Hello Cag,
I noticed a few thing when AllinOne restarts;
This line makes the light flicker, it should light its within the time slot?
>>{0, "`hallocatieGezin`|`hoofdSlaapKamerlader`",{state="value=true",timeSlot="07:00~23:45",
trueAct={"`woonKamerkerstboom`","turnOn",""},
falseAct={"`woonKamerkerstboom`","turnOff",""}}},
>>the light lights up at 7:01 instead off 07:00
Remark: HC2 Slave>>hallocatieGezin`|`hoofdSlaapKamerlader
              HC3 device>> woonKamerkerstboom
//Sjakie
    Yes, I'm doing mathematical calculation if time > timeSLot, so the timeSlot starts  at 7.01 and initializes the line according to the state status (true/false).
    Regarding is it flickers when timeSlot starts?
    Please verify that `hallocatieGezin`|`hoofdSlaapKamerlader` are  in the same status. If one of them true and other is false then it will flicker.... you can add initOnStarup=false to stop initialization at restart and when timeSlot starts or to set one of the actions (trueAct or falseAct) to avoid initialization.
    for example:
    trueAct={"`woonKamerkerstboom`","turnOn",false},
    It means do not initialize trueAct{} only
    Edited by cag014
    1 hour ago, SmartLifeSystems said:
    Hi @cag014,
    How can i set up this?: if the RAM > 85% reboot the HC3.
    Add reboot command and I suggest with few seconds of delay (to make sure that notification sent)
    See marked changes...
    {0, "$RAM",{state="value>85",trueAct={{"RAM>85%","sendNote","Warning. \nSystem memory is $RAM%, rebooting... ",true},{"","reboot","10"},{"|$lineId|","setStateValue","80"}},falseAct={{"|$lineId|","setStateValue","85"},{"RAM<80%","sendNote","System memory is $RAM%"}}}},
    Cag,
    This drives me crazy!
    This error didt come the whole morning and suddenly I saw it?
    line 371 error (empty line between ,  and --CURTAINS
    unexpected symbol near '}'
    --Mainbedroom Charger on, all inside lights off
    {0,"`hoofdSlaapKamerlader`",{state="value=true",
    trueAct={"`woonKamerverlbasis`|`woonKamerverlabsent`|`woonKamerverltvuit`|`woonKamerverltvaan`","turnOff","","{`hoofdSlaapKamerlader`:value=on}"}}}},
    --CURTAINS------------------------------  sjakie
    6 hours ago, Rover said:
    using in scene fibaro.call(212, "play", "192.168.1.19")  delivers the same error as the AOQ string, so it must have something to do with playing an empty queue.
    @cag014
    Again I am not smart enough to implement Sonos operation on AOQ, now with Sonos ZC of Krikroff:
    {"`SonosZoneControllerKeuken`", '+playFile,"Mediacenter/d/SonosGeluiden/Deurbel.mp3",true,40'},  works!
    But
    {"`SonosZoneControllerKeuken`", '+addURIToQueue,"Mediacenter/d/SonosGeluiden/Deurbel.mp3"'},
    followed by
    {"`SonosZoneControllerKeuken`", "+playSavedQueue"},
    or
    {"`SonosZoneControllerKeuken`", "+startQueue"},
    does not produce a sound.
    Maybe it is the main problem how to get a mp3 in the Sonos queue?
    8 hours ago, Sjakie said:
    Cag,
    Yes you have an error too many curly brackets at the end. Please remove one.
    trueAct={"`woonKamerverlbasis`|`woonKamerverlabsent`|`woonKamerverltvuit`|`woonKamerverltvaan`","turnOff","","{`hoofdSlaapKamerlader`:value=on}"}}},
    5 hours ago, Rover said:
    @cag014
    But
    followed by
    or
    OK, will try to see what the problem is...
    Good morning Cag,
    In debug you see some actions of <id>HC2
    Manualy I switched in HC3 devices 3 pieces of wall plugs at 08:13 NOT visible???
    I have also one motion sensor not visible???
    Those devices are HC3 devices.
    What to do?
    //Sjakie
    Hi @cag014,
    I think I find the restart problem. Look, this is very interesting.
    So I use the Satel Integra AlarmSystem's sensors. I think, the problem is the motion sensor.
    Example: If I breached the motion sensor in the livingroom, the AOQ is restarting. If I breached the MS 3 times, the AOQ is restarting 3 times, in every minutes.
    Look the times on the screenshot.
    When I breach the MS, the AOQ is restarting xx:xx:09, xx:yy:09, ...
    Cag,
    I have a few devices that triggers a lot of other things.
    In debug I see AllinOne is combining that device with all actions in one line.
    Can I do for a better reading and understanding:
        trueAct={"`stekkers`|`stekkersvertraagd`|`stekkersuit`","turnOff","","{`hallocatieGezin`:value=off}"},
        trueAct={"`woonKamerverlbasis`|`woonKamerverlabsent`|`woonKamerverltvuit`|`woonKamerverltvaan`|`voorTuinSpotvlag`","turnOff","","{`hoofdSlaapKamerlader`:value=on}"}}},
        falseAct={"`stekkers`|`stekkersvertraagd`","turnOn",""}}},
    If yes is there a limit on the number of true or false acts?
    //Sjakie
    And another problem. I useing iPhone, and in every push notifications have a \n characters, between the subject, and the message.
    @SmartLifeSystemsI have the same on my IPhone.
    //Sjakie
    //Sjakie
    So I'am not alone with this problem. :)
    @Sjakie how many phone what do your AOQ useing for the notifications?
    If this was the biggest problem at the moment with my HC3 I should be a happy camper!
    I am busy to convert my scenes into AllinOne so I face a lot of "problems".
    But I know what the problem is>> the user behind the keyboard!
    //Sjakie
    Hi, all,
    Can one of you give me some examples of arming/disarming?
    Thanks in advance,
    //Sjakie
    2 hours ago, Sjakie said:
    Cag,
    //Sjakie
    No limit... but all actions must be in the same array. Means  only one  trueAct{}  table (or any other) could be defined.
    According to that please include all trueAct in one table, same for others.
    When defining more than one command the action table starts and ends with double curly brackets and please keep correct number of brackets.
        trueAct={{"`stekkers`|`stekkersvertraagd`|`stekkersuit`","turnOff","","{`hallocatieGezin`:value=off}"}, {"`woonKamerverlbasis`|`woonKamerverlabsent`|`woonKamerverltvuit`|`woonKamerverltvaan`|`voorTuinSpotvlag`","turnOff","","{`hoofdSlaapKamerlader`:value=on}"}},
    By the way if same action table defined more than once, only the last table will be executed.
    Edited by cag014
    4 minutes ago, Sjakie said:
    Hi, all,
    Thanks in advance,
    //Sjakie
    What do you mean?
    Example I use the GPS localization for the DayArming, and PanicButton for the Night Arming.
    Edited by SmartLifeSystems
    2 hours ago, SmartLifeSystems said:
    Hi @cag014,
    OK, at least we're moving forward.
    Please post this sensor API
    http://<hc-IP>/api/devices/<Satel Integra sensor-ID>
    Here is:
    Just now, SmartLifeSystems said:
    Here is:
    That's will true for all Satel sensors?
    @cag014,
    This is a D/W sensor for satel, if this help for you.
    @cag014,
    Question, are these sensors included in HC3 alarm zones?
