  • 4
HC3 no motion for X time = lights off, how to?
Pete123
How do you configure a scene that will turn on lights when motion and does not turn off until motion sensor has been safe for X time?
I am looking for both Lua and block options, if available.
Until now I have only found option for "delay" meaning lights will turn off after given time no matter if there has been motion during "delay" period.
Hope someone has found a solution for this.
/monthly_2021_07/image.png.3408a90eb58864da5387a0125e976930.png" />
@jgab, your Portuguese is perfect :-)
Yeah, isn't it? :-)
If I translate the Portuguese to Swedish and back to English with Google translate it doesn't sound as impressive.... or maybe it does :-)
On 05/07/2021 at 08:10, jgab said:
Nada, pois todos os sensores binários retornam verdadeiro quando aberto / violado e falso se fechado / seguro
jgab@, how are you?
please one more help......if I have Dimmer and RGB along with modules On/Off what do I need to change in Scene? I just tried to include the Ids but the Scene doesn't read the original status.....Dimmers and RGBs always turn off....even if they're lit at the start of the Scene.
thanks,
So it is the isON() test that fails?
Dimmers and RGBs don't return true/false for their value, they return a number 0..99. 0 when off, and >0 when on.
We can allow for that if we modify isON()
I think it should be possible to use the 'state' property too, but I'm a bit unsure how consistently it is supported/used.
jgab@, thank you.....perfect!
On 05/07/2021 at 08:55, jgab said:
Sim, não é? :-)
Se eu traduzir o português para o sueco e de volta para o inglês com o Google Translate, não soará tão impressionante ... ou talvez pareça :-)
@jgab how are you?
one more guidance / help please ....
when condition (3) of the scene is met, I would like the scene to check the time (hour range) and based on that, turn on the RGB in a specific color ...... I tried to use
local time = os.date ("%H:%M")
if time> = "17:00" or time <="20:30"
then
but it didn't work, I looked in the Lua HC3 manual, but I couldn't find examples.... Could you guide me once again how this encoding works on the HC3.
thank you so much.
part of the code
local time = os.date("%H:%M")
if isON(light1) and isON(light2) and isONx(light3) then
light = {35}
print("conditions 1")
elseif isON(light1) and isON(light2) then
light = {35,25}
print("conditions 2")
elseif isON(light1) and isONx(light3) then
light = {35,259}                                               -- TurnOn ID 35 and RGBW
print("conditions 3")
if time >= "17:00" or time <= "20:30" then
fibaro.call(259, "setColor", "0","255","0","0") -- R,G,B,W
print ("Pool Color Green")
elseif time >= "20:31" or time <= "22:00" then
fibaro.call(259, "setColor", "0","255","255","255") -- R,G,B,W
print("Pool Color white")
else
fibaro.call(259, 'setColor', "8","0","165","0") -- R,G,B,W
print ("Pool Color Blue")
elseif isON(light2) and isONx(light3) then
light = {35,46}
print ("conditions 4")
elseif isON(light1) then
light = {35,25,259}
print("conditions 5")
elseif isON(light2) then
light = {35,46,25}
print("conditions 6")
elseif isONx(light3) then
light = {35,46,259}
print("conditions 7")
You should use 'and' instead of 'or'
if time >= "17:00" and time <= "20:30" then
jgab@,
thanks again for the help .....gratitude.
Att.
Jorge
Guest Benrive
I have just implemented all this, it works perfectly for me .
In my case all the lights are dimmable.
Would it be possible to implement that when the lights are turned on at the same time the brightness level is adjusted depending on the amount of lux there is at that moment?
Guest Benrive
Something very strange happens to me.
For testing purposes, I have changed the virtual lights to multilevel virtual light. ( I have dimmer )
But now something very curious happens, only the first one is turned on and off.
Of course, I have changed the ID of the new virtual multilevel lights in the script.
What can be?
Updated: 21/08/11
Work's Ok:
Witch Virtual Switch binary
local light = {61,62,63-- ID's of all the lights to turnOn and turnOff
local function isON(light) return fibaro.getValue(light,"value"end
Testing, because I don't understand what happens.
