Please bear with me as I'm discovering All-in-One. I must say I'm struggling a little bit but definitely keen to progress.
I wrotte the following
{0,"`mPasserelle`",{state="value=true",lineState = {"`lPasserelle`:value=0"},trueAct={"`lPasserelle`","turnOn","","{&Jour_Nuit:value=Nuit}"},falseAct={"`lPasserelle`","turnOff","180"}}},
where
mPasserelle is a a fibaro motion sensor
lPasserelle is fibaro switch that trigger a light
&journuit is a variable that tells me if we're at night.
I'm trying to achieve the following: if a motion sensor detect a move, and that the light ( was not already lit up then lit it up... before swithing it off 3mn later. Doing so only at night (&Jour_Nuit:value=Nuit)
In order to not switch it off if the light was already on, I'm trying to use the linestate condition but I'm struggling to get it work:whatever value I'm putting 0 or 1, it does switch the light on... even if was already on.
any idea what I'm doing wrong will be greatly appreciated... i spend a couple on hours on it... with no success;
Many thanks in advance.
Gael
    9 hours ago, Sjakie said:
    Last night they woke me up twice at2 and 4 o'clock.
    Selected time fa 08:00 to get those messages if event take place between 23:00-08:00
    //Sjakie
    You can disable alert messages (or to choose how to receive them) by setting false in
    eMail       = {true,"2"}  --Send alert to user IDs list. eMail={true,"2,5,20"}
    popupNote   = false -- if true, alert popup notification will send to all users
    pushNote    = {false,"2"}  -- if true, alerts interactive push notification will send
    That's my setup, receive alerts by email only.
    where
    Gael
    Fibaro switch uses value true or false (not 0 or 1).  Please change
     {"`lPasserelle`:value=false"}
    By the way for dimmers use value of 0 or  > 0
    Going forward, you can always to verify what kind of value has a device by API
    http://<HC-IP>/api/devices/<DEV_ID>
    See properties section...
    Edited by cag014
    On 11/3/2020 at 10:49 AM, Rover said:
    Hi @cag014, please have a look at it.
    Edited by Rover
    It should be lowercase and  not AND. Always has been like that.
    @Rover
    Have changed the entire scanning engine to get rid of delays...
    Please try (might be some bugs). Please don't use any slaves, it should work directly.
    Edited by cag014
    @Rover
    So you mean all devices <device>'hc2 and stop all slaves, or delete all slaves, or simple use only <device>'hc2 and let all slaves active without use?
    Many thank Cag. I'll give it a try this evening when I'm back from work :-)
    Good Morning everyone,
    I have a newbie quesiton regarding slave. I'm a bit confused on how to use them in the all-in-one qa.
    - I have added a slaveswitch qa (id on the remote HC:46, id of the slave device:489): this works perfectly fine. I can switch it on & off manually and can use it as a local device in the all-in-one qa by declaring it in jS2n like any local device by refering to his slave device id: "lBatisseExt=489"
    - Having said that, if I try to access it through his remote id, it does not work. It seems it does not recognise the device as a  switch:
    jSlave={
        hcb={user="admin",passwd="xxxx",ip="192.168.1.4"}
    jS2n={
    lBatisseExt="46'hcb"
    jM
    {2,"$blank",{onClock=true, timeLoopAct={"`lBatisseExt`","turnOff"}}},
    Result:
    [09.11.2020] [10:59:22] [DEBUG] [AOQ483]: ☠ [09 Nov 10:59:21] /opt/fibaro/AOQ483.jM hash table:11:~:
    {2,"$blank",{"timeLoopAct"={"46'hcb","turnOff",""},"onClock"=true}}
    (8) Action 'turnOff' not found for ID(46'hcb) Supported actions:
    `lBatisseExt`Bâtisse Extérieur:46'hcb:Bâtisse Extérieur Device's actions are:
    AOQ Supported Actions: (13% in use)
    - addRmd armAlarm delAllRmd delLogRmd delRmd disableScene
    - disarmAlarm emitEvent enableScene killScene logRmd poll
    - powerOutage pressButton reboot rptAction runAction sendEmail
    - sendNote sendPush sendSms sendiPush setColor setConfiguration
    - setGlobal setProfile setRmd setSlider setState setStateDelay
    - setStateFormula setStateValue setTimeDrift setTimeSlot setTimeSpan setValue
    - shutdown startScene tts turnOff turnOn vacOff
    - vacOn verify
    [09.11.2020] [10:59:22] [ERROR] [QUICKAPP483]: QuickApp crashed
    [09.11.2020] [10:59:22] [ERROR] [QUICKAPP483]: main.lua:319: attempt to call a nil value (method 'stop')
    Edited by GaelP
    hi @cag014,
    I got this email twice:
    All-in-One-2 Report (wakeUp)
    Device 23: TestLicht @ KamerHans is wake up Event history: [unplugged 09 Nov 11:36,nack 09 Nov 11:36,wkUp 09 Nov 11:42]
    What does it mean and why did I got this two emails?
