  • 4
HC3 no motion for X time = lights off, how to?
How do you configure a scene that will turn on lights when motion and does not turn off until motion sensor has been safe for X time?
I am looking for both Lua and block options, if available.
Until now I have only found option for "delay" meaning lights will turn off after given time no matter if there has been motion during "delay" period.
Hope someone has found a solution for this.
so the 45 is the light id? and i need to code it this way
local light = {jT.Woonkamer.verlichting, 45, 22, 27, 65}
if you use home table and you filled it you can use jT.Woonkamer.verlichting else you the device's ID number (you can find it at "settings>Devices" you'll see a list of installed devices and their ID numbers (next to the icon
i used the hometable but the lights did not go on in al the other rooms with 1 light en sensor it works perfectly.
jsonHome = {
Woonkamer={beweging=134, beweging=1401, beweging=1442, temp_PIR=135, temp_PIR1=141, temp_PIR2=145, lux=136, lux1=142, lux2=146, lux3=236,  luchtvocht=237, verlichting=115, verlichting1=130, verlichting2=153, verlichting3=150, verlichting4=27,},
Badkamer={beweging=209, temp_PIR=210, lux=211, luchtvocht=212, verlichting=215, ventilatie=221},
Slaapkamer={beweging=92, temp_PIR=93, lux=94, verlichting=99,},
Gang={beweging=62, temp_PIR=226, lux=64, verlichting=82,},
Wc={beweging=86, temp_PIR=87, lux=88, verlichting=113,},
Bijschuur={beweging=86, temp_PIR=87, lux=88, verlichting=113,},
fibaro.setGlobalVariable("HomeTable", json.encode(jsonHome))
jT = json.decode(fibaro.getGlobalVariable("HomeTable"))
fibaro.debug("""HomeTable created")
fibaro.debug("", jT.Badkamer.verlichting)
You can only use one sensor unless you edit the scene
oke it works now. i will try to make it work now wit 3 sensors?
I may do it as well tomorrow, I see you're from Holland aslo. I have time now I live in Braband and have a cold so been send home from work...
i am from zuid holland so for the moment its oke here.
i tink i got it. changed line 68 to the below code and added the 2 motionsensor in the biginning of the rule
local motion = jT.Woonkamer.beweging
local motion1 = jT.Woonkamer.beweging1
local motion2 = jT.Woonkamer.beweging2
line 68: if hc.getValue(motion,"value"or hc.getValue(motion1,"value"or hc.getValue(motion2,"value"then -- motion breached
Nice! I still need to get used to the new triggers
12 hours ago, jimicr said:
@robw, remove the check if lights are on:
to:
Same goes for turning off
Jim
Hi, I just tested, and it turns on and then it turns off immediately after a second. So it is good it can turn on and off.
local hc = fibaro
jT = json.decode(hc.getGlobalVariable("HomeTable"))
local light = {jT.Bathroom.bathroomlight}
local motion = jT.Bathroom.motion
local lux = tonumber(hc.getValue(jT.Bathroomt.lux, "value"))
local luxmin = 500
count = 0
function checkLights()
  if #light > 0 then
    for i = 1, #light
    do
if hc.getValue(light"state"then count = count+1 end
function turnon()
  if #light > 0 then
    for i = 1, #light
    do
        hc.call(light,"turnOn");
        hc.debug("","Turning on");
        hc.sleep(100)
function turnoff()
  if #light > 0 then
    for i = 1, #light
    do
        hc.call(light,"turnOff");
        hc.debug("","Turning off");
        hc.sleep(100)
checkLights()
if count >0 then state = "On" else state = "Off" end
hc.debug("","Current lux: ",lux)
hc.debug("","minlux: ",luxmin)
if state == "Off" then
if luxmin < lux then hc.debug("","room to light to turn on  lights")
else
local maxTime = 3*60  -- max time the sensor should be safe before turning off
local sleepTime = 3   -- time in seconds between each check of the sensor
turnon()
local safeTime = 0
while safeTime < maxTime do
  hc.sleep(sleepTime*1000)
  safeTime=safeTime+sleepTime                   -- count up safeTime
  hc.debug("","Counting up safeTime ",safeTime,maxTime)
 count = 0
 checkLights()
    if state == "Off" then hc.debug("","Light(s) turned off manual");
  break end
  if hc.getValue(motion,"value"then -- motion breached
     safeTime=0                                 -- reset safeTime
     hc.debug("","Reset")
turnoff()
else hc.debug("","Light manual turned on")
hc.debug("","Scene ended")
I'd like to use this method in my 3 rooms (every room with it own script and different timeouts) to turn off light when no move detected in room for x time.
