@jgab
here is error in fibaroapiHC3C:
My setup:
    14 minutes ago, petrkl12 said:
    @jgab
    My setup:
    You need to move the hc3_emulator.FILE("QA_Hue_F_Tools.lua","HueTools") outside the header.
    The reason is that I load the code with hc3_emulator not defined (once) - and then hc3_emulator.FILE is of course not defined.
    I will come up with a better syntax to list files to be included and that can be used in the header.
    Ok, now you can write
    --FILE:<file name>,<module name>;
    The old model, hc3_emulator.FILE(<file name>,<module name>) is still supported but will be phased out...
    @jgabsame error for your syntax above
    Ok, new version uploaded.
    I'm a bit picky when it comes to how the header should be formatted because I need to grab it with a pattern.
    It should look like
    if dofile ....
    So the 'if dofile' should start the line and end at the first 'end' that starts a line.
    I give a better error message now if I can't match the header....
    (I loaded in 100 copies of the ER4 QA and they run really smooth - in parallell :-) )
    for i=1,100 do
      hc3_emulator.loadQA('EventRunner4.lua"):install()
    @jgab a bit progress :)
    but some errors:
    1. it looks there is not item viewLayout after calling local data=api.get('/devices/'..tostring(thisDeviceID))
    2. this also doesn't work
    but some errors:
    It's a bit of a hack but it's still possible to do it.
    The match is different. To make it compatible between the emulator and HC3 the patterns needs to look like ':(%d+)' and ":(%d+):(.*)"
    However, I believe that the HC3 have become a bit better so if you throw an error within the patched setTimeout you get a reasonable line number...
    thanks, line is not correct but it's not a problem
    [ERROR] Error in fibaro.setTimeout (line:-32): attempt to index a nil value (field 'viewLayout')
    in res there is "[string \"QA_Hue_F_Menu.lua\"]:86: attempt to index a nil value (field 'viewLayout')"
    but bigger problem is this:
    Edited by petrkl12
    Uploaded  a new version that creates a .viewLayout from the provided UI. It should work now.
    Yes, but the patch of setTimeout to report the line number is not needed anymore as both the emulator and the HC3 report the right line number these days.
    The above code works both in the emulator and the HC3 but the cline fetched is always the right so line is always 0
    thanks, corrected
    it's created but this is empty:
    data.properties.viewLayout["$jason"].body.sections.items
    and it shoudn't
    11 hours ago, petrkl12 said:
    thanks, corrected
    and it shoudn't
    If you have a QA emulator file (with a header), you need to define the UI in the header too.
    It will not fetch the viewLayout from a QA running in the HC3.
    If it's an existing QA, like your Hue QA I would recommend to convert the viewLayout to an UI struct and include it in the file.
    I uploaded a new version where you can do
    ...and paste it into the header as the UI element.
    (the format is not as compact as it could be...)
    An  alternative:
    What you can do is to save the QA on the HC3 as a "unpacked file"
    If you QA on the HC3 has the deviceID 77 and name "MyQA"  run this
    hc3_emulator.loadQA(77):save("unpacked","faqs/")
    It will create a couple of files
    faqs/QA_77_MyQA.json
    faqs/QA_77_MyQA_main.lua
    : -- other module as files
    Then make a file and run
    It will load and install the "unpacked" files.
    You can then open faqs/QA_77_MyQA_main.lua etc and set breakpoints and step through them
    I will come back with more information on what file formats are supported.
    OK
    but if I want to use device from HC3 without define header how to do it?
    That a reson why I have in definition QA id (523) -  hc3_emulator={id=523,quickApp=true,poll=1500}
    50 minutes ago, petrkl12 said:
    OK
    So 523 is a proxy on the HC3 where you edit the UI? and as long as you connect to an existing proxy (523) you want the viewLayout from the proxy instead of the UI in the emulator file?
    If the proxy is deleted you loose the GUI?
    If so, let me think about how to do that...
    My case is about that I want to use everything from HC3 - it means everything from QA id 523 (existing QA in HC3) and also other APIs like list of all other devices, reading variables etc.
    Same function as you have in "old" fibaroapiHC3 :)
    You can always save the QA as a "unpacked" QA as shown in a previous post and debug this files.
    Is 523 the a proxy or the real QA?
    If its the real QA you don't get any callbacks? buttons , fibaro.calls from other QAs etc?
    523 is the real QA.
    Currently it's enough for me just redirect all read/write operations to HC3 from SDK
    Prefect feature could be detect events (ie.press buttons) from that real QA to your SDK.
    9 hours ago, petrkl12 said:
    523 is the real QA.
    That's the point with the proxy.
    The emulator can automatically install a proxy on the HC3 that looks like your real QA.
    However it will send all events back to the emulator version of the QA.
    That means that if you click on buttons/sliders in the proxy UI on the HC3 the button handlers in your emulated version of the QA is called.
    If some other QA/Scene calls your QA on the HC3 with fibaro.call(523,"turnOn") that is sent back to the emulator and calls the QuickApp:turnOn function there. This is the real advantage of the emulated model. Then when it works you choose the "deploy QA" menu option and the real QA is deployed to the HC3 with all the files.
    You don't need to specify the deviceID 523 in the header to achieve what you need.
    What I will do though is that if you have a proxy, you can edit the UI on the proxy and force that definition to be used by the emulated QA.
    This is cool.
    In ZBS user or system preferences, set:
    Then run something like
    It will download QuickApp with deviceId 47, unpack it in directory /fqas and stop the debugger when it enter the QA's :onInit and open the file in a new ZBS buffer....  and then it's just to step through and debug...
