  • 4
HC3 no motion for X time = lights off, how to?
How do you configure a scene that will turn on lights when motion and does not turn off until motion sensor has been safe for X time?
I am looking for both Lua and block options, if available.
Until now I have only found option for "delay" meaning lights will turn off after given time no matter if there has been motion during "delay" period.
Hope someone has found a solution for this.
2 minutes ago, jimicr said:
@robw No problem:
You'll have to create the variable manual as standard variable.
Nice, thank's!
6 hours ago, jimicr said:
Hi guys, I edited the scene and runs for me (see code below).
I added check against lux, manual override and check if light is on or off all ready.
It runs like a charm but I think the pro's here can clean the code to make it better.
Conditions only check the motion sensor:
maybe this helps someone.
Jim
I'm sure you've coded everything right, and I'm doing something wrong. But what happens for me is that the light turns on correctly, but it does not turn off. What can I have done wrong? I turned off the original light scene so it should not interfere. By the way, the HomeTable works great!
Conditions:
  conditions = { {
      id = 79,
      isTrigger = true,
      operator = "==",
      property = "value",
      type = "device",
      value = true
      isTrigger = false,
      operator = "==",
      property = "sleepstate",
      type = "global-variable",
      value = "false"
  operator = "all"
Scene:
local hc = fibaro
jT = json.decode(hc.getGlobalVariable("HomeTable"))
local light = jT.Bathroom.lamp
local motion = jT.Bathroom.motion
local lux = tonumber(jT.Bathroom.lux)
local luxmin = 75
if hc.getValue(light, "state"then state = "On" else state = "Off" end
hc.debug("","Current lux: "..hc.getValue(lux,"value"))
if state == "Off" then
if luxmin >= lux then hc.debug("","room to light to turn on  lights")
else
local maxTime = 1*60  -- max time the sensor should be safe before turning off
local sleepTime = 3   -- time in seconds between each check of the sensor
if hc.getValue(light,"state") == false then hc.call(light,"turnOn");
hc.debug("","Turning on")  end
local safeTime = 0
while safeTime < maxTime do
  hc.sleep(sleepTime*1000)
  safeTime=safeTime+sleepTime                   -- count up safeTime
  hc.debug("","Counting up safeTime ",safeTime,maxTime)
    if hc.getValue(light,"state") == false then hc.debug("","Light turned off manual");
  break end
  if hc.getValue(motion,"value"then -- motion breached
     safeTime=0                                 -- reset safeTime
     hc.debug("","Reset")
if hc.getValue(light,"state"then hc.call (light,"turnOff");
hc.debug("","Turning off")  end
else hc.debug("","Light manual turned on")
hc.debug("","Scene ended")
Edited by robw
@robw Can't find the error in a glance.
Maybe it is the new conditions and your sleepstate is false? Or id=79 is your switch instead of your motion sensor?
@robw, I found an error in my code, line 6 should be:
local lux = tonumber(hc.getValue(jT.Badkamer.lux, "value"))
Editing the code I posted earlier
Thank's! I will test again :)
And I changed line 14 to:
if luxmin < lux then hc.debug("","room to light to turn on  lights")
I had it turned around for testing and forgot to change it back when I posted the scene
Hmmm... Now the light don't turn on. Something is not right, I think:
(load):11: attempt to concatenate a nil value
I will check more.
Edited by robw
9 hours ago, petergebruers said:
Look at the last line of your scene - look carefully at the single quotes... See something strange? No? they are "angled" and that does not work, it causes "unexpected symbol near '<\226>'"
So fix that line, instead write:
EDIT: forgot to mention... There is onother one to fix on line 8, fibaro.call(light,'turnOn') - check all quotes
@robw the code with wrong kind of quotes is in your post because you've quoted a version with that error, can you please fix that? Jgab already fixed his version here...
