31 minutes ago, cag014 said:
Have tried again to run two AOQs... 50 lines each.
No issues, both run as expected. (Including delayed commands)
Yes, my two AOQ's are running both well too. But the question is: Have been running SlaveSwitches (coupled to whatever device) in the same time?
    Will try it... How many SlaveSwitches?
    (Have a look at the addition in the measurements above).
    I have added 1 SlaveSwitch: Response times: 6,2,5,3 seconds,
    Second SlaveSwitch added: Response times: 12,3,27,3,2,3,7 seconds,
    Third SlaveSwitch added: Response times: 6,19,3,7,4,6 seconds,
    Fourth SlaveSwitch added: Response times: 119,32,14,38 seconds. The last is the hardest one (Fibaro dual relay) but the third one is the other half of the double relay).
    Other question:
    Is one of the present slaves able to serve a Fibaro smoke sensor?
    Edited by Rover
    Other question:
    Try Slave Sensor...
    18 hours ago, cag014 said:
    Try Slave Sensor...
    Yes, SlaveSensor accepts smokesensor.
    The question is now how a smoke or heat alarm is indicated:
    state="alarm=breached" is not accepted, state="value=breached" and state="value=true" are both accepted but which one is the right one? or  both?
    Why is $HC3onLine false?
    13 minutes ago, Rover said:
    No idea... it always like that, at least for me.
    That's the value in settings/info
    Edited by cag014
    Internet is online and Fibaro services too, strange!
    Indeed.. by the way by checking JSON box on hcwebEye, the data will be formatted and shown more convenient.
    Edited by cag014
    I have 7 slave devices and both AOQ still running fast.
    With this User Shortcut AOQ2 will not initiate:
    Please post complete shortcut and where and how in use?
    Don't see any reason why not.
    I'am asking, because when my internet connection was NAT-ed, I couldn't reach my cameras. When I called the internet service to stop the NAT, they started working again.
    A shortcut for recurring text would be nice, like for {"`Pushover`", '+Send_Pushover,json[["&PushoverTitle","&Prio","&PushoverSound","Pipo"]]'}
    the  part {"`Pushover`", '+Send_Pushover,json[["&PushoverTitle","&Prio","&PushoverSound", is used very often in my code.
    But it looks like a User Shortcut is not a sort of text macro...
    Not macro, Lua code
    but I think you can use as follow
    PushStr='json[["&PushoverTitle","&Prio","&PushoverSound",'
    in line use
     {"`Pushover`"+Send_Pushover, PushStr..`"Pipo"]]'},
    @Rover
    I'm still trying to find out why you have such a huge delays... by using external IP to mine HC2 I see same delays... but working fine on internal IP.
    Will try to figure out why, but what I saw it's happens on command with delays... could you please confirm that this is the case?
    I mean do you have problems only in commands with delay in line?
    3 minutes ago, cag014 said:
    @Rover
    No, I do not have problems with delay in line.
    BTW at the moment again hugh delays are present and I am searching too.
    So all commands have a huge time response? not only command with delays?
