  • 4
HC3 no motion for X time = lights off, how to?
How do you configure a scene that will turn on lights when motion and does not turn off until motion sensor has been safe for X time?
I am looking for both Lua and block options, if available.
Until now I have only found option for "delay" meaning lights will turn off after given time no matter if there has been motion during "delay" period.
Hope someone has found a solution for this.
2 minutes ago, jgab said:
It was a rewrite of the original example where I have
When we can use the tag for something I will revert :-) Now every HC2 coder including myself forgets the tag...
Absolutely, happens to me all the time.
I get an 501 when doing
but I guess that is something that will come?
It would be cool if the tag replaced the standard [DEBUG] we get now...
Yes
Currently there is a bug in that, should be fixed on next release.
All scenes debug info goes to same debug output and makes a huge mess.
22 minutes ago, cag014 said:
Yes
...and why don't they then add a tag to the QuickApp's self:debug too?
I would prefer that they implemented logger.* that there seems to be left-overs of in the QuickApp environment and let the debug functions default to logger.info() or logger.log()
We also have logger.error() and logger.trace()...  and logger would tag the debugMessages accordingly...
...but now we our getting outside the topic of the thread.
Guest rafal_ll
W dniu 16.02.2020 o 13:22, jgab napisał:
This was a half-joke but it actually works. If you set "Allow to restart a running scene" to 'no' (similar to "if fibaro:countScenes() > 1 then fibaro:abort() end")
you can code like this (almost like in the old days).
In practice the fibaro.sleep loop should be changed to a setTimeout loop to adopt the new coding style imposed, because sleep is a bit heavy on the system...  - but that's left as an exercise to the reader.
The condition sections to trigger on motion sensor with id 32 being breached should be:
Hello after the update has stopped working
I get the message "attempt to compare string with boolean"
hi @rafal_ll the old getvalue on motion /widows sensors/ returns now a bolean , try this:
Yes, it's a moving target. With the support for fibaro.sleep the scene looks like this now.
The conditions part looks the same.
  • Thanks 3
Thank you, @jgab!
I've been testing this scene, but the light always turns off after 5 seconds (probably due to the default setting of 5 seconds of the Parameter 6 "Motion detection - alarm cancellation delay" of the Fibaro Eye), but keeps counting to 60. Even if I do motion within 60 seconds it does not turn on.
8 minutes ago, robw said:
Thank you, @jgab!
-Have you set the scene's  "Allow to restart a running scene" to 'no' ?
-When it turns off after 5s is it the scene that does it? , Do you see the log output from fibaro.debug("","Turning off") ? If not you have another scene that turns it off - or an association?
--Try setting down 'sleepTime' to 3s
@jgab
Thank's! You have my permission to hit me in the head with a large cup of coffee! :) My apologies, it was another scene that I forgot to turn off, that turned off the light. Everything is working now! Thank you again!
Guest rafal_ll
Thank you everyone, works great
Thanks jgab. Thanks to this kind of ideas I can make my HC2 to HC3 working again.
(btw my HC3 doesn't like the single quotes, I had to use double quotes)
Today these scenes just stopped working.
Edit: It was a variable crash. Everything is working now.
Edited by robw
I am getting an error and the scene does not work. Whath am i doing wrong.
[ERROR] 05.03.2020 20:27:54: (load):8: unexpected symbol near '<\226>'
Single quotes versus double quotes?
I have this same error message.
EDIT:
Copy and paste this script and delete quotes and insert manually.
Works.
Edited by motyk123
Look at the last line of your scene - look carefully at the single quotes... See something strange? No? they are "angled" and that does not work, it causes "unexpected symbol near '<\226>'"
So fix that line, instead write:
EDIT: forgot to mention... There is onother one to fix on line 8, fibaro.call(light,'turnOn') - check all quotes
On 3/1/2020 at 7:20 AM, robw said:
Thank you, @jgab!
@robw the code with wrong kind of quotes is in your post because you've quoted a version with that error, can you please fix that? Jgab already fixed his version here...
Edited by petergebruers
2 hours ago, jimicr said:
Hi guys, I edited the scene and runs for me (see code below).
I added check against lux, manual override and check if light is on or off all ready.
It runs like a charm but I think the pro's here can clean the code to make it better.
maybe this helps someone.
Jim
Thank's, Jim! Do you have a Hometable script for the HC3? Would you mind sharing it here?
Have a nice day!
Edited by robw
@robw No problem:
You'll have to create the variable manual as standard variable.
