On 11/3/2020 at 3:08 PM, Rover said:
With also 4 slave switches I ment also the other slaves (except for the 6 smoke sensor slaves (off)).
New measurements with Scenemaster as HC2 Slave and Wallplug switch direct on HC3, AOQ1 and AOQ2 with all lines active and 27 slaves, inclusively 4 slave switches active:
  • inclusively 4 slave switches active: response time 44 seconds.
  • inclusively 2 slave switches active: response time 45 seconds.
  • inclusively 1 slave switch active: response time 13,3,8,25,32 seconds.
  • inclusively 0 slave switches active: response time 1,1,1,1 second.
With all measurements all devices were either <deviceID>'hc2 or slave.
Conclusion stays: SlaveSwitches and SlaveSensors with smokesensor is a nogo!
New measurements with Scenemaster as HC2 Slave and Wallplug switch direct on HC3, AOQ1 and AOQ2 with all lines active and 25 slaves, inclusively 2 SlaveRemote_sceneActivation-v2 coupled to 2 Fibaro Keyfobs active:
  • inclusively 2 keyfob slaves active: response times 95, 68, 184 seconds.
  • 2 keyfob slaves stopped: response times 3, 4, 15, 6, 3, 3 seconds.
Conclusion: also SlaveRemote_sceneActivation-v2 with Fibaro Keyfobs is a nogo!
    The slaves are not in parallel, right? once slave defined it used in AOQ ?
    What do you mean with in parallel? Each have an slave of its own and own AOQ lines.
    For sure a new measurement with keyfob slaves active and usable in AOQ with its own lines: 42, 49, 5, 45, 60 seconds.
    (In this configuration state all motion sensors need a minute to react... I stop the keyfob slaves immediatly before my wife starts a war with heavy weapons).
    Edited by Rover
    44 minutes ago, cag014 said:
    Did some change with slave controllers communication... let's see.
    [05.11.2020] [17:02:16] [WARNING] [AOQ205]: Variable Test not found
    Debug data...
    29 minutes ago, cag014 said:
    Debug data...
    • 2 keyfob slaves active: response times 82, 47, 15, 19, 5, 23 seconds.
    • 2 keyfob slaves stopped: response times 6, 10, 5, 1, 12 seconds
    So no improvement.
    ALSO: arming of 2 D/W sensors (slaves) with verify takes so long that each arming attemp fails in errAct.
    Edited by Rover
    So no improvement.
    Did you see debug line  like
    "TimeResp over [number] to retrieve.....
    Just 1 [DEBUG] line:
    [05.11.2020] [17:38:26] [DEBUG] [AOQ205]: {"&Statuslicht>68":{"type":"T","lTime":1604594174,"act":[["86'hc2","turnOff","180","{&Statuslicht:value=Disarmed}"]]}}
    (with the 2 keyfob slaves stopped)
    Edited by Rover
    With 2 keyfob slaves on (respons wall switch after about 2 minutes):
    [05.11.2020] [18:27:49] [DEBUG] [AOQ204]: TimeResp over 6 to retrive %2FcallAction%3FdeviceID%3D169%26name%3DturnOff
    That's exactly what I said, too slow communication with the slave controller...
    Can you verify proper LAN connection? Connect laptop instead of HC2 and test the speed.
    I saw that while using public IP (instead of LAN internal IP), in some cases delay over 40 seconds.
    The HC2 and HC3 and PC are connected to the same 1 Gbps switch.
    LAN speed test between this PC and other Win10 PC connected to the same switch as HC2 and HC3:
    Edited by Rover
    Edited by Rover
    The HC2 is obviously very busy with..? Nothing to do but possibly communicating with slaves.
    Dont look at the graphic its not realistic.
    The 15% is a real value.
    If you look longer at this screen you see the graphic comming to 15%
    If you hide this page and come back after a few minutes the graphic is complete red.
    //Sjakie
    //Sjakie
    Yes, that is true, but why is the graphic completely red?
    I really dont know but is what I noticed.
    //Sjakie
    On 10/20/2020 at 4:38 PM, cag014 said:
    Right now AOQ doesn't support dates  (like 20/oct/2020), so it couldn't be done by default.
    But you can create userKeyword with function that synchronizes the calendar
    for example
    userKeyWord={{"$myTime","$dayTime"},
        {function () ....... use calender and return timeSlot value end},
    function() return  os.date("*t",os_time()).hour<6 and "Good night," or os.date("*t",os_time()).hour<12 and "Good morning," or os.date("*t",os_time()).hour<18 and "Good afternoon," or os.date("*t",os_time()).hour<=23 and "Good evening," end }}
    in jM use $myTime keyword.
    {0,"..............{.....,timeSlot="$myTime",.......}}},
    BTW - could you post a specific example of calendar dates usage (I believe you refer to holidays) in actions?
    Hi @cag014,
    How can I set this "
    for example
    {0,"..............{.....,timeSlot="$myTime",.......}}},"
    Can you tell me an example?
    I download now the icalendar.fqa file. The QA is working, i see my calendar, but I can't get the calendar values.
    Edited by SmartLifeSystems
    Good morning Cag,
    Is it possible to get this kind of push messages on a selected time?
    - Device 1122: pirHumidity @ toilet is dead Event history: [power 08 Nov 01:11]
    - Device 1122: pirHumidity @ toilet is wake up Event history: [power 08 Nov 01:11,wkUp 08 Nov 01:20]
    In this case 1122 is non excisting
    //Sjakie
    2 hours ago, Sjakie said:
    Good morning Cag,
    //Sjakie
    These messages generated automatically when device is dead and wake ups.
    What do you mean by: at selected time?
    Edited by cag014
    Last night they woke me up twice at2 and 4 o'clock.
    Selected time fa 08:00 to get those messages if event take place between 23:00-08:00
    //Sjakie
