6.2 with only
    {0,"`PortSwitch`",{state="centralSceneSupport=1.Pressed",trueAct={ --Dimmer Leeslamp Aan/Uit
        {"PortSwitch","sendEmail,2","1 1x"}, {"`DimmerLeeslamp`","turnOn;else;turnOff","if {`DimmerLeeslamp`:value=0}"} }}},
    {0,"`PortSwitch`",{state="centralSceneSupport=1.Pressed2",trueAct={ -- Dimmer Leeslamp toggle 99%-30%-50%
        {"PortSwitch","sendEmail,2","1 2x"},
        {"`DimmerLeeslamp`","setValue,50","if {`DimmerLeeslamp`:value=99}"},
        {"`DimmerLeeslamp`","setValue,30","if {`DimmerLeeslamp`:value=50}"},
        {"`DimmerLeeslamp`","setValue,99","if {`DimmerLeeslamp`:value=30}"} }}},
    1x pressing button until Dimmer turns on/off takes more than 1 minute.
    Edited by Rover
    Something very wrong here... your Scan Max is 6 seconds, so the action executed within 6 seconds... where from comes this delay?
    Did you see the command line on debug appears after 1 minute also?
    Can you change the command to turn on device on HC3? or to try to turn on / off switch and not dimmer.
    If it's fibaro dimmer it could be set for few minutes to turn on off.
    Edited by cag014
    Now on AOQ2 with HC3 switch: delay 2minutes, 48 seconds before switch on and before command line on debug appears.
    "If it's fibaro dimmer it could be set for few minutes to turn on off" ???  It is a Popp wall plug dimmer.
    Everything in the house has a big delay now. Motion sensor until lights on: 28 seconds (slave motionsensor and slave switch).
    Something wrong, have copied and added your lines (just different device IDs) works perfectly with no delay at all.  My AOQ have 170 lines for testing!!!
    Please reboot HC3
    Is anyone else has these huge delays of minutes?
    Please reboot HC3
    Rebooted HC3: delay on AOQ2 1 minute, 31 seconds.
    Maybe there is a problem with the SlaveRemote_centralScene-v2 (Scenemaster), so I tried to use a ZME wallswitch with sceneactivation slave, but this triggers nothing, the showed keyID is not correct and is not to be changed by pushing a button (I wanted 41).
    Reset HC2: Scenemaster to HC3 Wallswitch delay: 1:48 m
    Going back to version 6.0: no improvements.
    I'm lost ?
    Edited by Rover
    I'm lost ?
    The Slave Remote sceneActivation works fine with mine Zwave.me switch...
    Something absolutely went wrong...
    Could you use just one line in jM
    By the way I have released slave emulations in download, please use them
    I am using just 1 line in AOQ2, but delay stay.
    Do these release slave emulations differ from the ones you have published in this forum? These I am using.
    No, just some cosmetics
    Please post your AOQ QA as is
    What could be the reason that at once there are delays between triggering of all sensors and remote controllers (I can see the flickering of a motion sensor) and a very long delay before the actuator has been acting?
    How can I stop AOQ1 totally so that AOQ2 with one line can show the absolute minimum?
