    1 minute ago, Rover said:
    Not sending notifications if dead is desired. Also not sending comands to dead device is preferred. But why not neglect condition of dead device instead of pretending a defined value ?
    You're using true/false state of device, right? But let assume user uses power value in conditions or calculation.
    I keep tracking air conditioners in my home by checking the power (it turned on/off by infra remotes). (i have 7 of them).
    In many cases kids left AC turned ON when they left the room, so I turn them off if no motion detected in the room for certain time.
    So I have the power of the device as part of the condition to turn off the AC switch and 'AC':power<200 couldn't be replaced by dead=true
    By the way using predefined values is exactly the same as using dead=true.
    if you have 'Wplug`:value=true  and in case it's dead you setting this to true, I don't see the different when the value is set to true when the device is dead in the table. It's exactly the same, but has more option to define other properties in case device is dead.
    Yes, I am using true/false state of device.
    Indeed 'AC':power<200 couldn't be replaced by dead=true, because with a removed wallplug no power measurement is possible at all.
    I do not comprehence "By the way using predefined values is exactly the same as using dead=true". Has this the same effect as neglecting a device condition?
    14 hours ago, cag014 said:
    `WallPlug2`:dead=true
    Works?
    To all,
    Although the commands in AOR user functions are in HC3 format, it does support HC2 also. Meams you can use AOR to control HC2 while HC3 could be a slave.
    I believe in answers to @AR27690 question, if HC2 could have slaves controllers.
    Please note that the user functions executed not in parallel and could have an impact on AOR performances. Please keep the function simple as much as possible and try to avoid any delays or loops.
    Edited by cag014
    9 hours ago, Rover said:
    Works?
    And now how to stop the "dead" notifications?
    set
    wakeUpRate  = 0
    Now only for the first time when device is dead you will receive notification for that.
    Edited by cag014
    1 hour ago, cag014 said:
    set
    wakeUpRate  = 0
    I already had set wakeUpRate  = 0 in both AOS, but the dead notifications are coming back again.
    looks like somehow  your device is waking up
    Do you have anything in the system that tries to communicate with the device?
    What about polling setting in your system?
    Please exclude the device from polling
    Edited by cag014
    Attached AOR version could be run on VS code and/or on ZeroBrane (previous released version has been intended to run on VS code only)
    Edited by cag014
    In order to use VS code and ZeroBrane at same project directory, unzip attached file in your project
    Edited by cag014
    Yes, the standard polling state of Fibaro Wall Plug E/F is global polling. Useful?
    I have excluded the device from polling.
    Hello Cag,
    How to write if internet connection HC3 is lost for 15 min
    <{0, "$internet",{state="value=online",
      trueAct={"`wallSocket`","turnOn","","},
      falseAct={"`wallSocket`","turnOff","(15*60)","`wallSocket`","turnOn","","}}},>
    Please advice,
    //Sjakie
    I'm a little bit confused here..
    Looking on your line you're turning wallSocket ON if internet on line and off line!?
    Do you want to turn ON wallSocket when internet is off line over 15 minutes and when is back on line to turn OFF?
    If so, then
      trueAct={"`wallSocket`","turnOff"},
      falseAct={"`wallSocket`","turnOn","900"}}},
    Sorry for not being clear.
    Online wallsocket is On
    After lets say 5 min no connection>>wallsocket Off>>wait 2 minutes>> wallsocket On.
    If internet connection HC3 is off wallsocket will restart my router because he failed after breakdown ISP.
    About dead devices
    Dead device window sensor (3 notifications because off sensor,temp and alarmtemp)
    6 minutes later again 3 notifications  device wake up>>>excelent
    Question can alert only send on main device?>>less notifications and main is leading
    Is AllinOne waking up the dead device? If yes a delay to prevent this notifications or is there something wrong with that device?
    Waiting your excellent advice,
    //Sjakie
    21 hours ago, SmartLifeSystems said:
    Hi @cag014!
    You got the old profile? :)
    Yes, finally Fibaro has successfully restored my user at the forum
    Sorry about late response...
    There are several options to perform what you need...
    1. - the simple option
      trueAct={"`wallSocket`","turnOn"},
      falseAct={{"`wallSocket`","turnOff","300"},{"`wallSocket`","turnOn","420"}}}},
    2.  - Here you can to add commands in timeLoopAct{} table to restart router and others..
    {0, "$internet",{state="value=online",  trueAct={"`wallSocket`","turnOn"},  falseAct={{"`wallSocket`","turnOff","300"}}},
    {120,"`walSocket`",{state="false", timeLoopAct={"`wallSocket`","turnOn"}}},
    Cag no problem at all I am glad for your srvice excellent! Thanks!
    second part gives error I cant detect whats wrong
    <{120,"`halrouterAsus`",{state="false",timeloopAct={"`halrouterAsus`","turnOn"}}},>
    main.lua:465: attempt to call a nil value (method 'stop')
    timeLoopAct not timeloopAct (capital L)
    Hey Cag!
    Im in the starting process with this scene, and I'm trying to get the geoAction to work.
    I can se my devices and users, but I cant seem to get the "enter" or "leave" part to work.
    geoAction is NA
    /monthly_2021_02/image.png.e3b1e5248a2a4d41c9d0c16218d2af63.png" />
    You know what I'm missing?
    Geofencing is activated in the app etc.
    I followed the guides.
    Best Regards
    Martin