Great i got it working 1 more question how do i add more light en sensors. i tried the below but does not work.
local light = 115,130,150,153,27
local motion = 134
@marius de jong like this:
Enjoy coding
Jim
Enjoy coding
Jim
Sorry, I must have ghosts in my HC3. The new code does not turn off the light(s). A proposal also (I'm not a coder), would be to check if there is motion before running the scene. If not - don't turn on the light when starting the scene. Could that be done? Thank you Jim and Marius!
[DEBUG] 2020-03-10 06:42:17: Turning on
[DEBUG] 2020-03-10 06:42:20: Counting up safeTime 3 60
[DEBUG] 2020-03-10 06:42:20: Light(s) turned off manual
[DEBUG] 2020-03-10 06:42:20: Scene ended
@robw , maybe a long shot:
Remove the sleepstate part from the condition and reboot your HC3.
Here the same code runs like supposed too.
jim
jim
I'm sorry, it does not work for me. It turns on the light, but not off. I've uncommented the sleepstate in the triggers section. I have only one light, so I use:
    local light = {jT.Bathroom.bathroomlamp}
Log:
[DEBUG] 2020-03-10 10:25:43: Current lux: 486.0
[DEBUG] 2020-03-10 10:25:43: minlux: 500
[DEBUG] 2020-03-10 10:25:43: Turning on
[DEBUG] 2020-03-10 10:25:46: Counting up safeTime 5 60
[DEBUG] 2020-03-10 10:25:46: Reset
[DEBUG] 2020-03-10 10:25:46: Counting up safeTime 3 60
[DEBUG] 2020-03-10 10:25:46: Light(s) turned off manual
[DEBUG] 2020-03-10 10:25:46: Scene ended
Don't know what I'm doing wrong here, but I wil look further. I'm no coder, thought.
Note: If I change "Allow to restart a running scene" back and forth, I can see in the logs that it counts up Safetime. But it still does not turn off the light.
Is your light a dimmer?
A dimmier might require different code to turn off.
I only have a double switch and a Aeotec MS6 connected to my HC3 atm.
I'm not a coder too, I work with a lot of trail and error to get things working.
Jim
Jim
No, it is a Hue light. I'm stumped, and, I'm lousy at coding - trying to get a hang of it though on the HC3, I want to learn.
As an example, this code works:
        Trigger section:
  conditions = { {
      id = 79,
      isTrigger = true,
      operator = "==",
      property = "value",
      type = "device",
      value = true
      id = 81,
      isTrigger = false,
      operator = "<=",
      property = "value",
      type = "device",
      value = 100
      isTrigger = false,
      operator = "==",
      value = "false"
  operator = "all"
        Lua section:
local light = 52
local motion = 79
local sleepTime = 5   -- time in seconds between each check of the sensor
fibaro.debug("","Turning on")
fibaro.call(light,'setValue'90)
local safeTime = 0
  fibaro.sleep(sleepTime*1000)
  fibaro.debug("","Counting up safeTime ",safeTime,maxTime)
  if fibaro.getValue(motion,'value'then -- motion breached
     fibaro.debug("","Reset")
fibaro.debug("","Turning off")
fibaro.call(light,'turnOff'
Ah you should have told me sooner it wasn't a switch ;)
But no worries, try setting the value to "0" instead of "turnOff"
Hope this solves your problem
Jim
Jim
The code that I had above here, with fibaro.call(light,'turnOff', works.
Should I change like this in your example?
function turnoff()
  if #light > 0 then
    for i = 1, #light
    do
        if hc.getValue(light,"state"then hc.call(light,"setValue"0);
        hc.debug("","Turning off");
        hc.sleep(100end
I tested that, but unfortunately it did not work. The light don't turn off.
@robw, remove the check if lights are on:
to:
Same goes for turning off
Jim
to:
Jim
Thank's Jim! I will test in the morning. I'll get back here and tell how it went. Thank you for all help!!
Enjoy coding
Jim
I still don't understand howe to add more lights en sensors. i got 5 lamps and 3 sensors do i add them to the scene or to the hometable? and howe do i add them?
@marius de jong your lights go in here:
can also be {10, 20, 30} --> your light ID numbers.
I havent tuned the scene for more than one motion sensor.
Jim
