  • 4
HC3 no motion for X time = lights off, how to?
Pete123
How do you configure a scene that will turn on lights when motion and does not turn off until motion sensor has been safe for X time?
I am looking for both Lua and block options, if available.
Until now I have only found option for "delay" meaning lights will turn off after given time no matter if there has been motion during "delay" period.
Hope someone has found a solution for this.
5 hours ago, SmartHomeEddy said:
You have two motion sensors, how does this line looks in your code?
Or can you share the code you are actually using?
Hi, SmartHomeEddy,
Below is the original scene I'm using today.
A. Motion sensor 1 OR motion sensor 2 violated AND Lux <300 turns main room light on (ID 35).
B. After the 1 minute timeout in a safe state of the motion sensor (no motion detected), the scene verifies that the garage and laundry lights are on. In this case, if they are lit, the main room light will remain ON.
C. Now, if the garage and laundry lights are off, the scene also turns off the main room light.
what i would like to do......
1. any of the 2 violated motion sensors (motion detected);
2. Turns on the lights in the Main Room (ID 35), Garage (ID 69) and Laundry (ID 70).
3. after counting the safe time, the scene turns off the light in the main room, but keeps the previous state of the garage and laundry lights (on or off), that is, if these lights were already on before the start of the scene , they will remain lit. ... .. otherwise, Cena turns them off too ......
thanks,
  conditions = { {
      id = 170,
      isTrigger = true, -- Motion 1
      operator = "==",
      property = "value",
      type = "device",
      value = true
      id = 190,
      isTrigger = true, -- Motion 2
      operator = "==",
      property = "value",
      type = "device",
      value = true
      id = 172,   -- LUX
      isTrigger = false,
      operator = "<=",
      property = "value",
      type = "device",
      value = 300,
  operator = "any"
local light = {35} -- ID's the main room light
local motion = {170,190} -- ID's the Motions
local lux = {172, 192} -- ID's the Lux
local maxTime = 1*60  -- max safe time
local sleepTime = 5 -- check interval (default = 5)
local debug_TAG = "Lights Timer" -- Tag for the debug messages
for i in pairs(light) do -- Turn On main room light
fibaro.debug(debug_TAG,"Turning on (ID " ..light[i] ..") " ..fibaro.getName(light[i]) .." for " ..maxTime .." seconds")
fibaro.call(light[i],"turnOn")
for i in pairs(lux) do -- show lux level at the moment(LUX)
fibaro.debug(debug_TAG,"Current Lux level " ..lux[i] .." " ..fibaro.getName(lux[i]) ..": " ..fibaro.getValue(lux[i],"value"))
local safeTime = 0
while safeTime < maxTime do -- Loop until max time reached
fibaro.sleep(sleepTime*1000)
safeTime=safeTime+sleepTime
fibaro.debug(debug_TAG," Counting safe time " ..safeTime .." para maxTime " ..maxTime)
for i in pairs(motion) do
if fibaro.getValue(motion[i],"value") then -- Check se Motion violado(s)
fibaro.debug(debug_TAG,"Reset o Motion sensor " ..motion[i] .." " ..fibaro.getName(motion[i]))
safeTime = 0 -- Reset safeTime
if fibaro.getValue (69, 'value') or fibaro.getValue (70, 'value') then
fibaro.debug(debug_TAG, "leave the lights on") -- garage and laundry lights IDs (69, 70)
else
fibaro.debug(debug_TAG, " Turning off  " ..light[i] .." " ..fibaro.getName(light[i]))
fibaro.call(light[i],"turnOff") -- main room light
I thinks this will do the job
When running the code, first it will check if the Garage and Laundry lights are on. If both lights are on, they won't be turned off is there is no more motion.
Edited by SmartHomeEddy
Hello SmartHomeEddy,
I was only able to test the Scene today, it is reporting the error below:
on line 14 that refers to:
14 - if fibaro.getValue(lightlit1) and fibaro.getValue(lightlit2) then
/monthly_2021_07/image.png.db134569d1ba8ee19d8a9b6013a42557.png" />
Can you replace the line with
if fibaro.getValue(lightlit1,”value”) and fibaro.getValue(lightlit2,”value”) then
20 minutes ago, SmartHomeEddy said:
Você pode substituir a linha por
if fibaro.getValue (lightlit1, ”valor”) e fibaro.getValue (lightlit2, ”value”) então
Works perfect ......thanks so much [email protected]'m so happy......thanks for the help!