    Yes, use <device>'hc2. I suggest to stop/delete slave devices in order to reduce extra load on HC2.
    12 minutes ago, Rover said:
    hi @cag014,
    Any change in number of alerted devices, email generated. Are you sure it's exactly the same email?
    jSlave={
    jS2n={
    jM
    Result:
    - vacOn verify
    Are you sure that the line looks exactly as you posted?
    It's an error... timeLoopAct should be a table not a string... same for onClock, should be a parameter not a string.
    {2,"$blank",{timeLoopAct={"46'hcb","turnOff",""},onClock=true}}
    and yes, you can define in Lua parameter using string format, but this is the syntax for that:
    {2,"$blank",{["timeLoopAct"]={"46'hcb","turnOff",""},["onClock"]=true}}
    Edited by cag014
    It is only one (HC3-)device 23, 2 emails.
    Now I saw also 2 emails a few minutes before:
    All-in-One-1 Alert (Dead)
    Device 23: TestLicht @ KamerHans is dead Event history: [nack 09 Nov 11:36,unplugged 09 Nov 11:36]
    Yes it was exactly the same email (twice).
    So it means that these devices are not visible anymore in the alarm zones? That is the only reason I use slaves...
    BTW this morning I have added (from 2 before) all the D/W sensor slaves to the alarm zones and now arming gets very fast, without repeated verifying ?.
    Edited by Rover
    What I meant that you don't need to use slaves to reduce delays... you can use slaves as much as needed, don't think now it matters...
    I may have created confusion by copying the output of the debug window which is where you see the line formated this way:  9.11.2020] [10:59:22] [DEBUG] [AOQ483]: ☠ [09 Nov 10:59:21] /opt/fibaro/AOQ483.jM hash table:11:~:{2,"$blank",{"timeLoopAct"={"46'hcb","turnOff",""},"onClock"=true}}
    In the actual Jm, the syntax is correct: {2,"$blank",{onClock=true, timeLoopAct={"46'hcb","turnOn"}}},
    I have done the following test:
    if I use {2,"$blank",{onClock=true, timeLoopAct={"489","turnOn"}}},
    -> works (the slave device 489 is defined as "device=46 " in the user data of the slavedevice.)
    but if I use {2,"$blank",{onClock=true, timeLoopAct={"46'hcb","turnOn"}}},
    -> does not work. it returns in the debug window
    2,"$blank",{"timeLoopAct"={"46'hcb","turnOn",""},"onClock"=true}}
    (8) Action 'turnOn' not found for ID(46'hcb) Supported actions:
    and then it crash with "main.lua:319: attempt to call a nil value (method 'stop')
    I'm sure I'm doing smthg stupid but can't figure it out….
    Edited by GaelP
    Just to make sure that in jSlave you do use admin or other user that has access to device?
    Could you please post API of this device?
    http://192.1681.4/api/devices/46
    jSlave={
        hcb={user="admin",passwd="xxx",ip="192.168.1.4"},
    @Rover
    10 minutes ago, GaelP said:
    jSlave={
    According to that AOQ is correct! There is no actions for the device!? (see marked red). What is that device?
    Could you post how it looks in UI (icon), is there buttons on/off?
    36 minutes ago, Rover said:
    Forgot about alarm property...
    This is really weird, this is a FS221. migrated from an HC2 to an HC3 using the HC3 migration tool.
    In the 192.168.1.4 gateways, the device does show a power off /power on button that works fine to on or off the light manually.
    weird as well is that slave qa that refer to this device does work well.
    on the 192.168.1.4, I looked at the api of a few other device that were imported as well: same no actions listed.
    I'll try to forget an reinclude the device and will report.
    OK.
    In any case AOQ has an workaround for that (add + before command)
    {2,"$blank",{onClock=true, timeLoopAct={"46'hcb","+turnOn"}}},
    But using workaround AOQ can't verify validity of the command and execution.
    Thanks for pointing me in the right direction!
    The issue was with the device configuration which was corrupted during the automatic migration from the HC2 to my 2nd HC3. I used the Fibaro migration tool that avoid to reinclude all module… but clearly there is an important issue with this tool as the device configuration seems to get corrupted as all devices shows no action through the api.
    I manually reconfigured the device -did not have to exclude / reinclude-: it did allocate a new ID to the device but at least now the API shows the correct list of actions and the AIO works as expected.
    Result of the api query(94 is the new ID for 46):
    {"id":94,"name":"Batisse Potelet","roomID":222,"view":[{"assetsPath":"/dynamic-plugins/com.fibaro.binarySwitch/assets",...….actions":{"reconfigure":0,"toggle":0,"turnOff":0,"turnOn":0},"created":1604934655,"modified":1604934655,"sortOrder":51}}
    By the way do you recommand to create the device using the slave qa and then to refer to them in AIO as if they were local device or to not create them but use the "deviceid'hcl"  approach in AIO?
    really thanks for taking the time to help me out: clearly the issue was not related to AIO but to Fibaro HC3 migration tool. I'll reconfigure my other device and this should then be ok.
