    13 hours ago, Rover said:
    {"Voordeur","sendEmail,2","Voordeurstatus: @`Voordeur`>value"},
    `Voordeur` is a AEON DW-sensor.
    Because values are intended to use in calculations, so true and false converted automatically to numeric values....
    On 1/14/2021 at 1:46 AM, cag014 said:
    I think this is my bad... if you remember have added extra trigger for $24clock and disabled the standard refreshState trigger.
    Anyhow try attached version (both triggers in place)
    in addition:
    1. Added an option to skip time-span definition when not required.
    Standard format:
    {0,"DevID", {state="value=true", truAct{…}}},
    New optional format
    {"DevID", {state="value=true", truAct{…}}},
    Super fast again ?
    The attached version displays lineState condition before commands execution.
    By default true and false states are shown
    By default (if variables are not defined) both states are displayed.
    In addition I intend to add state for each action array, something like
    trueState - condition for all commands in trueAct{}
    falseState - condition for all commands in falseAct{}
    timeLoopState- condition for all commands in timeLoopAct{}
    and etc....
    Works and looks super !!!
    What about All-in-One Scene for HC2, is it possible to have same debug information ?
    Yes, work in progress...
    In next release user can choose table or debug view, while HcWebEye will support table view (same as for HC3)
    and etc...
    v10.2 is much faster ?
    Amazing fast, what took many seconds before (one action in one second) is done now into 1 second.  what happened?
    Edited by Rover
    Just an extra trigger which works when the z-wave is busy or no activity at all.
    Now it always respond and not only when the system triggers the events...
    The lineState status is displayed, but commands conditions probably not true and not executed....
    1 hour ago, Rover said:
    Do you think this is better when the lineState is true and only when command executed to display the state?
    What about displaying lineState false? In this case the commands are not executed also.... but from other hand it could be disabled by setting dbgFalseState to false.
    To display true lineState when commands executed for me is a matter of seconds to change the code....
    Let me know what do you think about it?
    I'll be glad to have an opinion of other users also...
    Edited by cag014
    what about something more granular?
    dbgtruestate=true
    dbgtruestateaction=true
    and aoq shows line state always
    if dbgtruestateaction=false
    aoq shows linestate if action is excuted.
    Just a suggestion i really don't  know how complex may be to implement this kind of debug.
    dbgtruestate=true
    Nice Idea... so be it.
    By the way I'm adding trueActState, falseActState and etc. (means the trueActState has a condition for entire trueAct{} commands. No need to write same condition for every command)
    Should they displayed the same, using same global variable?
    Sorry cag014 it's not clear to me what do you mean
    Currently we're talking about displaying lineState condition.
    In next version I'm adding condition array for every action table, for example:
    Here the standard jM line
    {0,"$24clock",{state="02:00", trueAct{{"200","turnOn","{&GV:value=start}"},{"300","open","{&GV:value=start}"},{"400","setValue,90","{&GV:value=start}"}},
    falseAct{{"200","turnOff","{&GV:value=stop}"},{"300","close","{&GV:value=stop}"},{"400","setValue,0","{&GV:value=stop}"}}}},
    Now you'll be able to set condition for every action array separately (of course this is in addition to the lineState defintion). More convenient way to define and to maintain
    {0,"$24clock",{state="02:00", trueActState="{&GV:value=start}", trueAct{{"200","turnOn",},{"300","open"},{"400","setValue,90"}},
    falseActState="{&GV:value=stop}", falseAct{{"200","turnOff"},{"300","close"},{"400","setValue,0"}}}},
    So I believe same debug logic goes here as well
    I missed previous posts about new version. So you think to use same debug control vars to show linestate and actstate following same logic suggested in my previous post.
    Yes, this is correct...
    What do you think should be the default setup for
    dbgTrueState=?
    dbgFalseState=?
    To my opinion both should be set to false by default .
    Edited by cag014
