    Just now, Rover said:
    Let's see if it's help...
    Regretfully the response time of everything is still bizar...
    Still delay of minutes?
    Yes.
    9 minutes ago, Rover said:
    Yes.
    Criminals found!
    Yesterday I had to reboot HC3 because of a problem with the old SonosHub QA of 10der (the new one is OK). I forgot that a HC3 reboot starts all slaves again. Before all not D/W slaves were stopped. Now I stopped all not D/W slaves but forgot to stop two keyfob slaves. Still minutes response time. After also stopping the two keyfob slaves: fast response!!!
    I think that all not D/W slaves should be deleted.
    Why does not work
    No difference in call from AOQ or testscene, except for a working testscene and a not working AOQ call...
    At once, AOQ call has worked...
    Edited by Rover
    12 hours ago, SmartLifeSystems said:
    That's the heating scene, what do you see.
    Here is my user data.
    I'm trying to set same conditions that you have, but still have no restarts.
    Question, is restarts are random or it's happens every specific time period? or may be after specific event?
    Edited by cag014
    Continually. When restarted after the update, restarting again and again.
    12 hours ago, Rover said:
    Why does not work
    Could you post Sonos QA?
    The only difference that I can see, is in the last parameter (40).
    AOQ sends that as a string, while in testscene call is a number.
    Please try to send that in testscene as a string also, let's see what it does.
    Edited by cag014
    Meanwhile at once it works in AOQ by wonder...
    TNX, cag!
    OK... let's try to find what line causes the issue.
    Please remark half of jM lines and see if it's works.
    if restarts remark again half of the lines and so on....
    if works, unmark half of the lines and so on....
    I think this method called "to catch the lion in desert" or binary search... hope you understand what I mean...
    OK, I understand. At this week i will do your idea. We will catch the lion. :)
    One more question. For the 6.3, why working correctly?
    Have compared 6.3 to other version and don't see any reason for that....
    I am trying to implement the use of the SonosHub of 10der in AOQ.
    @cag014 could you please help me to implement "addToQueue" followed by "play" in AOQ?
    Edited by Rover
    Is it works when using fibaro.call(212,'"play","192.168.1.19")
    I think you are using ' ' and it's not neccessay (works for json only)
    Try to use normally (without ' ')
    {"212","+play,192.168.1.19"}
    Edited by cag014
    Hello Cag,
    I am back after a lot of problems to get HC3 doing something I want.
    To use slave devices my HC2 didt like at all CPU was 100% and more so HC2 stucked.
    Because the WAF is effected when HC2 is out I stopped for a while.
    I cant stand the HC3 is doing nothing and I reported some issues to Fibaro but there assistance is far from my customer satisfaction.
    After several factory restores the box is running smoothly now (I hope it stays)
    My settings are now to use HC2 as slave.
    All devices are in HC3 JjS2n now and I have a few lines in jM
    I want to do the following
    Toilet >>GV occupied  and free
    If toilet GV occupied > 2 min FanHigh on
    if toilet free FanHigh off after 3 min
    GV will be used in combination with bathroom and kitchen because the fan is common
    Is this a correct approach or must I use keywords instead of GV for it?
    If I use GV I have the next error in line";
    --Door/ pir breached, toilet light and mechVentLaag on
      {0,"`toiletdeur`",
      {state="value=true",
      trueAct={{"`toiletSpottoilet`|`zoldermechVentLaag`","turnOn","","{`toiletpir`:value=false}"},{"`toiletSpottoilet`|`zoldermechVentLaag`","turnOff","","{`toiletpir`:value=true}",{"toiletGlobal","setGlobal","occupied"}},
    falseAct={{"toiletGlobal","setGlobal","free","{`dwGrpAanwezigState`:value=false}"}},
    Please advice,
    //Sjakie
    using in scene fibaro.call(212, "play", "192.168.1.19")  delivers the same error as the AOQ string, so it must have something to do with playing an empty queue.
    It looks like you have to json.encode something.
    @cag014: do not seeking further to help me operate SonosHub QA.
    This SonosHub QA is too difficult to operate, too few error handling.
    So I am going further with the Sonos QA of Krikroff : Sonos Zone Controller 1.3.1 RC.
    Edited by Rover
    @SmartLifeSystems,
    Its already in? I have version 7.9
    Just above
    AOQ PARAMETERS
    {0, "$RAM",{state="value>85",trueAct={{"RAM>85%","sendNote","Warning. \nSystem memory is $RAM% ",true},{"|$lineId|","setStateValue","80"}},falseAct={{"|$lineId|","setStateValue","85"},{"RAM<80%","sendNote","System memory is $RAM%"}}}},