I'd like to:
- turning on any of 3 switches > start cuntdown
- manually turning off switch > stop countdown
- detected move > reset countdown
Now i'm trying this code, but:
- it causes high cpu utilization
- turning off switch doesn't stop counting
- when i turn on 3 scenes, debug of every one of them shows 3 countdowns, not only it's own
Can you help me to deal with it?
  conditions = { {
      id = 115,
      isTrigger = true,
      operator = "==",
      property = "state",
      type = "device",
      value = true
      id = 116,
      isTrigger = true,
      operator = "==",
      property = "state",
      type = "device",
      value = true
      id = 117,
      isTrigger = true,
      operator = "==",
      property = "state",
      type = "device",
      value = true
  operator = "any"
local light = {115,116,117}
local motion = 163
local maxTime = 1*60  -- max time the sensor should be safe before turning off
local sleepTime = 5   -- time in seconds between each check of the sensor
fibaro.debug("","Turning on")
local safeTime = 0
  fibaro.sleep(sleepTime*1000)
  fibaro.debug("","Counting up safeTime ",safeTime,maxTime)
  if fibaro.getValue(motion,'value'then -- motion breached
     fibaro.debug("","Reset")
fibaro.debug("","Turning off")
fibaro.call(light,'turnOff'
Anyone?
59 minutes ago, michal85pl said:
Anyone?
Well, I made this QuickApp the other day...
Assume you have 3 motion sensors in the kitchen, id 44, id 55, and id 66
If you use the QA in the post and create a QA variable (quickAppVariable)
and as value put the string
"00:05/2/44:safe & 55:safe & 66:safe"
It will send a CustomEvent named 'motionsInKitchenSafeFor5min' when the all the motion sensors are safe for 5 min.
If anyone gets breached it will restart waiting until they all are safe for 5min again and send a new event etc etc.
You could then build a block scene that triggers on the CustomEvents and turns off the lights
You could add more rules for more rooms - the quickvar needs to start with #.
To handle the case with the the switch stopping the countdown I would recommend the same block scene triggering on the switch becoming 'on' and set a global variable that you check before you turn off the lights when you react on the 'motionsInKitchenSafeFor5min' customEvent.
It's usually a bit complicated because you need to decide when to let the countdown continue again. After 20min of no motion? Then add another rule
value: "00:20/2/44:safe & 55:safe & 66:safe"
and clear the variable.
My thinking behind creating the QA was to setup rules that posts events when rooms are safe, when rooms are breached, when rooms are lit (lux), etc. as I usually have more than one sensor per room. The expressiveness for rules are more or less what Lua supports which  allows for quite complex rules.
"00:20/2/(101:lux + 102:lux + 103:lux)/3 > 200"
is true when the average lux value in a room with 3 lux sensors exceeds 200 and will fire off an event.
However, I haven't had to play with it much yet...
Anyway, it's a possibility...
Man You are Great ... this method works great and gives more possibilities, which in my opinion should be available as ready conditions in block scenes ...
I have an additional question. What if, by mistake, we turn on the switch, for example, through an Application without detected motion (the motion sensor was already marked as safe), how to force a countdown restart?
Does the following apply to this problem because I do not understand it?
Cytat
So, you turn on the lamp in the room from another scene or the app and no one is in the room?
You can add the lamp to the condition, ex. the lamp deviceID is 77
value: "00:05/2/77:on & 44:safe & 55:safe & 66:safe"
If the lamp is on and the sensors are safe for 5min it will send the event
Yes, but given that we turn on the switch virtually, the motion sensor is already in safe state, so it immediately turns off the switch, but I would like the countdown to be triggered
Yes, but 77:on  need to be true for 5mins also.
Actually the whole expression needs to be true for 5min, which includes 77 being on and the sensors being safe.
So when the lamp is turned on it will start counting 5mins (given that the sensors are safe already)
it seems to work different, just like i said, below debug after switch turned on remotelly:
#ppSwiatloOn
00:00:01/2/115:on
#ppRuch
00:00:01/2/115:on & 163:safe
[DEBUG] 21.03.2020 11:35:08: true: 115:on
[DEBUG] 21.03.2020 11:35:08: true: 115:on & 163:safe
[DEBUG] 21.03.2020 11:35:10: true(00:00:01): 115:on => customEvent:ppSwiatloOn
[DEBUG] 21.03.2020 11:35:10: true(00:00:01): 115:on & 163:safe => customEvent:ppRuch
#ppSwiatloOn
00:00:01/2/115:on
#ppRuch
Yes, but the on/safe period is only 1s? And it's on/safe for 1s and sends the event
(actually 2s because that is the specified interval it checks the test ../2/..)
Give it 5min and see if it waits for 5min (or at least a bit longer than 1s)
(actually 2s because that is the specified interval ../2/..)
of course You're right...sorry for my oversight
No problems,
and you're right. It should be a function that is part of the standard conditions test for scenes.