I have noticed in the Debug that if I use Binary Switches it works and even looks like the function
When I use virtual devices multilevel , the same function is just looping only to first ID.
local light = {55,59,60-- ID's of all the lights to turnOn and turnOff
It's very strange.
Thx a lot
Edited by Benrive
I need some quick help?
How can i modify this scene to :
End the scene,  if light (ID 481) is turned off by a person on a switch or by app ? This way turning off the light doesnt stop the scene and it keeps counting thil the end..
DECLARATIONS (Conditions/Triggers)
  conditions = { {
      id = 481,
      isTrigger = true,
      operator = "==",
      property = "value",
      type = "device",
      value = true
  operator = "all"
ACTIONS
local light = {201}
local motion = {481}
local maxTime = 2*60
local sleepTime = 5
local debug_TAG = "IZKLOP WC LUČI PO 3 min"
 for i in pairs(light) do
  fibaro.debug(debug_TAG,"vklapljam luci (ID " ..light[i] ..") " ..fibaro.getName(light[i]) .." za " ..maxTime .." sekund")
  fibaro.call(light[i],"turnOn")
local safeTime = 0
while safeTime < maxTime do
  fibaro.sleep(sleepTime*1000)
  safeTime=safeTime+sleepTime
  fibaro.debug(debug_TAG,"  Štetje do maksimalnega časa  ki znaša ... " ..safeTime .." maksimalni čas znaša ... " ..maxTime)
  for i in pairs(motion) do
    if fibaro.getValue(motion[i],"value") then
       fibaro.debug(debug_TAG,"Reset na podlagi senzorja gibanja  št.... " ..motion[i] .." " ..fibaro.getName(motion[i]))
       safeTime = 0
  fibaro.debug(debug_TAG, "Ugašanje luči " ..light[i] .." " ..fibaro.getName(light[i]))
  fibaro.call(light[i],"turnOff")
This is just for 1 light - if you have several lights in the lua table 'light' the code needs to be modified.
Thanks a lot for your help.
I do have another scene i would like to do the same. With multiple LED Strips (ID 324, ID 325) and one klassic non dimmable LED light (ID 74). How do i have to change the code this time?
  conditions = { {
      id = 516,
      isTrigger = true,
      operator = "==",
      property = "value",
      type = "device",
      value = true
      id = 74,
      isTrigger = false,
      operator = "==",
      property = "state",
      type = "device",
      value = false
      isTrigger = false,
      operator = "==",
      property = "SLEEP_MODE",
      type = "global-variable",
      value = "OFF"
      conditions = { {
          isTrigger = false,
          operator = "==",
          property = "Dan_Noc",
          value = "NOC"
          id = 518,
          isTrigger = false,
          operator = "<",
          property = "value",
          type = "device",
          value = 25
      operator = "any"
  operator = "all"
ACTIONS
local light = {324,325}
local motion = {516}
local maxTime = 1*60
local sleepTime = 5
local debug_TAG = " kuhinja ON/OFF SENZOR " -- oznaka scene
 for i in pairs(light) do -- vklop vseh luči
  fibaro.debug(debug_TAG,"Vklapljam (ID " ..light[i] ..") " ..fibaro.getName(light[i]) .." za čas   " ..maxTime .." sekund") -- debug vklopa luči
  fibaro.call(324,"setValue",30)
  fibaro.call(325,"setValue",15)
local safeTime = 0
  if fibaro.getValue(74, "value")
    then
    break
  fibaro.debug(debug_TAG," Štetje do maksimalnega časa ki znaša ...  " ..safeTime .." maksimalni čas znaša ..." ..maxTime)
    if fibaro.getValue(motion[i],"value") then -- preveri če se je sprožil senzor gibanja
       fibaro.debug(debug_TAG,"  Reset na podlagi senzorja gibanja  št.  " ..motion[i] .." " ..fibaro.getName(motion[i]))
       safeTime = 0 -- resetira čas na 0 če zazna gibanje
then
  fibaro.debug(debug_TAG, "Ker je zaznan prižig druge luči se luč ne ugasne")
else
  for i in pairs(light) do -- Štetje do maksimalnega časa nato izklop luči
    fibaro.debug(debug_TAG, " Turning off  " ..light[i] .." " ..fibaro.getName(light[i]))
Doesn’t there exist an ALC LUA like the of @Sankotronic for the HC3?
