8 hours ago, cag014 said:
The lineState status is displayed, but commands conditions probably not true and not executed....
The line is:
{5,"`BewegingHuiskamer`|`BewegingKeuken`",{initOnStartup=false,state="value=false",lineState={"if {&KerstPeriode:value=Ja and &Lichten:value=Uit}"},
    timeLoopAct={"`Kerstverlichting`","turnOff","if {`BewegingHuiskamer`,`BewegingKeuken`:lastBreached>900 and `Kerstboom`:value=true}"},}},
/monthly_2021_01/screenshot-hc3-00005529.local-2021_01.17-01-44-12.png.6a24d5ce8ff81fb6184df4ab7d96fdfe.png" />
My point was: why displaying this every 5 minutes while the two devices (motion sensors) itself have not been triggered at all?
    1 minute ago, Rover said:
    The line is:
    That's strange... lineState tested only when the command is about to be executed.
    Could you please post this jM line?
    7 hours ago, cag014 said:
    Do you think this is better when the lineState is true and only when command executed to display the state?
    What about displaying lineState false? In this case the commands are not executed also.... but from other hand it could be disabled by setting dbgFalseState to false.
    To display true lineState when commands executed for me is a matter of seconds to change the code....
    Let me know what do you think about it?
    I'll be glad to have an opinion of other users also...
    Display only when device value (or GV) has been changed.
    I had posted the jM line in the beginning of the message:
    So it sounds like @gggizmo suggested
    No, that is a discussion about the lineState. I only mean that without changes in a device value ("`BewegingHuiskamer`|`BewegingKeuken`") displaying anything has no use.
    12 minutes ago, cag014 said:
    Yes, this is correct...
    What do you think should be the default setup for
    dbgTrueState=?
    dbgFalseState=?
    To my opinion both should be set to false by default .
    yep, i agree, useless to debug something till it's working as expected
    dbgTrueState=?
    dbgFalseState=?
    I agree.
    It has to do with timeLoopAct. Only this line has the issue.
    You have time span of 5 minutes, meaning while devices at false state every five minutes timeLoopAct {} executed, that's why LineState displayed altought the command not executed due to its condition.
    Yes, that's what is does, but how to avoid the display each 5 minutes while the command not executed?
    That's exactly @gggizmo suggestion, to set dbgTrueState to false and only if the command executed the LineState is deisplayed.
    Attached version works as suggested by @gggizmo
    By default
    dbgTrueState=false (show lineState only if the command executed)
    dbgFalseState=false (if lineState is false , nothing displayed)
    Please set dbgTrueState and dbgFalseState per your choice.
    By default
    v10.3 reboots AOQ every minute...
    Strange... in any case attached version includes states for action tables also. (just add word  "State" to action table name: initACt={} -> initActState={} )
    for example:
    Standard format -
    {0,"$24clock",{state="02:00", trueAct{{"200","turnOn","{&GV:value=start}"},{"300","open","{&GV:value=start}"},{"400","setValue,90","{&GV:value=start}"}},
    falseAct{{"200","turnOff","{&GV:value=stop}"},{"300","close","{&GV:value=stop}"},{"400","setValue,0","{&GV:value=stop}"}}}},
    Now you can set condition for entire action array separately. More convenient way to define and to maintain
    {0,"$24clock",{state="02:00", trueActState="{&GV:value=start}", trueAct{{"200","turnOn",},{"300","open"},{"400","setValue,90"}},
    falseActState="{&GV:value=stop}", falseAct{{"200","turnOff"},{"300","close"},{"400","setValue,0"}}}},
    In addition
    1. new debug variable have added:
    dbgInfo=true by setting to false not states will be displayed. (Default set to true)
    dbgInfo     = true -- display states conditions according to dbgTrueState/dbgFalseState
    dbgTrueState= false -- display line and action states when condition is true
    dbgFalseState= true -- display line and action states when condition is false
    2. ;else; statement could be used in conjunction with action state also
    {0,"$24clock",{state="02:00", trueActState="{&GV:value=start}", trueAct{{"200","turnOn;else;turnOff",},{"300","open;else;close"},{"400","setValue,90;else;setValue,0"}}}},
    Please note, when conditional parameter defined in command, action state is ignored as part of else condition
    {0,"$24clock",{state="02:00", trueActState="{&GV:value=start}", trueAct{{"200","turnOn;else;turnOff","{200:state=false}"},{"300","open;else;close"},{"400","setValue,90;else;setValue,0"}}}},
    in example above device 200 truns on/off according to his own state only. Means if trueActState is false the command will not be executed at all
    3. lineState and action tables state could be defined as a table or as a string
    lineState={"{200:value=0}"}     or   lineState="{200:value=0}"
    trueActState={"{200:value=0}"}     or   trueActState="{200:value=0}"
    and etc.
    Currently in HcWebEye view every command will be displayed with if condition of action table state.... working to display it correctly.
    Edited by cag014
    [18.01.2021] [09:33:17] [ERROR] [QUICKAPP1385]: QuickApp crashed[18.01.2021] [09:33:17] [ERROR] [QUICKAPP1385]: main.lua:729: 'end' expected (to close 'function' at line 726) near 'gData'
    20 minutes ago, gggizmo said:
    10.4
    Are you sure?
    Have tried on entire new QA - no errors
    5 hours ago, cag014 said:
    Are you sure?
    i rebooted hc3 and no error anymore
    for example:
    Standard format -
    In addition
    and etc.
    v10.4 installs without issues.
    Isn't time to specify a nice icon for All-in-One?
    You are welcome, I accept any idea
    Edited by cag014
    AOQ icons ON/OFF
    Looks OK
    Edited by cag014
