With your new version of fibaroapiHC3C it's a completly new level of debugging :) Thanks!
    I think the timers info is quite helpful to nail those hard bugs.
    I know but my HueMain is working without bugs ???
    btw.
    I have this
        hc3_emulator.debug = {http=false, api=false, timersSched=false, trigger=false, timersExtra=false, timersWarn=false}
    but still info about timers ...
    btw.
    I have this
    Sorry, hadn't added it in the. check in version. Pushed v.183 where it should work.
    timersWarn is either false or the time that should be considered late in second. 0.9 is 900ms. 1.1 is 1100ms.
    @jgab
    how to debug QA with childs?
    I'd like to have the option for connecting real device with childs with proxy for reading information, events from childs and also for creating new ones (new child dev will be under 850)
    hc3_emulator.resources = {UI = 850, quickVars = 850, parent = 850}
    Edited by petrkl12
    13 hours ago, petrkl12 said:
    @jgab
    v.185 just pushed. Try
    E.g. the proxy field is a number of a QA instead of true
    It will add a file to your QA 850 the defines
    That the emulator when it starts up will call fibaro.call(520,"PROXY",true,<IP>) to intercept all onAction and UIEvent events.
    The QA will ping back to the emulator and if it doesn't respond it will restore the onAction handlers.
    Also if you restart the QA the handlers are restored.
    @jgab
    here is error in function QuickApp:loadChildren()
    [14.03.2021] [18:15:11] |[31;1mERROR[0m|: QuickApp 'QA_VirtualDevAIO', deviceId:850, crashed ([string "QA_VirtualDevAIO.lua"]:436: attempt to index a nil value (global '_G')) at 03/14/21 18:15:11
    5 minutes ago, petrkl12 said:
    @jgab
    Yes, there is a bug in handling of children - I’m chasing it...
    OK, Thanks
    48 minutes ago, petrkl12 said:
    OK, Thanks
    Does it work for you if you add _G around line 8270 ?
    No
    [14.03.2021] [19:40:05] |[31;1mERROR[0m|: QuickApp 'QA_VirtualDevAIO', deviceId:850, crashed (fibaroapiHC3C.lua:3620: attempt to index a nil value (field 'quickApp')) at 03/14/21 19:40:05
    stack traceback:
        fibaroapiHC3C.lua:4466: in metamethod '__index'
        fibaroapiHC3C.lua:3620: in field '__init'
        [string "QA_VirtualDevAIO.lua"]:569: in field '__init'
        fibaroapiHC3C.lua:5314: in field '?'
        [string "QA_VirtualDevAIO.lua"]:472: in method 'loadChildren'
        [string "QA_VirtualDevAIO.lua"]:811: in method 'onInit'
        fibaroapiHC3C.lua:3570: in field '__init'
        fibaroapiHC3C.lua:5381: in field 'QuickApp'
        fibaroapiHC3C.lua:4463: in function <fibaroapiHC3C.lua:4463>
        [C]: in function 'xpcall'
        fibaroapiHC3C.lua:4462: in local 'runQA'
        fibaroapiHC3C.lua:4477: in method 'callback'
        fibaroapiHC3C.lua:2569: in function <fibaroapiHC3C.lua:2565>
        (...tail calls...)
    [14.03.2021] [19:40:05] |[34mLOG  [0m|: Intercepting events from QA:850
    55 minutes ago, petrkl12 said:
    No
    stack traceback:
        (...tail calls...)
    Yes, I've seen it too. Will come with a fix tomorrow.
    v .186 with fix for child devices.
    @jgab
    now it works
    but press of buttons in HC3 are not transfered to ZBS (parent and also in child)
    I will send you my QA via pm
    debug flags for fibaroapiHC3.lua
    The values listed above is the defaults.
    To turn on flags add the fields in hc3_emulator.debug table in header.
    The above enables logging of fibaro functions and timers that are 1.1s or more late.
    Dynamic load functions for fibaroapiHC3.lua
    To dynamically load QuickApps into the emulator at runtime. The :save() functions is a utility function to save a QA in various formats.
    The functions return the loaded object so the function calls can be chained.
    Ex.
    Similar for Scenes
    This means that we can code a QA and load another to test against.
    If we have the OtherQA.lua file open in ZBS we can set breakpoints and debug that code like our main QA. We can then easily "jump" between the QAs when we debug to understand the interaction.
    If in ZBS you set user prefs:  editor.autoactivate = true
    it will automatically open unopened files if you step into them.
    If we load a QA from the HC3 and run it
    it will save the code files in your temp directory and open them when you debug.
    The dynamic load functions also work well as a basis for roll-your-own backup/restore script.
    Connecting to the emulator at runtime ( fibaroapiHC3.lua )
    The emulator, when running, opens two ports.
    hc3_emulator.webPort=6872 for a web server. This server both receives events pushed from the HC3 and also serves up a Web GUI on
     that can be used to interact with QAs and devices
    hc3_emulator.webPort=6972 is a socket listener that can be connected to (with ex. telnet) and interact with the emulator when it's running. ZeroBrane Studio is a bit limited when it comes to running commands when the application is running. This listener allows lua commands to be typed into the emulator. when it's running.
    Two commands are treated special.
    'quit' - closes the port.
    'log <pattern>' - register a log listener for log output with the tag <pattern>
    log 120
    will output all log commands with tag 'QUICKAPP120' on this port. This allows many terminals to be setup to capture the logs from different QAs and/or Scenes.
    The port can also be used to pipe commands into to turn on/off devices in specific patterns to test a QA ex.
    Multi-file support in fibaroapiHC3.lua
    The emulator supports creating, running and debugging multi-file QuickApps.
    It is also easy to upload the QA with all the files to the HC3.
    The comment
    --FILE:<file name>,<module name>;
    will load <file name> and treat it as the file in the QA with name <module name>
    In the emulator the files are loaded and can be opened in in ZBS and debugged like any Lua program with included require/dofile files.
    If the "project" is uploaded to the HC3 the files are assembled in the .fqa structure.
    @jgab
    I have problem with reading "dead" property in child devices (in HC3 it works OK). deviceID is not nil ...
    [03.04.2021] [12:38:55] |[31;1mERROR[0m|: QuickApp timer <Timer:0001 fun:017d10d8 exp:12:38:35:261> for 'QA_VirtualDevAIO', deviceId:850, crashed - fibaroapiHC3.lua:7685: attempt to call a nil value (method 'getProperty')
    @jgab
    Thanks, fixed in v0.200.2
