5 hours ago, jgab said:
In any case I have pushed a version (v0.303) where http timeout is specified in ms, like on the HC3. However, I'm pretty sure that the real resolution is seconds... It now also uses net.HTTPClient({timeout=...}) if set.
Still sometimes same data received twice when timeout is > 500 mS.
When reducing the timeout to 400 mS. works perfect!
It's probably related to PC performances (speed)
Edited by cag014
    The only time I get the same .last is when the server decides to timeout and return events = {} or events = nil,
    but that's easy to check.
    @jgab
    I newest version I have this bug:
    [27.04.2021] [21:49:32] |[31;1mERROR[0m|: QuickApp timer <Timer:0004 fun:01724440 exp:21:49:32:492> for 'EvoHomeClient', deviceId:946, crashed - fibaroapiHC3.lua:704: attempt to index a nil value (upvalue 'i_options')
    8 hours ago, petrkl12 said:
    @jgab
    Fixed v.304
    Works perfectly on v0.305 with all timeouts
    @jgab
    I have this error message - I want to create child device directly in HC3 (btw. it was working a few version ago)
    [01.05.2021] [14:17:15] |[33mWARN [0m|: Please download assets to create device types
    [01.05.2021] [14:17:15] |[33mWARN [0m|: Unknown device type: com.fibaro.lightSensor
    my setup:
    7 hours ago, petrkl12 said:
    @jgab
    my setup:
    It's warning that it doesn't know the template for that type. You get a default device structure for it.
    If you run
    hc3_emulator.downloadAssets()
    in the emulator (do it once)
    it will download a file with all templates in ~/.zbstudio/hc3emu/... and use it
    @jgab
    I'm playing with the new Fibaro controller and in some point the system has been freeze (Z-wave stuck).
    By starting the emulator it looks like nothing happens for a long time and then an error appears
    [16.05.2021] [15:20:40] |ERROR|: Error connnecting to HC3: 'closed'
    Looks like the timeout is too long and may be it will be a good idea to add debug line like : Accessing HC at IP-address and/or to set a limit for timeout
    Another request could you change the name "HC3" to a global name or could be defined by user. Right now there are three types of controllers HC3, HC3Lite and the new one. (in my case I access HCL and HC2 also)
    • 1 month later...
    Hello
    i am trying to test the sdk with the examples in the youtube video at the very first page.
    using the intrepreter Lua 5.2 in Zenobrane Studio
    i get the console output
    any ideas ?
    You need to set interpreter to Lua 5.3 (it is what QAs on the HC3 uses)
    Using Lua53
    getting this new error
    UPS had a typo in the script, got it working.
    Edited by mike79
    5 hours ago, mike79 said:
    Using Lua53
    Yes, its json, not jsonq…
    Hello again
    i am trying to find out how http post get works in Lua and the Emulator
    it aint the same as python that i am use to.
    i have been playing around converting this python api for panasonic heat pumps
    first thing i wanna is get an response that is not 403
    my script
    Does anyone have some nice examples using POST, GET, PUT.
    Edited by mike79
    12 hours ago, mike79 said:
    Hello again
    my script
    403 seems to be an issue with the authentication.
    You could  try to
    Add the extraheaders
    ["X-APP-TYPE"] = "1"
    ["X-APP-VERSION"] = "1.10.0"
    just in case the receiver is picky.
    Then remove the "HTTP/1.1" at the end of the url - as it's probably part of the protocol and not the url
    i.e. just "https://accsmart.panasonic.com/auth/login"
    Just to be sure, you get the same error on the HC3?
    Yes i get the same error on the hc3.
    Aslo with extra headers
    Also
    All the example i find for lua is using reguest, but reguest seem not to be working with hc3.
    I get a nil response.
    attempt to call a nil value (global 'require')
    is request not allowed with hc3?
    Edited by mike79
    Looking at the GitHub they are sending just the params and not the action=create that you have done.
    Try
    This is very wierd.
    after some hours i did a minimalistic python script to see if that works.
    after a few bumbs the python version  works.
    i then converted to Lua after best off my knowleadge , but the lua version does not work.
    python version.
    output
    Lua Version
    output
    as you see  i get a 403 forbidden in lua version.
    Also wierd is when printing Params and headers it shows as table in Lua output.
    Edited by mike79
    Lua prints out tables that way per default. You need your own custom print to print keys and values.
    Still some strange things - you assigns params to a 'json' key? It should be 'data' and encoded as json
    Try this
    I'm a bit unsure if the Lua version will comply with the ['SERVER_PROTOCOL'] = 'HTTP/1.1' header. It's a risk that it will be a HTTP/1.2 request anyway.
    thx ?
    reponse
    next thing is to use token and change settings.
    not sure but when i setVaribles in function onInit()
    all other functions are not reponsive.
    Dont we set Varibles on onInit() ?
    Also i get from console
    04.07.2021] [15:02:04] [WARNING] [QUICKAPP64]: Variable PROXYIP not found
    Code
    Edited by mike79
    typo
