All-in-One Scene: How to do it Better
cag014
8 hours ago, cag014 said:
I'm using local variables
global4local= {true,gVarName="localTank",varArray={acInd="init:0",iDoor="init:0",rclr=0,gclr=0,bclr=0}}
Setting variables where is needed and using setColor command
"setColor,&rclr,&gclr,&bclr,0"
By the way have RGBW device which changes random color every hour (just for fun) like that
"setColor,?random(10,255)?,?random(10,255)?,?random(10,255)?,0"
TNX @cag014, nice solution.
Funny application ?
Hi cag,
I have a question for you.
I have a Fibaro Single Switch, and I want to use the This Year energy data in a global varriable. How can I do this?
What is the code, what I need?
Thanks!
Edited by SmartLifeSystems
13 hours ago, Rover said:
Yes, setColor works. I have used that already for a long time. And it also in the action set of RGBW 2.
But I want also set a color (red, green, blue, white) without changing the existing values of the other colors. Therefor is setB, setG, etc.
So the question is: how to change one color, leaving the other colors untouched, using setColor?
I have found that {"`BlueIn`",{trigAll=true, trigAct={{"`Blue`", "setValue,255"},{"`Blue`", "setValue,0","30"}}, }}, has the desired behaviour of setB.
    Good to know...
    14 hours ago, SmartLifeSystems said:
    Hi cag,
    Thanks!
    Currently I'm on business trip...  will check that on Sunday..
    Hi @cag014,
    Hoping you returned well from your business trip.
    Simple question: I want to set a Smart Implant out relais in the status On from start of AOQ. How to implement this with initAct or otherwise?
  • 2 hours ago, Rover said:
    Hi @cag014,
    Yes, set initAct={....} and every time you start AOQ this command will be executed.
    How does the complete jM line with initAct in it looks like?
    The initAct={} has same format as trueAct={} or any other action.
    Since you probably don't have any specific device to set the jM line, so use $blank keyword
    {"$blank",{state="whatever", iniAct={"`sImplant`","<set relay command>"}}},
  • On 11/11/2021 at 9:58 PM, SmartLifeSystems said:
    Hi cag,
    Thanks!
    OK here is the api command for device ID 83
    here is the response
    Just use your device ID and get the data you need from response and save in global variable. You need to create QA for that and to call it from AOQ.
    Another idea is to use
    in parallel to AOQ and you can write your own function as part of the
    code.
    Edited by cag014
    TNX @cag014, that is what I needed. Something to add in the guide?
    OK.
    please pay attention it should be initAct ={} (my bad)
  • @Rover
    Have used your AOQ "advertising", hope that's OK by you
    Of course @cag014, AOQ cannot get enough advertising. ?
    code.
    Hi cag,
    Thanks your answer, but how can I make this QA. I know the API address, but I can't make the QA programming. Can you help me?
  • 22 hours ago, SmartLifeSystems said:
    Hi cag,
    Please let me know what parameter exactly you need to save as a global? (pls provide global name also)
    In addition what exactly you want to do in AOQ?
    Edited by cag014
    I would like to get the energy consumption data from the device and save as a global variable.
    The global variables name:
    - TodayEnergy
    - ThisWeekEnergy
    - ThisMonthEnergy
    - ThisYearEnergy
    Thank you very much!
    - TodayEnergy
    - ThisWeekEnergy
    - ThisMonthEnergy
    - ThisYearEnergy
    DO you need that for one device only? Otherwise it might be a good idea to add device ID to variable name, like:
    TodayEneregy483 and etc.
    Another question - are you looking current or total energy?
    I can create QA where you pass parameters : current or total and device ID. Is it good enough for you?
    Edited by cag014
    - TodayEnergy
    - ThisWeekEnergy
    - ThisMonthEnergy
    - ThisYearEnergy
    OK, here is the first try...
    Create standard global variables as defined by you.
     -TodayEnergy
    - ThisWeekEnergy
    - ThisMonthEnergy
    - ThisYearEnergy
    download attached QA.
    At function QuickApp:onInit()
    Change variable devId to your device ID. (currently defined 83)
    devId=83
    Currently the QA updates the data every 15 minutes. To change that set wanted time interval in mSec. at following line:
    setInterval(function() self:getData(devId) end,   900000)
    Please ignore data in Advance tab, it always will be zero.
    The real data displayed on device UI as labels. There are two buttons (current and total) work same as at advance tab.
    7 hours ago, cag014 said:
    Oké, itt az első próbálkozás...
    Hozzon létre szabványos globális változókat az Ön által meghatározottak szerint.
     -TodayEnergy
    - ThisWeekEnergy
    - This MonthEnergy
    - ThisYearEnergy
    töltse le a mellékelt minőségbiztosítást.
    QuickApp:onInit() függvénynél
    Módosítsa a devId változót az eszközazonosítóra. (jelenleg definiált 83)
    devId= 83
    Jelenleg a QA 15 percenként frissíti az adatokat. A kívánt időintervallum msec-ben történő módosításához. a következő sorban:
    setInterval( függvény () self:getData(devId)  end ,    900000 )
    Kérjük, hagyja figyelmen kívül az Advance lapon lévő adatokat, mert mindig nulla lesz.
    Az eszköz felhasználói felületén címkékként megjelenített valós adatok. Két gomb (aktuális és teljes) ugyanúgy működik, mint az előzetes lapon.
    Ohhh I'am very happy! Working fine! Thank you very much!!!!