I have 2 lights with Fibaro Plug, 2 HUE lamps and 2 motion sensors. I want the "normal" lights to become on by motion and stay on for 10m and restart counting after motion. This works perfect with the script of @SmartHomeEddy
But at sunset the HUE lights should also become active with a certain color and using the same motion script as above.
Can this be done?
Edited by Sjekke
On 2/16/2020 at 1:22 PM, jgab said:
This was a half-joke but it actually works. If you set "Allow to restart a running scene" to 'no' (similar to "if fibaro:countScenes() > 1 then fibaro:abort() end")
you can code like this (almost like in the old days).
In practice the fibaro.sleep loop should be changed to a setTimeout loop to adopt the new coding style imposed, because sleep is a bit heavy on the system...  - but that's left as an exercise to the reader.
The condition sections to trigger on motion sensor with id 32 being breached should be:
Hi everyone. I'm a baby user OF HC3 and I'm interested in this issue to do as well.
But when I copied and pasted this code in my HC3 and try to make it run. I have this error :
[16.06.2022] [16:44:25] [ERROR] [SCENE32]: (load):19: attempt to compare number with boolean
Line 19 is this one
Could you please gimme help ?
Thank you.
Hello @YannickKARCHER
Try
if fibaro.getValue(motion,"value") then
Because I think the motion Sensor gives only "true" or "false"
I use this ...
2 sensors, 2 lights. Lux I don't use yet
DECLARATIONS
  conditions = { {
      id = 78,
      isTrigger = true,
      operator = "==",
      property = "value",
      type = "device",
      value = true
      id = 263,
      isTrigger = true,
      operator = "==",
      property = "value",
      type = "device",
      value = true
  operator = "any"
Actions
-- This scene turns on one or more lights:
--    when Lux level is below a certain level (see DECLARATIONS) and
--    shows the Lux level of one ore more Lux sensors and
--    turns off the lights after a certain time (maxTime),
--    unless there is motion from one or more Motion sensors
-- Please enter the right ID's (if more than one, seperate by ",") and the prefered maxTime for the lights to stay on
local light = {26, 62} -- ID's of the lights to turn on
local motion = {78, 263} -- ID's of the Motion sensors to check if they are breached
local lux = {80, 265} -- ID's of the Lux sensors to (only) show the lux level
local maxTime = 1*600 -- Maximum time the sensor should be safe before turning off (n*60 where n is minutes)
local sleepTime = 5 -- Time in seconds between each check of the Motion sensor (default = 5)
local debug_TAG = "Woonkamer licht" -- Tag for the debug messages
-- Below here no changes are necessary
for i in pairs(light) do -- Turn on the lights
  fibaro.debug(debug_TAG,"Turning on (ID " ..light[i] ..") " ..fibaro.getName(light[i]) .." for " ..maxTime .." seconds")
for i in pairs(lux) do -- Show the lux level of the Lux sensors
  fibaro.debug(debug_TAG,"Current Lux level " ..lux[i] .." " ..fibaro.getName(lux[i]) ..": " ..fibaro.getValue(lux[i],"value"))
local safeTime = 0
while safeTime < maxTime do -- Loop until maxTime is reached
  fibaro.debug(debug_TAG,"Counting up safeTime " ..safeTime .." to maxTime " ..maxTime)
    if fibaro.getValue(motion[i],"value") then -- Check if Motion sensors are breached
       fibaro.debug(debug_TAG,"Reset by Motion sensor " ..motion[i] .." " ..fibaro.getName(motion[i]))
       safeTime = 0 -- Reset safeTime to zero
for i in pairs(light) do -- Counted down to maxTime, turn off the lights
  fibaro.debug(debug_TAG, "Turning off " ..light[i] .." " ..fibaro.getName(light[i]))
