For me working correctly the push messages. With this update, no send the push messages to my all phones, only for that one, which is in the JM line added.
Edited by SmartLifeSystems
No problems with 5.070?
    What do you mean only in the jM line?
    Looks like push notifications work with mobile device ID only (user ID not supported in QA anymore)
    Please after an update change push notification to mobile ID of the user.
    Edited by cag014
    If I add in the line only my phone, only my phone get the notifications. For me was not so till now. Every phone got the notifications.
    Only problem, what I see, I can't change the Satel Integra alarm system icons.
    So it was a bug in the system!?
    Yes it was. I have 3 Iphones and not worked correctly.
    Hi Cag014,
    Hi Cag014,
    I am having some issues and your recommendation is highly appreciated.
    Simple jM command line I am using leads to the below error message.
    My Dimmerlight is a dimmer ( ID 130 ) which I want to set at value 22.
    Any suggestion is welcomed.
    {0,"$24clock",{state="value=0",timeSlot="?$sunsetHour+2700?~,~?$sunriseHour-2700?",trueAct={"`Dimmerlights`","setValue,22","",false},falseAct={"`Dimmerlights`","turnOff","",false}}},
    [23.03.2021] [21:42:04] [DEBUG] [AOQ1636]:  [23 Mar 21:42:04] AOQ16369.5 jM hash table:7:~: {0, "$24clock"...}
    {0,"$24clock",{"timeSlot"="?$sunsetHour+2700?~,~?$sunriseHour-2700?","trueAct"={"130","setValue,22","",false,false},"falseAct"={"130","turnOff","",false},"state"="value=0"}}
    (8) Action 'setValue' not found for ID(130) Supported actions:
    `Dimmerlights`Dimmer lights:130:Front court Device's actions are:
    User Defined Actions:
    - turnOn turnOff
    AOQ Supported Actions: (11% in use)
    - addRmd armAlarm debug delAllRmd delLogRmd delRmd
    - disableScene disarmAlarm emitEvent enableScene error killScene
    - logRmd poll powerOutage pressButton reboot rptAction
    - runAction sendEmail sendNote sendPush sendSms sendiPush
    - setConfiguration setGlobal setProfile setRmd setSlider setState
    - setStateDelay setStateFormula setStateValue setTimeDrift setTimeSlot setTimeSpan
    - shutdown startScene trace tts vacOff vacOn
    - verify warning
    3 hours ago, Dann said:
    Hi Cag014,
    Hi Cag014,
    Strange... looks like AOQ cannot find any valid actions for the device.
    Are you sure you're using correct device ID? I mean this is not a parent device...
    Could you please post API of the device?
    http://<hc3-IP>/api/devices/130
    Edited by cag014
    I am away from that location ( so no LAN connected for the moment ).
    Anyhow, please see a shot of picture I took with the relevant datas.
    12 hours ago, Dann said:
    Hi Cag014,
    Hi Cag014,
    - turnOn turnOff
    - verify warning
    After transition of devices from HC2 to HC3 a lot of actions are not valid anymore. Soft reconfiguration helps.
    Even if you did not came from HC2 soft reconfiguration could help.
    Thanks Rover,
    Indeed, after soft reconfigure on ID 130 ( I did not came from HC2 ) now is working.
    Surprise, surprise, we got an Easter present from @cag014 ?: AOQ version 11.3 in the Downloads.
    Especially the new State features in conditional settings are super useful ?
    Have a look at the updated Advanced User Guide.
    Edited by Rover
    Hi @cag,
    No GV conditions possible in trueActState?
    4 hours ago, Rover said:
    Hi @cag,
    Strange.. it does work for me
    Could you please post an example?
    Have tested your line and it works fine..
    Could you please explain what exactly doesn't work
    Now  I can see the syntax errors:
    1.
    trueActState={”&Huisstatus:value=Weg”}
    Should be
    trueActState={”{&Huisstatus:value=Weg}”}
    or
    trueActState="{&Huisstatus:value=Weg}"
    The format of actions state is the same as lineState or in command condition.
    2. Another issue at the end of the line there are too many commas and curly brackets (not the correct order):
    {"$geoAction", {state="enter", lineState={"if {&Geofencing:value=Aan and &BlockGeofencing:value=Uit and &Huisstatus:value=Weg}"},
     trueAct={ {"Geofencing","sendEmail,2","Komt er aan","if{&Statuslicht:value<>Disarming}"}, {"&SwitchScene","setGlobal","Disarm"},
        {"&PushoverMessage","setGlobal","Geofencing","if{&Statuslicht:value<>Disarming}"}, }, }},
    1.
    Should be
    or
    I have been trapped again by copying text of the Advanced User Guide: {0,400”,{ trueActState=”{600:power<60}” etc. : the quotes are of the wrong kind.
    Please update all quotes in the Advanced User Guide in order to help everyone not becoming the same errors.
    trueActState={”{&Huisstatus:value=Weg}”}, works: TNX cag.
    What do you mean with point 2: too many commas and curly brackets (not the correct order):
    - The number of curly brackets is OK
    - The order is correct
    - What about too many commas? I am using the commas the make clear what the end is of f.i. trueAct section. The commas do not make trouble, your parsing is fine!
    Edited by Rover