12 minutes ago, SmartHomeEddy said:
SmartHomeEddy@,
Forgive me, a question came to me now using the scene in practice: if the laundry light was already "off" and the garage light "on" or vice versa, how to keep them that way instead of turning them on or off them always together?
In this script the Garage and Laundry lights are handles separately. The script is actually more simple, in the if-elseif-end it checks which lights are already on and excludes them from the "light" variable to turn on and off the light. I think this should do the job.
Don't have much todo today either :-)
I'm a big fan of abstractions, and when expressing an algorithm it's nice to create abstract functions for turning on or checking devices instead of calling fibaro.* every time. If you have an isON(device) function that works it also minimise the risk that you forget to add that second "value" parameter when you use the fibaro.getValue(x,"value") for the nth time...
If we have a NAME(dev) function that returns the name we want to print in the log for a device (here <ID>:<name>) we can easily change that function if we would like to log <name>:<ID> instead.
etc.
It also tends to keep the code size down (at least the main part) and create a better overview of the logic of the algorithm/code.
So, here's an example on how to code the above example without changing the flow/logic.
SmartHomeEddy@,
The scene works, only this error message appears every time the scene resets the time count.......but it still works normal after...
/monthly_2021_07/image.png.74feff301c98908c096e599c4e43486f.png" />
I also noticed that when the motion sensor timer is reset due to a new detected motion, before reaching the safe time, the scene saves the new "status" of the light. In this situation (new movement detected during the execution of the scene) the Lights never go out... is it possible to work around this situation? in order to maintain the original status of the lights?
thank you so much...
etc.
jgab@,
thank you very much for the tips and tricks for the example, please help me with this error that appeared when running Scene.
15   local function NAME(dev) return ""..dev..":"..fibaro.getName(ldev) end
32 minutes ago, jorge rintaro said:
jgab@,
Typo. ldev should be dev
I see some different ID’s in comparison to the code.
Does the version of @jgab give the same error?
Hello, SmartHomeEddy@,
I just tested the @Scene jgab, it didn't show this error...
this error in your scene appears only when the scene is stopped (time count restart) new motion detected during the timer.
but even with the error it still works after ......
in the Scene indicated by jgab @ Scene also presents the same situation that I explained about the condition of the lights on or off initially ..... if the motion sensor is violated during the execution of the scene it resets the timer and considers the original state of lights ALL on... ...because actually, when the new instance started, they were on... I don't know how it would be possible to get around that.......
SmartHomeEddy@,
complementing....the IDs were changed just for testing, I used the same IDs in the Scene of jgab @......they are correct in relation to their respective devices/functions (lights, motions and Luxs)
thanks
I think, hope, this setting will do the trick
/monthly_2021_07/42C26278-1B9A-410F-944C-AADB3D68CC0E.jpeg.e1761e58e6b1fe2a351acf6583928132.jpeg" />
Allow to restart a running scene: No
(I think this one also triggers the error)
Eu acho, espero, que esta configuração funcione
Permitir reiniciar uma cena em execução: Não
thank you very much, it worked perfect ....
a lot of learning for me these days .... grateful.
On 04/07/2021 at 05:23, jgab said:
Não tenho muito o que fazer hoje também :-)
Sou um grande fã de abstrações e, ao expressar um algoritmo, é bom criar funções abstratas para ligar ou verificar dispositivos em vez de chamar fibaro. * Todas as vezes. Se você tem uma função isON (dispositivo) que funciona, também minimiza o risco de você se esquecer de adicionar o segundo parâmetro de "valor" ao usar fibaro.getValue (x, "valor") pela enésima vez ...
Se tivermos uma função NAME (dev) que retorna o nome que queremos imprimir no log de um dispositivo (aqui <ID>: <name>), podemos facilmente alterar essa função se quisermos registrar <name>: < ID> em vez disso.
etc.
Também tende a manter o tamanho do código baixo (pelo menos a parte principal) e a criar uma visão geral melhor da lógica do algoritmo / código.
Portanto, aqui está um exemplo de como codificar o exemplo acima sem alterar o fluxo / lógica.
jgab@, please......if instead of motion sensor I use door and window sensor... what needs to be changed in Scene? thanks
Nothing, as all binary sensors return true when opened/breached and false if closed/safe
11 minutes ago, jgab said:
Nada, pois todos os sensores binários retornam verdadeiro quando aberto / violado e falso se fechado / seguro
@jgab, thanks ...... had forgotten to change the IDs in the "CONDITIONS" .... so it wasn't working .... now everything is OK... grateful
