    10 hours ago, Rover said:
    Hi @cag014,
    I am using version 8.6 now. Is version 9.0 at Downloads different?
    No, just some cosmetic stuff for reboot comand.
    Hi @cag014,
    Why has device Licht1 color rose, while the other devices have a green color? (Hint: Licht1 is a HC3 device and the other devices are HC2 slaves).
    Why are the conditions of lineState not also shown? They are also a part of the total activation condition, aren't they?
    On 12/11/2020 at 4:00 PM, Rover said:
    Hi @cag014,
    Currently lineState condition not displayed because  I'm didn't find yet proper way to display that among command conditions. Each line could have many commands and I don't think to display lineState with every command is the right solution (too many repeated data).
    Regarding the color it means that the previous executed command for Licht1 was the same command (in this case turnOff).
    Previous executed command for Licht1 was the same command ???
    17 hours ago, Rover said:
    It means turnOff was the last executed command and you're sending turnOff again.
    This is not an error, just some tracking mechanism to make sure that you don't executed same command over and over...
    I have showed in the previous message that turnOn after turnOff produces the same rose color.
    Yet, another bug... same device number in slave and HC3.
    Fixed, use attached
    Hi @cag014
    Can you help me? I bought a BlitzWolf wifi wallplug, and for this device I uploaded the SlaveSwitch app.
    How can I setup this device?
    What is the sampleRate?
    Now I have an error message.
    What did I wrong?
    /monthly_2020_12/329491484_Kepernyofoto2020-12-14-15_44_04.png.6bc4aea2f1e718001ba97a7b5664b8e5.png" />
    14 minutes ago, SmartLifeSystems said:
    Hi @cag014
    What did I wrong?
    Is this device included in HC3?
    If yes, please post device API
    No, it's not included. I only upload the SlaveSwitch app.
    No I'am here now. I never used yet wifi device, and i can't how adding in the HC3.
    The slaveSwitch QA is for devices included in HC controllers only.
    To include your wifi device you need the API of the item. Like how to send commands and receive data from the device.
    How can I look this device's API?
    I found something, but I don't know how can I use.
    @cag014, can you help me?
    What you sent, is the configuration file when you re-flashing the device wifi chip to use ESPHome system.
    Are you going to reflash the device?
    I would like use in HC3, but I don't know how.
    You do need to get an API commands of the device for that.
    By the way, do you have an application for PC to control the device?
    Edited by cag014
    I haven't app for PC, and I don't find.
    But I found a template. Sorry, but I absolutely stupid for the wifi devices.
    Again, this template is for the device, requires to disassembly the device and to reflashed for better performances.
    So I think, I can't use this device with the HC3...
