    3 hours ago, SmartLifeSystems said:
    Something wrong. The AOQ all the time restarted.
    What was the last version that you have used before v6.5?
    I'm currently running over 200 lines, no delays and restarts!?
    29 minutes ago, cag014 said:
    Restarts ?..
    Anyone else has same issue?
    no problem at all with 6.5 in my configuration
     I use now the 5.7.
    3 hours ago, cag014 said:
    Restarts ?..
    No restarts.
    But this:
    Edited by Rover
    Back from 6.5 to 6.2 for both AOQ's:
    Edited by Rover
    1 hour ago, Rover said:
    No restarts.
    But this:
    Could you stop the AOQs and post the CPU load?
    3 minutes ago, cag014 said:
    That's absolutely crazy...
    Here two AOQ (one with 175 line and second with 50 lines), including 7 slave devices
    I went back to 6.5 because 6.2 cannot be stopped, but 6.5 also restart immediately after stop.
    Also 6.4 cannot be stopped ?‍♂️
    Both AOQ's stopped:
    Edited by Rover
    17 hours ago, SmartLifeSystems said:
     I use now the 5.7.
    Hi @cag014,
    A tried again the 6.5. Random restarted every 30 sec. For some min no, and started again.
    34 minutes ago, SmartLifeSystems said:
    Hi @cag014,
    OK, now working fine. I didn't upload the new 6.3 fqa.
    After I did it, working fine the AOQ and the CPU load normal too.
    Something wrong. Restarted again. I don't understand. :(
    Could you please post your user_data file?
    5 hours ago, Rover said:
    Both AOQ's stopped:
    So you CPU load is very high regardless AOQ!?
    I am able to stop all version... looks like you have same problem as @SmartLifeSystems - restarts..
    Yes, even if not only stopping, but deleting AOQ1 and AOQ2 the CPU is still crazy.
    But after also deleting the two QA Zone ZC Players from KriKroff (Sonos QA) the HC3 is quieting under 10% ?. Each deletion of this QA took many minutes, while the HC3 was fully unresponsive, a very bad QA!
    Now I am going to build up AOQ again...
    After installing AOQ1 and AOQ2:
    Issue with initiating AOQ for 10 minutes is also over now, very fast initiation ?
    Edited by Rover
    New measurements with Scenemaster as HC2 Slave and Wallplug switch direct on HC3, AOQ1 and AOQ2 with all lines active:
    • All 32 slaves on (with 3 slave smoke sensors and 4 slave switches on): response time wall switch 160 seconds.
    • With 3 slave smoke sensors stopped: response time wall switch 98 seconds.
    • With also 4 slave switches stopped: response time wall switch 3 seconds.
    For me the 6.4 working normaly. No restart.
    OK, will try to install more slaves to see why it impacts on response time...
    Why is value = true red?
