    1 minute ago, MartinBeck said:
    Hey Cag!
    Im in the starting process with this scene, and I'm trying to get the geoAction to work.
    I can se my devices and users, but I cant seem to get the "enter" or "leave" part to work.
    geoAction is NA
    You know what I'm missing?
    Geofencing is activated in the app etc.
    I followed the guides.
    Best Regards
    Martin
    Could you please post the jM line?
    You need to set the state .. state="enter" or state="leave"
    For the first run the value is NA (not available), till geoFence will be sent by application.
    {0,"$geoAction",{state="value"}},
    {0,"$geoAction",{state="enter", trueAct={"`Stalampe`","turnOn"},falseAct={"`Stalampe`","turnOff"}}},
    Do I have to leave the house, and come back? or will the state turn to enter as I am at home?
    Edited by MartinBeck
    The first line does nothing... and of course the state="value" will never work.
    The second line looks OK and should work  when any user will enter or leave the area.
    Ok! Thanks. Will give it a try then :)
    Cag, sorry for the typo but still same error
    <  {120,"`halrouterAsus`",{state="false",timeLoopAct={"`halrouterAsus`","turnOn"}}},>
    //Sjakie
    //Sjakie
    Could you post the screen of the error?
    Cag,
    [21.02.2021] [11:41:27] [ERROR] [QUICKAPP1197]: main.lua:1387: attempt to concatenate a nil value
    //Sjakie
    That's interesting .
    Please post jP2n and  jS2n table.. I want to see how halrouterAsus has defined to try on my system
    Great..
    Let me know if it works
    Cag,
    the other line has no error
    jS2n={halrouterAsus=1157}
    --====================== USER SHORTCUTS
    --sampleTrue={"`device`","turnOff","10"}
    --================== jM{} lines
    jM={
    {0,"$internet",{state="value=online",
      trueAct={"`halrouterAsus`","turnOn"},
      falseAct={{"`halrouterAsus`","turnOff","300"},{"`halrouterAsus`","turnOn","420"}}}},
    //Sjakie
    4 hours ago, Sjakie said:
    Cag,
    jM={
    //Sjakie
    Works fine on my system.
    Could be you have some kind of error on adjacent jM line?
    Cag, thanks,
    If I take out this line I dont get anny error.
    Did a update >>10.9 error gone, wierd.
    thanks
    //Sjakie
    20 hours ago, cag014 said:
    Great..
    So.. it doesn't work. I read the whole thread on "GPS doesn't work - no location reports"
    -It worked one time when i pushed "refresh network data" in the old app (iPhone).
    My phone turned up in your nice system and had the state "enter", so the scene turned on my test-lamp.
    Since nothing more happend and it only happened once i tried to log out of the apps and connect localy. (without fibaro-ID. After this I connected to the apps using public IP:8080. Works fine, but still no GPS.
    One of my devices:
    My superuser (ID: 2):
    Do you know what i can try next?
    Kind Regards
    Martin
    First of all I do believe that you have setup your phone correctly (including iPhone sleep mode), in addition  I've found that Android phone works better... but it doesn't help you right now.
    Please try to use new Home center app.
    Cag, thanks,
    thanks
    //Sjakie
    That's strange...
    Is any iPhone user uses GPS option in AOQ/AOS and it does work?
    Cag,
    Sorry I have aIPhone but didt use geo.
    <{0,"$geoAction",{state="enter", trueAct={"`woonKamerLinks`","turnOn"},falseAct={"`woonKamerLinks`","turnOff"}}}, >
    If I do this it should work?
    I asume I need to step out the range given in location in HC3?
    Or can I do something now at home without leaving?(I am lazy)
    //Sjakie
    8 hours ago, Sjakie said:
    Cag,
    //Sjakie
    No, you need to change the location and be outside of the location radius
    I use geoAction in AOQ, but it do not function.
    This is my HC3 user data with wrong location data and location time (2012?):
    Edited by Rover
    In HC3 the user location data is not updated, but the geoFencing does work.
    Did you defined properly locations in General->Location?
    Try new app and follow setup procedure
    Edited by cag014
    @SmartLifeSystems
    Is GPS still works for you?
    34 minutes ago, cag014 said:
    @SmartLifeSystems
    Yes, working fine for me.
    This problem was on my HC2. But on my HC3 working correctly the geolocation.
    Somebody tried the 5.062 Beta? Working correctly the AOQ?
